Chicago, IL - OTA - Page 404 - AVS Forum | Home Theater Discussions And Reviews
 31Likes
post #12091 of 12664 Old 07-17-2014, 05:24 PM
gonefishin's Avatar
Location: Marseilles, Ill. On the back side of Seneca...south of I-80 zip:61341
Originally Posted by longwong View Post
Wonder how the tuner is on the Roamio, although it's nice to see they finally built-in the wifi. Still lament that the Premiere tuner is less sensitive than the Series 3.
Hi longwong,
go ahead and read through some of my previous posts, here in the Chicago OTA thread. I just moved to a new area, out in the fringe borders of Chicago OTA reception. In our old house we had a Tivo HD and had great reception with our antennas. But after the move, some 40 miles further from Chicago, the Tivo HD would only pull in channel 7. My Tv tuner would get most of the channels, most of the time. I borrowed my dad's Tivo Romio, to see if it had better reception...better than my HD. It got all the major networks...so it was easily performing better than my HD...way better in fact.
I since changed out the coax and preamp for a high db one...I have even better results.
that's where I am so far...
Dan
not working
not working
enjoy the music!
gonefishin is offline
post #12092 of 12664 Old 07-18-2014, 07:54 PM
longwong's Avatar
Maybe Roamio actually is truly the step-up from Premiere that they've been promoting. Just wish they would include an OTA tuner on the Elite models or at least offer it with a larger capacity, but I guess we should be grateful that they even still have a tuner to begin with.
Good luck with your reception quest.
Originally Posted by gonefishin View Post
Hi longwong,
Dan
longwong is offline
post #12093 of 12664 Old 07-18-2014, 10:25 PM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 30
With the base model Roamio you can easily swap out the hard drive in about 15 minutes, for a 3tb drive.
Johnla is offline
post #12094 of 12664 Old 07-19-2014, 07:08 AM
gonefishin's Avatar
very true!
I think we are very lucky that they're still offering an OTA option on their DVRs.
not working
not working
enjoy the music!
post #12095 of 12664 Old 07-19-2014, 10:33 AM
nyctveng's Avatar
Quoted: 110 Post(s)
Liked: 65
gonefishin, your signature links don't work
nyctveng is offline
post #12096 of 12664 Old 07-20-2014, 01:01 AM
bonline's Avatar
Originally Posted by OTA_GUY View Post
Get the biggest thing that will fit. Keep the receipt.
Think about putting the home run in the attic and dropping Ethernet into the basement.
What do you mean drop ethernet to the basement? Why do I need Ethernet with the coax cables?
bonline is offline
post #12097 of 12664 Old 07-20-2014, 05:51 AM
OTA_GUY's Avatar
The closer the tuner is to the antenna the better the signal it receives. So think about putting it in the attic. If the hdhomerun tuner is in the attic the coax drop to the basement won't be needed. If you plan on using other tuners like a tv, or dvr then the coax will need to be dropped ... If the attic isn't climate controlled the hdhomerun might not work when summer comes....
OTA_GUY is offline
post #12098 of 12664 Old 07-22-2014, 09:22 PM
bonline's Avatar
I think I may have misled my issue by using the term homerun. Let me begin again - I live in Naperville (Rt59/95th), I am looking for a antenna to stick in the attic. In my basement there is a central distribution box (homerun) that currently distributes cable/dish signals to all of my TV outlets. My thinking was I would set-up a antenna in the attic, drop the coax to this distribution box, so that the signal will be available at all of my TV outlets.
Please advise - how I would go about distributing the antenna signals to all of the rooms, antenna recommendation and anything other words of wisdom.
Thanks you!
bonline is offline
post #12099 of 12664 Old 07-23-2014, 04:06 AM
ProjectSHO89's Avatar
Quoted: 256 Post(s)
Liked: 127
A "homerun", in electrician's parlance, is a line that goes all the way from the point of delivery/service back to the central distribution point. It is not the central distribution point itself.
Your plan is pretty commonly done and usually works well enough.
ProjectSHO89 is offline
post #12100 of 12664 Old 07-30-2014, 04:27 PM
Liked: 1
Hi longwong,
Dan
Dan, new to forum and I am from the NW Chicago IL area. I am about 45-50 miles from the city (Antioch 60002) and am wondering what in your opinion is the best outdoor OTA antenna (HD) I can get for my area. I am near Fox Lake and can easily get ABC/NBC, BUT can NOT get CBS for some reason. I am running an HD Yagi from Solidsignal right now and its good, BUT I am missing some OTA Chicago stations? Thoughts and help greatly appreciated. I am interested in an High Gain outdoor and will even look at a rotatable unit or fixed.
GlennGlenn is offline
post #12101 of 12664 Old 07-30-2014, 06:24 PM
Quoted: 256 Post(s)
Liked: 127
WBBM operates on a VHF channel with a modest level of power. If your "HD Yagi from Solidsignal" is a UHF-only antenna, that explains the problem with that station.
post #12102 of 12664 Old 07-31-2014, 06:36 PM
Liked: 1
Any thoughts then on another antenna that "really draws them in" from 50 or more miles from source. My antenna us about 25 feet high on a mast. I run a amp with my Yagi and still can not get that great reception, even on the UHF stations. Any links or suggestions would be appreciated.
Any thoughts on Antennacraft hd1850?
OTA_GUY likes this.
post #12103 of 12664 Old 08-01-2014, 04:13 AM
Quoted: 256 Post(s)
Liked: 127
You don't need that big thing. Just add a 5 or 10 element high-VHF antenna.
post #12104 of 12664 Old 08-01-2014, 06:00 AM
dave73's Avatar
Quoted: 17 Post(s)
That antenna would be good, if you want to try & get WIWN (Weather Nation) on RF 5 from Milwaukee. That might also work if you want to try & get WOCK-CD on RF 4 from Chicago (some people from South Bend Indiana have picked up this station at only 300 watts with no problems, while I'm about 30 miles SE, & have problems on some days getting it). Otherwise, I'd recommend either the Antennacraft HBU558 or Winegard HD7698 antennas if you're looking at a combo. If your current antenna is UHF only, & picks up the bulk of your stations, adding the Antennacraft Y10-7-13 antenna would help for WBBM, to an extent. Running a generic TV Fool chart for your area, WBBM-TV will be tough, considering the terrain in your area that would make it tough to get some stations. Since you're near the state line, you also can get Milwaukee stations too, & it shows that you have a slightly better chance of getting WDJT on RF 46 better for CBS than WBBM on RF 12 from Chicago. Usually, most people have 2 combo antennas in your area, along with those in Kenosha County, since both markets are VHF/UHF. For Milwaukee, they have 2 VHF stations: WIWN on RF 5, & they carry Weather Nation, & WMVS on RF 8 (one of 2 PBS stations, with the other on RF 35), while everyone else (including all network affiliates) are on UHF. For Chicago, we only have 1 full power VHF, & that WBBM-TV on RF 12, while we also have a Class A station on RF 4, WOCK-CD, that few people get with no trouble (I get it, but reception isn't always clear, especially in the summer). If you only want one antenna, then I'd recommend a rotator as well, since you may want to get Milwaukee stations as well. You might as well take advantage of it, as it allows you to see some syndicated shows in different timeslots on different stations. I don't know if you want Ion Television or the subchannels. If you do, I'd recommend getting it from WPXE on RF 40, as it's licensed to Kenosha, while transmitting from Milwaukee. With that in mind, they must send a lot of signal toward Kenosha in order to cover their COL, & send a good amount of signal into Lake & McHenry Counties of Illinois.
Go to this link: http://www.tvfool.com/?option=com_wrapper&Itemid=29, & fill out your address to see what stations can be received in your location (address is hidden to us), & post your personal chart from the link created, & post it on this board, so we can give you better recommendations on an antenna or 2. Also, be sure you put the height you're placing your antenna, so it can give you a better analysis. If you don't, then by default, it goes by ground level, rather than the height you want your antenna(s). I'm curious as to which antenna you're using right now from Solid Signal. Most of the Solid Signal brand antennas are UHF only, with 1 being a deep fringe all channel yagi. And again, we won't recommend any all channel combo antennas, unless you think you might want WIWN (Weather Nation) on RF 5 from Milwaukee.
dave73 is offline
post #12105 of 12664 Old 08-01-2014, 02:03 PM
Lord_Zath's Avatar
Quoted: 112 Post(s)
Liked: 109
I'm in Antioch and get WMAQ - CBS *most* of the time with a simple Radio Shack rabbit-ear antenna in the attic tied to a CM-7777 amp. For UHF I have a DB-4. Works great, and the times that I don't get it, I can always switch to Milwaukee's CBS (56 or 58).
Holding the fort on old games that play the same as the new ones, minus the $400 price tag.
Lord_Zath is offline
post #12106 of 12664 Old 08-05-2014, 07:36 PM
Liked: 1
Hdb91x is the hint from solid signal that I am running and instill can't get wbbm channel2
post #12107 of 12664 Old 08-06-2014, 04:37 AM
Quoted: 256 Post(s)
Liked: 127
Go back and read my previous response. Your answer is already there.
post #12108 of 12664 Old 08-06-2014, 06:00 PM
ryadoggy1987's Avatar
When will escape and grit appear? 7:30 Wednesday able to pick up south bend CBS with wingurd flatware indoor antenna
ryadoggy1987 is offline
post #12109 of 12664 Old 08-07-2014, 07:04 AM
Rob1956's Avatar
Any news about WBBM moving to digital channel 26 from 12? My Channel Master OTA DVR can pick up every available Chicago channel with a signal strength of 83 or more from Hickory Hills, but never WBBM no matter the orientation of the indoor antenna (apartment bound).
Rob1956 is offline
post #12110 of 12664 Old 08-07-2014, 07:44 AM
ADTech's Avatar
Quoted: 127 Post(s)
Liked: 68
WBBM is not moving to RF 26. They are using RF26 as a low power UHF translator to supplement the VHF 12 signal for better indoor coverage in the metro Chicago area.
Tech support for Antennas Direct
ADTech is online now
post #12111 of 12664 Old 08-08-2014, 05:15 AM
snoopy1954's Avatar
My recommendation would be to not try to get WBBM , and try for WIFR in Rockford. I live in Crystal Lake, and I have put 2 antennas in the attic. One at Chicago, the other aimed at Rockford. I have given up on WBBM sending a proper signal. There is a way to do this so you only use one coax.
snoopy1954 is offline
post #12112 of 12664 Old 08-08-2014, 05:26 PM
cgmv123's Avatar
Quoted: 42 Post(s)
Liked: 36
WBBM can't transmit at full power on 26 because they have to protect WKOW here in Madison.
Max Vrany
@cgmv123
cgmv123 is offline
post #12113 of 12664 Old 08-08-2014, 05:42 PM
hrlyboy1's Avatar
WFLD with the Bears Network had horrible breakup for the first 25 minutes of the game tonight in Chicago. In addition, the main picture at midfield from medium range has horrible resolution. Looks like 480i at best.
Bill M.
Hoffman Estates, Il
hrlyboy1 is offline
post #12114 of 12664 Old 08-08-2014, 08:23 PM
jmmilner's Avatar
My brother in Las Vegas was seeing the same thing, so I think the issue was with NFL Network or the crew they used to provide the video. The commercials during the period in question all appeared perfectly, aside from a few that were graphics over the playing field as a background.
My beef with WFLD is that their announcers seemed totally clueless to the video problem for the duration and I have yet to see WFLD even acknowledge the issue. Next week's game is on ESPN so we can see for ourselves if the first team looks as good as the announcers claimed.
For my money the whole thing was a 25 minute commercial for listening to WBBM for the play by play. At least those guys tried to describe the on-field action!
jmmilner is offline
post #12115 of 12664 Old 08-09-2014, 08:23 AM
kevin j's Avatar
Quoted: 18 Post(s)
Liked: 27
The pq on the Bears game last night looked like the old Fox Digital Widescreen imho[they ought to pony up the money to do the games in HD locally].
If a movie or concert video or a TV show isn't on blu ray it darn well should be.
kevin j is offline
post #12116 of 12664 Old 08-09-2014, 01:29 PM
dave73's Avatar
Quoted: 17 Post(s)
They also have to protect WCCU Champaign, IL as well. That's why the signal is also nulled in that direction, but not as much, since WCCU nulls theirs to the north, for when WCIU was still on RF 26.
dave73 is offline
post #12117 of 12664 Old 08-10-2014, 03:55 AM
Quoted: 256 Post(s)
Liked: 127
There is no null in the direction of Champaign. WBBM-26 is, in fact, at almost maximum power in that direction.
WBBM's license is for 15 kW on RF 26, which is the maximum legal limit for a UHF digital translator. Because of the adjacent markets, WBBM could only operate as a translator on RF 26 as a "full-power" station would have interfered and the other stations already enjoyed legal interference protection.
post #12118 of 12664 Old 08-10-2014, 02:29 PM
Heard new escape and grit primear no longer august 11th google it
post #12119 of 12664 Old 08-11-2014, 07:49 AM - Thread Starter
sebenste's Avatar
Quoted: 23 Post(s)
The video encoder crashed. Even when it was rebooted, it still looked bad. The Bears made it clear that it wasn't WFLD's fault at all; it was at the truck.
http://www.chicagotribune.com/sports...808-story.html
The Bears produced the game; everyone else was just picking up the feed.
Gilbert
sebenste is offline
post #12120 of 12664 Old 08-11-2014, 08:06 AM
kevin j's Avatar
Quoted: 18 Post(s)
Liked: 27
I noticed the same thing with last season's preseason games(less than HD picture quality)it's still the same so far this season.
kevin j is offline
digital audio , wrjk
