digital cable..?! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-28-2007, 05:08 AM - Thread Starter
Andyisc00l's Avatar
OK-- I wanna get digital cable with HDTV-- I'm in mound, minnesota, like that matters...
anyways whats the best way to get Digital cable with HDTV...is it DirectTV or something like Time Warner?? any thoughts?
Andyisc00l is offline
post #2 of 3 Old 02-28-2007, 05:57 AM
HappyFunBoater's Avatar
The best way to get digital cable is from your cable company. The satellite companies like DirectTV and Dish don't supply digital cable. Perhaps you meant "what is the best way to get HDTV?". OTA is always typically the best quality if you can get it. Start here to find out how close you are to the transmitters:
http://www.antennaweb.org/aw/welcome.aspx
If you want more than just local HDTV, then you'll have to see what other folks think about cable in your area. (Look for your area in the AVS forum.) It could be better or worse than satellite. Also, you'll have to decide which channels you want. Typically satellite has more HD channels than cable.
HappyFunBoater is offline
post #3 of 3 Old 02-28-2007, 07:09 AM
CPanther95's Avatar
Quoted: 72 Post(s)
Liked: 94
Check the United States Thread Index at the top of the forum to find the thread for the Minneapolis DMA cable company that serves your area.
CPanther95 is offline
Closed Thread Local HDTV Info and Reception
