St. Louis, MO - Charter - Page 120 - AVS | Home Theater Discussions And Reviews
AVS | Home Theater Discussions And Reviews > HDTV > Local HDTV Info and Reception > St. Louis, MO - Charter
StockInv's Avatar StockInv
09:43 PM Liked: 12
post #3571 of 3604
07-18-2014 | Posts: 635
Will Charter ever have a multi-room DVR system? Their rationalization that separate DVR's in each room is better is hogwash. You can't continue to watch the same program in different rooms.
I'm wondering why most all of the competition has a multi-room DVR system, but Charter can't seem to get it's act together on this issue.
mgkdragn's Avatar mgkdragn
11:06 AM Liked: 783
post #3572 of 3604
07-19-2014 | Posts: 11,140
Charter actually did have that tech in the works, I believe with TIVO .. but they dropped the R&D a year or two ago .. preferring, I believe, to concentrate on delivery VIA On Demand to multi devices .. which is BS because On Demand is BS .. especially on non-PPV material
nyctveng's Avatar nyctveng
11:32 AM Liked: 63
post #3573 of 3604
07-19-2014 | Posts: 880
My guess is because the current CEO Tom Rutledge who is the former CEO of Cablevision will prefer to roll out remote DVR. Seems like he's slowly turning Charter into what Cablevision is.
Remote storage DVR is more cost efficient to the cable operator than MR-DVR because it doesn't require costly new hardware, doesn't require a costly truck roll, training techs on MOCA, installing filters, etc. Remote storage DVR if implemented can use existing hardware in the customers' homes and only require hardware installed & work done in the headend and hubs.
03:28 PM Liked: 783
post #3574 of 3604
With what Charter charges for a DVR "rental", they are doing quite well with the current solution ..
Robert Simandl's Avatar Robert Simandl
08:17 PM Liked: 21
post #3575 of 3604
07-28-2014 | Posts: 2,816
Gonna be adding Charter to my fiancee's Tivo Wednesday (just getting a multistream cablecard into the Tivo, not getting a Charter DVR). She was OTA-only up til now. I told the gal at the desk it has to be a multistream card, because the Tivo specifically states "multistream cablecard only."
Any of you experienced Charter customers know of any "gotchas" I should be on the lookout for, before/during/after installation? Charter's ability to screw things up is legendary, so I'm sure there have to be some.
ort's Avatar ort
04:17 PM Liked: 11
post #3576 of 3604
07-31-2014 | Posts: 39
The only "gotcha" per se is that the techs have no idea what the hell they are doing with cable cards and only about 50% of cable cards seem to actually work. Prepare yourself for a long drawn-out and most likely bad experience.
Most techs have never even seen a TiVo. They don't even carry able cards in their vans anymore. Read up on the process before they come out. Print out the instructions and be prepared to show it to them and/or do it yourself.
09:19 PM Liked: 21
post #3577 of 3604
07-31-2014 | Posts: 2,816
You had that 100% right. It was his first ever Cablecard install. He didn't even know whether the Cablecard he had was a single stream or multistream (the Tivo specifically says "multistream only" over the slot). Luckily it turned out to be a multistream. Took 3 hours even though we had existing wiring from a previous Charter install at the house. But everything seems to be working fine now. Thanks!
10:58 PM Liked: 21
post #3578 of 3604
08-06-2014 | Posts: 2,816
Okay, noticing that there's a lot of channels that have no info in the Channel Guide. FX is one. Not in the Channel Guide at all, either the HD or the SD channels. So I manually added channel 784 to the guide and FX is there, but the guide says no info available. Had to schedule a manual recording for the new Kelsey Grammer sitcom.
At first I figured it was something to do with the Tivo and Cablecard, but a coworker (who has the regular Charter DVR) says she's missing channels in her guide, too.
Can someone shed some light on this?
elgibby's Avatar elgibby
11:19 AM Liked: 10
post #3579 of 3604
08-07-2014 | Posts: 434
I have that problem as well since the last channel expansion. I admit I have not called because I can't bear another round with the phone people (although, to be fair, Charter CS is a lot better than it used to be).
But that's what you'll have to do: Call Charter and make sure that the service you signed up for is the service they think you have; and/or they might have to send signal to the box to reset the CC to receive the channels you're supposed to get.
11:21 AM Liked: 10
post #3580 of 3604
I'm still using TiVos but I'm considering going back to Charter DVR and using Slingbox to get remote viewing etc. But I fear that Charter's DVR tech is still stone age.
Can anybody tell me what the top box is that Charter's using? Make and model number?
thx
11:39 AM Liked: 783
post #3581 of 3604
08-07-2014 | Posts: 11,140
This is an issue with many cable cards .. I have never heard, though, of a regular Charter DVR not picking up on all channels and providing viewing info .. although, if it's newly installed, or the power goes out it can take some time to re-populate the info .. sometimes days for it to see 10 days out ..
11:40 AM Liked: 783
post #3582 of 3604
thx
It's usually best to contact Charter on that since it can vary by the area .. there is not full consistency that I know of ..
Saluki's Avatar Saluki
12:13 PM Liked: 10
post #3583 of 3604
08-08-2014 | Posts: 511
The problem I keep having is that my DVR is scheduling rerun shows to record even though it is set for new shows only. This occurs when the program guide info is something generic. For example, American Pickers might say something like "2 friends travel the country searching for treasures" or whatever instead of info specific to the particular episode. I have noticed this on several programs (American Pickers, Deadliest Catch & American Restoration to name a few).
Any ideas how to solve this?
12:17 PM Liked: 783
post #3584 of 3604
08-08-2014 | Posts: 11,140
I've had that happen myself .. your DVR is not fully populated .. I unplug then plug back in for a hard re-boot .. it takes some time to fully re-populate, but it has always corrected the problem .. my main problem channel is AMC and FX ..
12:18 PM Liked: 10
post #3585 of 3604
08-08-2014 | Posts: 434
It's a flagging issue at the content level. I'm getting that issue lately with Daily Show. Also have had that problem with shows like Continuum that had their first run in Canada or the UK: if I set tivo season pass for new episodes only, it won't record any.
08:04 AM Liked: 10
post #3586 of 3604
08-14-2014 | Posts: 511
I forgot to check my channel guide before leaving for work this morning. Did the SEC Network get added in overnight?
04:53 AM Liked: 21
post #3587 of 3604
08-24-2014 | Posts: 2,816
Have Charter internet and having problems?
As of yesterday, Charter is having DNS routing issues nationwide. Don't know (and don't care, you'll see why below) if they've gotten it fixed today.
Because if you're a computer geek you can bypass Charter's issues and fix it yourself.
Change your default DNS to 8.8.8.8 and 8.8.4.4 (Google's DNS server) instead of automatic (using Charter).
You can do this per computer/device, or in your router which will apply to all devices connected to it (wired or wireless). If you have several PC's and Smart TV's and Roku boxes and stuff, it's best to do it in the router (so you only have to do it once).
Should solve your internet problems instantly, and you do NOT have to change this setting back if and when Charter gets its own problems fixed.
https://developers.google.com/speed/...dns/docs/using
You can also Google "how to manually change DNS on _____ router"
Replace _____ with your router make/model.
Hope this helps.
08:27 AM Liked: 12
post #3588 of 3604
10-04-2014 | Posts: 635
Has anyone heard anything about Charter coming out with a mult-iroom DVR system?
ort's Avatar ort
10:34 PM Liked: 11
post #3589 of 3604
10-08-2014 | Posts: 39
Ugh. Charter's HD is so compressed and full of artifacts. It's really terrible.
Any chance this will ever get fixed, or is it just not a priority?
Hockey looks like hot garbage. So does everything else, but sports look extra crappy. Anything with a lot of movement and complicated busy patterns like grass on a baseball field.
08:05 PM Liked: 12
post #3590 of 3604
10-21-2014 | Posts: 635
Does anyone know if there is a way to copy shows from my Charter DVR to a TIVO?
07:46 AM Liked: 783
post #3591 of 3604
10-22-2014 | Posts: 11,140
Most cable company DVRs (including Charter) are akin to a roach motel for TV and movies. Shows go in, but the can't come out. Although your Charter DVR may have a USB port, they're effectively neutered and incapable of exporting data.
hologon's Avatar hologon
11:19 AM Liked: 10
post #3592 of 3604
01-08-2015 | Posts: 6
Hello everyone,
My wife & I have 2 of the 2-Tuner Charter Moxi units. They are model number 3012.
We have had them since at least June, 2012 when they received their latest software update. Until very recently, we have had no problems getting Video On Demand. About a 1 or 2 months ago, we started noticing problems with Video On Demand. It would kick us out of an On Demand program for no apparent reason. Eventually, we could no longer view any Video On Demand programs. It has been like this for about 2-3 weeks.
1st, we called Charter for support. They had us do the usual things, reset the system, (no luck); unplug the system & wait (no luck); re-do the provisioning for VOD (no luck).
I have reviewed the on-board diagnostic tools. As far as I can tell, everything looks the way it should. The internal modems appear to be functioning as they should.
We even had a tech come out. Of course, he didn't know much about the Moxi. But he checked the signal strength at the pole, at the ground block where it enters our house, at our 4-way splitter, and at the wall. Everything was as it should be.
ANY ADVICE WOULD BE GREATLY APPRECIATED! We both love our Moxis. But receiving Video On Demand is absolutely necessary.
11:57 AM Liked: 783
post #3593 of 3604
01-08-2015 | Posts: 11,140
Originally Posted by hologon View Post
Hello everyone,
I'd guess most of the MOXies are dying a slow death .. I finally gave up on ours some time back .. lost some DVR material, but nothing lasts forever ..
06:08 PM Liked: 10
post #3594 of 3604
Keep in mind that Video On Demand (VOD) has stopped working on both of our Moxis at the same time. While each of our units will eventually die, it is very unlikely that they would both die at the same time.
I am thoroughly convinced that our VOD problem is on Charter's end. I am also convinced that it was caused by something that Charter has done, and that they are completely unaware that what they did would have this result.
For example, I read that strong return amplifiers can ruin the return signal frequency for an entire neighborhood. One of our neighbors, or a Charter Tech, could very easily have hooked up a powerful line amplifier. That amplifier then could have made it impossible for us to get any VOD through our Moxis.
09:16 AM Liked: 783
post #3595 of 3604
01-09-2015 | Posts: 11,140
While I don't disagree with your theory (although it's a new one for me), bottom line is you may as well get a couple new DVR's since the chance of Charter actually doing or trying anything outside the "script" is pretty slim .. my MOX'ies were great while they lasted, loved the OSD, but in the last months before I had Charter replace, they were prone to problems .. have them bring replacements, probably a Moto, and test the VOD before the tech leaves your house .. see what happens .. if the Moto works perfectly, I think you'll have your answer .. good luck ..
tootal2's Avatar tootal2
09:22 AM Liked: 10
post #3596 of 3604
01-11-2015 | Posts: 343
Does anyone know what channels I need a tuning adapter for? I wonder if I can unplug it from my windows media center computer.
01:49 PM Liked: 10
post #3597 of 3604
01-11-2015 | Posts: 6
Yup,
This is the obvious test. And if things go as I anticipate, the newish DVRs would operate as they should.
However, assume for a moment that we can't get VOD with the newish DVRs. I would definitely keep both MOXIs as the problem would clearly be on Charter's end. But then, what do I tell the Charter Tech? What would his next move be? The last Charter tech who came out 1 or 2 weeks ago said that everything about our signal as exactly as it should be.
01:55 PM Liked: 783
post #3598 of 3604
01-11-2015 | Posts: 11,140
Yup,
I would demonstrate the VOD issue while he was there and demand they install a signal booster / amplifier .. and I would still keep the new DVR's .. the MOXies have a history of issues ..
bunglebungle's Avatar bunglebungle
08:43 AM Liked: 10
post #3599 of 3604
02-04-2015 | Posts: 151
Charter - screw you for moving MLB Network to a higher tier.
08:56 AM Liked: 783
post #3600 of 3604
02-04-2015 | Posts: 11,140
Charter does one thing very well .. Tier manipulation ..
Subscribe to this Thread
Powered by vBadvanced CMPS v3.2.3
