Chicago, IL - OTA - Page 407 - AVS Forum
 2Likes
post #12181 of 12187 Old 10-23-2014, 06:48 PM
Trip in VA's Avatar
Quoted: 82 Post(s)
Liked: 64
Send a message via AIM to Trip in VA Send a message via Yahoo to Trip in VA
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #12182 of 12187 Old 10-24-2014, 11:11 AM
danwojciechowski's Avatar
Originally Posted by bonline View Post
Hello - I am hoping you folks can help me out. I am looking to install an antenna in my attic. I live out in Rt59 Naperville area. I would like to drop the line from the attic to the basement where I have like a homerun connection. Please advise which antenna and other equipment I should look to purchase to get quality reception (especially CBS). Thanks in advance for your help.
I'm not too far from you. I'm off Eola Road by Waubonsie HS and I get fantastic reception.
Currently, I have a Winegard HD7694P in my attic above my 2 story house, pointed towards Chicago. I had been using a ChannelMaster 7777 pre-amp, but when it died after 10 years, I replaced it with an AntennaCraft 10G212. I run 3 drops from the output of the pre-amp: upstairs bedroom, main floor family room, and basement family room, unfortunately all with RG-59, rather than the newer and better RG-6 coax cable. Still, with this setup, as I said, I get fantastic reception. The only things I don't get reliably are the low-power digitals. Still, in this market, my scan turns up roughly 70 channels, of which I keep about 30 in my favorites.
Winegard makes larger members of the 769x family, which would provide a little more gain. The 7694 is remarkably compact, so it will work in just about any space, even an attic crowded with trusses.
danwojciechowski is offline
post #12183 of 12187 Old 10-24-2014, 12:03 PM
Mike99's Avatar
Quoted: 32 Post(s)
Liked: 49
I looked at the AntennaCraft 10G212 preamp instructions & noticed it said not to mount the power supply in the attic, but I have no idea why not. Are you running your 3 drops using a splitter in the attic & located inbetween the preamp & power supply (presumably located inside your house)? Or did you also put the power supply in the attic?
Mike99 is offline
post #12184 of 12187 Old 10-24-2014, 02:02 PM
bonline's Avatar
Dan - Thanks! You are close by. So help me understand this 3 drops you mentioned. How would I go about doing it or did you outsource this job to someone (contact details)? I have a similar set-up as you. Is it possible to send it to one spot and then it gets distributed from there?
bonline is offline
post #12185 of 12187 Old 10-27-2014, 07:41 PM
Bobcrane's Avatar
Having some odd TV drops after 6 years of flawless signal -
ABC 7 (Chicago) I DVR Castle on Monday's at 9pm. Last 2 Monday's the last 10 minutes of the show experiences a lot of pixelating and drops. I'm watching signal on the HDHomeRun. The one recording now seems to be around 87-90% signal quality while the other tuner drops as low as 73% for the same channel. All other channels are pegged at 100% signal quality.
Anyone else noticing issues with ABC?
CBS 2 (Chicago) - we record a handful of shows on this station. However Scorpion experiences similar drops at the last 10-15 minutes of the show each week. No other night/time of week has this issue.
Just curious if anyone else is experiencing this.
Bob
Bob
Bobcrane is offline
post #12186 of 12187 Old 10-27-2014, 10:42 PM
Mike99's Avatar
Quoted: 32 Post(s)
Liked: 49
Bob
I just watched Scorpion & there were no dropouts on my HTPC which uses a pair of AverMedia Duet tuner cards. Do not recall any problems from prior weeks either. Never had a problem with Castle either. That being said, every once in a while I might get a very brief pixelation on a channel but I chalk it up to the weather or a transmission problem.
Mike99 is offline
post #12187 of 12187 Old 10-28-2014, 05:40 AM
Bobcrane's Avatar
I loaded new software for my HDHomeRun's and it automatically upgraded the unit to the latest firmware. Beginning to wonder if thats the culprit.
Biggest problem will be figuring out which firmware I was on.
Thanks for the feedback Mike99.
Bob
Bobcrane is offline
User Tag List
