Chicago, IL - OTA - Page 418 - AVS Forum | Home Theater Discussions And Reviews
 22Likes
post #12511 of 12530 Old 03-28-2016, 07:56 AM
smahoney1's Avatar
Thanks for the reply.
smahoney1 is offline
post #12512 of 12530 Old 03-28-2016, 08:55 AM
shpitz's Avatar
Quoted: 57 Post(s)
Liked: 52
I used the Channel Master CM-4228HD, received all channels including CBS. I had it mounted on a pole attached to a tripod on the ground, so it was maybe 4ft above ground. If I mounted it on the roof, I would think reception was even better, but I got all the channels I wanted just above ground-level.
I didn't use an amp at all, it went straight to HDHR receivers.
I lived in Geneva (no longer live in IL, moved to AZ )
shpitz is offline
post #12513 of 12530 Old 05-22-2016, 08:51 PM
mvcg66b3r's Avatar
Quoted: 90 Post(s)
Liked: 9
Robert Feder is reporting that The CW in Chicago is moving from WGN to WPWR this fall.
Robservations: CW Network losing WGN affiliation, moving to WPWR
In a rare change of network affiliations in Chicago, the CW Network will move this fall from Tribune Media WGN-Channel 9 to Fox-owned WPWR-Channel 50, sources said Sunday. The switch, expected to be announced Monday, will return “Chicago’s Very Own” to a strictly local programming lineup, starting in September. Tribune Media still owns CW affiliates in 12 other markets, including New York and Los Angeles.
Sources said the move to WPWR, low-rated sister station of WFLD-Channel 32, is expected to mean a shift of less than $4 million in local advertising revenue.
http://www.robertfeder.com/2016/05/2...op-cw-network/
James Calvin Woods - Son of Verta Jane Holland
mvcg66b3r is online now
post #12514 of 12530 Old 05-23-2016, 07:47 AM
dishrich's Avatar
Quoted: 50 Post(s)
Liked: 38
WGN in Chicago goes local, WPWR will carry weblet
http://www.broadcastingcable.com/new...network/156733
(not that it really matters all that much) but wondering what's going to happen with MNT programming that's currently on WPWR???
dishrich is offline
post #12515 of 12530 Old 05-23-2016, 08:01 AM
dattier's Avatar
Quoted: 104 Post(s)
Liked: 51
Originally Posted by dishrich View Post
… wondering what's going to happen with MNT programming that's currently on WPWR???
The same question occurred to me when I read Mvcg66b3r's post just before Dishrich's.
WPWR's signal on physical 51 already has what, three two 480i subchannels besides MNT in 720p?.  Even if the CW is cut from WGN's current 1080i to 720p, how well can one physical ATSC channel carry two HD streams plus three two in SD?  Something's gotta give.  WLS doesn't always do so well with two 720p plus one 480i on physical 44.
Last edited by dattier; 05-24-2016 at 08:09 AM. Reason: WPWR has only two SD streams now, not three any more.
dattier is offline
post #12516 of 12530 Old 05-23-2016, 08:30 AM
Trip in VA's Avatar
Quoted: 427 Post(s)
Liked: 119
Send a message via AIM to Trip in VA Send a message via Yahoo to Trip in VA
KCOP in Los Angeles already runs My Network TV at 11PM rather than 8PM. No reason WPWR couldn't do the same.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #12517 of 12530 Old 05-23-2016, 09:45 AM
unclehonkey's Avatar
Quoted: 224 Post(s)
Liked: 41
Since CW programming is technically 3 hours a day during the week (2 a night + that Bill Cunnigham show in the afternoon) they could carry CW from 7-9 local and then My at 9-11, 10-midnight or whenever they want.
unclehonkey is offline
post #12518 of 12530 Old 05-24-2016, 08:05 AM
dattier's Avatar
Quoted: 104 Post(s)
Liked: 51
Yes, thank you both.  [Trip's saying "the same" doesn't adjust for Central Time but UncleHonkey remembered.]  Running CW from 7:00 PM to 9:00 PM and MNT starting at 9:00 or 10:00 would work, and there would be no need to cram a second HD stream into the channel.  We'll still be getting CW in 720p instead of 1080i, but that's minor.
(I erred earlier: WPWR has only two SD streams now.)
dattier is offline
post #12519 of 12530 Old 05-24-2016, 09:50 AM
Quoted: 224 Post(s)
Liked: 41
Looking at the schedule for WPWR I could see them doing My at 11 or even midnight. I'm sure those syndicated shows (big bang, simpsons, mother) that are after My programming still get the viewers.
It would be interesting how they will ID then. I'm sure they ID right now as "My50"...hmmm...MyCW50?
post #12520 of 12530 Old 05-31-2016, 12:00 PM
ludespeedny's Avatar
Quoted: 28 Post(s)
help choosing antenna
I just moved to the area and currently have an antennas direct DB2 antenna. While it pulls a lot of the Chicago stations, I do not receive VHF. Can someone help point me towards a decent inexpensive antenna that could do the job better? I am thinking I am going to have to go yagi style.
here is my report:http://www.tvfool.com/?option=com_wr...e2cb0edd454db3
And I am only really concerned about the major networks (around 38 mi)
ludespeedny is offline
post #12521 of 12530 Old 05-31-2016, 01:30 PM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
There's only one station out of Chicago using VHF which is CBS on 2.1 (real channel 12). I use an MCM Electronics ”Stellar Labs” VHF-Hi yagi with good results.
anikun07 is offline
post #12522 of 12530 Old 05-31-2016, 01:35 PM
Quoted: 28 Post(s)
How far away do you pull stations from? I was actually looking at that antenna from MCM and Parts express. Is this the one you are talking about? http://www.mcmelectronics.com/product/30-2440
post #12523 of 12530 Old 05-31-2016, 01:41 PM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
I ordered antenna 30-2476, I receive signals about 50 south of of the Sears Tower.
anikun07 is offline
post #12524 of 12530 Old 05-31-2016, 01:45 PM
Quoted: 28 Post(s)
Ok, cool! Thanks!
post #12525 of 12530 Old 05-31-2016, 03:32 PM
dicko2's Avatar
Quoted: 17 Post(s)
Is it possible to rotate it to point toward Milwaukee?
WDJT, ch58, should be putting in a pretty good signal to Grayslake.
dicko2 is offline
post #12526 of 12530 Old 05-31-2016, 04:47 PM
Quoted: 28 Post(s)
Yeah, I tried pointing it the other way, but didn't seem to get it.
post #12527 of 12530 Old 08-07-2016, 09:24 AM
Quoted: 28 Post(s)
I am just now looking to pull the trigger and was wondering about these 2:
http://www.parts-express.com/antop-v...tenna--210-512
Are they the same antenna?
post #12528 of 12530 Old 08-11-2016, 02:40 PM
andyross63's Avatar
Quoted: 158 Post(s)
Liked: 49
It looks like WOCK has dropped MundoMax. 13.1 is now just Infomercials.
Need help with your Motorola DVR? Check the Wikibook: How to use a Motorola DVR
andyross63 is offline
post #12529 of 12530 Old 08-20-2016, 02:33 AM
surf_fun85's Avatar
has anyone noticed the picture quality greatly improved on CBS2chicago news ? i think they using new cameras ?
AVS Forum Fold@Home Team Enter Team # 55280 when u download
surf_fun85 is offline
post #12530 of 12530 Old Today, 06:54 PM
OTA_GUY's Avatar
Someone ping wpwr engineers.... 50-2 evertz.com logo
OTA_GUY is online now
