Chicago, IL - OTA - Page 411 - AVS | Home Theater Discussions And Reviews
 8Likes
post #12301 of 12322 Old 04-16-2015, 03:15 PM
Mike99's Avatar
Quoted: 90 Post(s)
Liked: 56
Originally Posted by retromzc View Post
2.1 and 2.2 continue to come in fine here. Signal meter is pegged 100%
What are you, and others, using as signal strength meters?
Mike99 is offline
post #12302 of 12322 Old 04-16-2015, 05:38 PM
HisSvt2's Avatar
Liked: 0
i use windows 7 media center channel meter.
HisSvt2 is offline
post #12303 of 12322 Old 04-17-2015, 05:26 AM
retromzc's Avatar
I'm simply using the signal quality meters of three different brands of tvs. All three show 100% strength with no glitches. (except of course if there is any lightning in the area)
R. B.
retromzc is offline
post #12304 of 12322 Old 04-27-2015, 03:53 PM
Arianna's Avatar
Liked: 0
I am trying to get channel 13.1. I live 3 miles away from the transmitter. Why is it so hard to get that channel!???
Arianna is offline
post #12305 of 12322 Old 04-28-2015, 02:20 PM
andyross63's Avatar
Quoted: 50 Post(s)
Liked: 41
WOCK broadcasts on RF4. You need a VHF-Lo capable antenna (big).
Need help with your Motorola DVR? Check the Wikibook: How to use a Motorola DVR
andyross63 is online now
post #12306 of 12322 Old 04-30-2015, 04:33 PM
Arianna's Avatar
Liked: 0
Thanks for answering my question. I'm using a radioshack antenna (Since I can't post a link.. It's called Radioshack Amplified HDTV Antenna.. got it for $35 bucks)
I get 78 channels but I don't get channels: 13.1, 13.2 , 13.3 , 13.4, 13.5. So I guess I need one of those big antennas(Outdoor) I rent so I don't think I'll be able to get that. But again Thanks for the info.
Arianna is offline
post #12307 of 12322 Old 05-01-2015, 02:23 PM
andyross63's Avatar
Quoted: 50 Post(s)
Liked: 41
It doesn't have to be an outdoor antenna, but it needs to support the long wavelengths of VHF-Lo. Most indoor antenna's without the big dipoles (rabbit ears) will have problems.
post #12308 of 12322 Old 05-01-2015, 07:37 PM
CubsWin1's Avatar
The past 2 days I have been getting perfect reception with a signal in the low 60's, about 5 points higher than the best signal I was getting before.
Are fluctuations like this normal? I am new to OTA, so I don't know whether signals may vary slightly by season or with warmer weather (or something else), but hopefully I continue to see readings in the 60's and I will be happy.
CubsWin1 is online now
post #12309 of 12322 Old 05-02-2015, 06:35 AM
retromzc's Avatar
My reception remains pretty stable year round. The exceptions being some early mornings during the spring - early autumn seasons and evenings when it is very hot and humid. During those times atmospheric conditions sometimes allow very distant stations to overcome the Chicago stations. So, in a sense, yes, weather conditions can and do play a roll in reception issues from time to time.
George Molnar likes this.
R. B.
retromzc is offline
post #12310 of 12322 Old 05-06-2015, 08:10 PM
PStew67's Avatar
Liked: 0
Can anyone give me antenna brand/model recommendations for Crystal Lake. In a 2 story home near main beach. I'd prefer to put it in the attic but could also roof mount. Also, I'd rather buy more antenna than I need so I don't lose a signal when it rains. I'm also ok with 2 antennas, one pointed to Chicago and the other to Rockford for WBBM as another Crystal Lake poster had suggested. Also, is there a product that will join the signals from 2 antennas? Do I need a pre-amp, I've seen posts saying yes and others saying never. Thanks...
PStew67 is offline
post #12311 of 12322 Old 05-07-2015, 06:14 PM
dicko2's Avatar
Combining antennas is a bad idea where you're at. We get stations from Milwaukee, Rockford, & Madison. No matter where you aim an antenna, there is always something coming in from the sides or rear, Madison in particular. Combining antennas negates the directionality of the antennas and during times of atmospheric ducting these interfering stations will overpower the desired signals. I speak from experience.
A better solution is to keep the antennas separate and by editing the sources of each tuner you can dedicate tuners to each metro area the antennas are pointed to.
You might want to try aiming an antenna at Milwaukee instead of Rockford. I find its easier to receive and WDJT, CBS, is a powerhouse compared to Rockford.
You'll also need an amp at the antenna and possibly a line amp if you're doing any kind of splitting.
dicko2 is offline
post #12312 of 12322 Old 05-07-2015, 09:06 PM
PStew67's Avatar
Liked: 0
Thanks for the reply dicko2. What antenna are you using or what would you recommend?
PStew67 is offline
post #12313 of 12322 Old 05-08-2015, 10:38 AM
dicko2's Avatar
My antenna is so old I dont remember what it is, but it was the biggest one I could find at the time.
dicko2 is offline
post #12314 of 12322 Old 05-09-2015, 01:01 PM
Quoted: 33 Post(s)
Liked: 5
I live in Downers Grove on 6th floor of an apartment. Somehow I can never get CBS and NBC. My apartment is facing south West. Is that the reason I don't get CbS?
shinepushpan is offline
post #12315 of 12322 Old 05-09-2015, 02:01 PM
ProjectSHO89's Avatar
Quoted: 119 Post(s)
Liked: 89
Partially, probably. You didn't identify what antenna you have, but I'll take a SWAG that its a UHF-only model.
ProjectSHO89 is offline
post #12316 of 12322 Old 05-09-2015, 11:24 PM - Thread Starter
sebenste's Avatar
As for the actual antenna, a ChannelMaster 4228 HD should do the trick very nicely. One on the south side of Crystal Lake gets all the Chicago stations; his is mounted on the roof. Otherwise, Dicko2 is correct.
Gilbert
sebenste is offline
post #12317 of 12322 Old 05-10-2015, 11:00 AM
Quoted: 33 Post(s)
Liked: 5
Thanks. I bought a clearstream2v yesterday and now I get more than 65 channels including cbs and nbc. I need to keep the antenna in my Balcony to get all these. If I keep it inside home, I end up with only few channels and no CBS/NBC
My previous antenna wasn't UHF alone. I used to get CBS when I lived in Skokie. It is an indoor flat antenna.
post #12318 of 12322 Old 05-10-2015, 11:41 AM
Quoted: 119 Post(s)
Liked: 89
Glad to hear the C2V did so well for you. It's a bit large for an indoor antenna, but will run circles around just about anything else once you figure out how to exploit its capabilities.
Most "flat" antennas do a pretty lousy job on VHF, they're not big enough.
post #12319 of 12322 Old 05-16-2015, 05:28 PM
OTA_GUY's Avatar
Currently 7.2 has a rebroadcast of today's cub game....
OTA_GUY is offline
post #12320 of 12322 Old Today, 08:30 AM
andyross63's Avatar
Quoted: 50 Post(s)
Liked: 41
Noticed that WTTW has changed 11.1 to 720p.
post #12321 of 12322 Old Today, 08:58 AM
FSugino's Avatar
On what may be a related note, the Create channel is broadcasting in widescreen now. I think it's still 480i, though.
Flicks? Here's my collection. And I've seen a lot, too.
FSugino is online now
post #12322 of 12322 Unread Today, 02:30 PM
andyross63's Avatar
Quoted: 50 Post(s)
Liked: 41
Yes, it's 480i@16:9.
If I remember, WTTW-HD started at 1080i, ran 720p for awhile, then went back to 1080i? I never watched Create or V-Me much, but Prime was surprisingly good for SD.
