The official final DTV Table Of Allotments/channel change thread - Page 163 - AVS Forum
post #4861 of 7370 Old 09-11-2009, 08:10 PM
iowegian3's Avatar
Channel 2 has NEVER worked on rabbit ears. Was under 20 miles from KTCA 2 in the Twin Cities back in the day. Nothing was more frustrating than trying to pick them up w/ rabbit ears. Outdoor antenna in the garage attic solved that.
Fill-in translators for the outer areas would be a better fix, but let's face it, there's more money for stations getting carriage fees from cable and satellite. OTA is just a legal requirement to be provided as cheaply as possible.
www.therenegaderoadhouse.co Southern rock, pop and country favorites play here!
iowegian3 is offline
post #4862 of 7370 Old 09-11-2009, 09:20 PM
BCF68's Avatar
Well let's see anyone know of any rabbit ears that are over 72 inches( 36 inches on each element )? I don't. Each one would have to be 51 inches each or 102 inches to for Ch 2.
BCF68 is offline
post #4863 of 7370 Old 09-12-2009, 03:56 AM
Stanislav's Avatar
It depends on the market. Because of both geography and economics, a station in a market like Bangor has a high percentage of rural OTA viewers, and ignoring them or marginalizing them would not be wise, especially if your competitors are reaching them effectively. Even if cable/satellite penetration is 80-85% in such a market, I don't think a station like WBRZ can afford to shrug off 15-20% of its viewing audience. It's far more than "just a legal requirement" to many stations.
Stanislav is offline
post #4864 of 7370 Old 09-12-2009, 08:15 AM
BCF68's Avatar
Isn't like 15% of all households are OTA? Now maybe I'm just not smart enough on this topic but since Disney owns ABC wouldn't it behoove them to try to gain that 15% by putting says ABC Family or one of their Disney channels on a subchannel on ABC stations? Sure they're not getting a fee like they would from cable or satellite, but they aren't getting those fees anyways from OTA households. They would be gaining eyeballs which means they can charge higher advertising fees
BCF68 is offline
post #4865 of 7370 Old 09-12-2009, 08:28 AM
Falcon_77's Avatar
I haven't seen rabbit ears that are long enough for 2/3. Most seem to be designed for 5/6 or FM. The ones on the HDTVi are 42" on each side. I've heard of the metal (aluminum foil) ball trick at the end, but haven't tried it and have no need to now.
More comments have been added. I like the one that says we can send signals to (satellites) in space, but not 7.7 miles away. More blood is boiling. There's always watching TV on the Internet...
WLBZ should have known better than to hype up channel 2 at least. "We were assigned 2 by the FCC" would have been less damaging I would think, even if that doesn't really tell the story.
Falcon_77 is offline
post #4866 of 7370 Old 09-12-2009, 08:51 AM
SnellKrell's Avatar
And how do you think cable and satellite providers would react to such actions?
There would not only be outrage, but real threats to cease carriage..
Viewers pay for cable and satellite not just to improve reception, but most outside of urban areas, buy those services to receive "cable" programming.
If such programming were readily available OTA, there would be less of an inducement for viewers to pay those heavy monthly bills.
SnellKrell is offline
post #4867 of 7370 Old 09-12-2009, 08:54 AM
jtbell's Avatar
But then Disney probably wouldn't be able to negotiate as large a carriage fee as they currently get from cable and satellite companies, which would argue that some viewers might leave them for OTA because of it.
(added: SnellKrell beat me to it!)
jtbell is offline
post #4868 of 7370 Old 09-12-2009, 10:11 AM
gbynum's Avatar
I don't know if 300 ohm twinlead is even still made, but a folded dipole as we used for FM would be inexpensive and offer moderate gain. Then a balun to 75 ohms ...
gbynum is offline
post #4869 of 7370 Old 09-12-2009, 02:02 PM
Stanislav's Avatar
Or a quad loop for that matter, cut to whatever channel is desired. I know DXers who were stuck in apartments used to make those for picking up lo-band e-skip. Doesn't have to be fancy -- even just lamp cord can be used, tacked up on a wall facing the general direction of the transmitter. I don't know the actual specs, but I seem to recall it provides a bit more gain over a folded dipole.
post #4870 of 7370 Old 09-12-2009, 06:39 PM
BCF68's Avatar
Who cares how they would react. It's Disney's programing they can do what they want.
Every major cable company and both DirecTv and Dish carry HSN yet in many areas it's available over OTA. Where are the threats? Where is the outrage? for example in Nashville it's available on UHF 24. Yet Comcast still carries it.
I seriously doubt anyone would leave cable or sat because ABC Family would then be available OTA. The carriage fee wouldn't change because for something like ABC Family and similar channels won't practically non-existent anyways.
Anyways it was just an idea.
BCF68 is offline
post #4871 of 7370 Old 09-13-2009, 05:58 AM
spokybob's Avatar
I made one cut for rf4. I can't get a lock at 28 miles. Still no CBS WHBF on the garage tv. I have no trouble receiving the UHF stations using my YouTube antenna.
Bob 61231
spokybob is offline
post #4872 of 7370 Old 09-13-2009, 06:03 AM
SnellKrell's Avatar
Just wondering, is your degree in Broadcast Business or
Broadcast Engineering?
post #4873 of 7370 Old 09-13-2009, 12:32 PM
dline's Avatar
HSN is a different animal. They make their money by people watching, calling in and buying their products directly from them. They're not really cannibalizing anything by having a free signal in some areas. Also, I'm not sure exactly what the arrangements are, but I think whomever carries these shopping channels gets some kind of compensation based on the calls they generate from their area.
Views are strictly my own unless otherwise noted.
"ItÂs looking more like Y2K than the Bay of Pigs." - FCC Commissioner Adelstein, 6-13-09, on the DTV switch
dline is offline
post #4874 of 7370 Old 09-13-2009, 05:06 PM
Desert Hawk's Avatar
According to the FCC's website, some Christian ministry now has an application for a 300 watt low power digital station on channel 2 here in Bakersfield. I wonder if I will be able to receive it. I hope they do build this station, as all this talk about digital on low VHF has me curious.
How can we say "the digital transition is complete" when thousands of low power stations are still broadcasting in analog?
LOW POWER ANALOG NEEDS TO DIE NOW!!!
Desert Hawk is offline
post #4875 of 7370 Old 09-13-2009, 06:09 PM
Stanislav's Avatar
Especially odd as Bakersfield has been an all-UHF market for a long time -- until recently (when KERO moved to 10 for DTV), I doubt many folks there even had VHF antennas, except maybe to pick up out-of-market stations, no?
What many predict will happen when the FCC starts accepting new full-power DTV applications is that some of the now-vacated lo-VHF channels in the bigger markets are going to be highly sought after, by applicants that care little about OTA and just want "must carry" status on cable.
post #4876 of 7370 Old 09-13-2009, 09:04 PM
Trip in VA's Avatar
Quoted: 16 Post(s)
Liked: 55
Send a message via AIM to Trip in VA Send a message via Yahoo to Trip in VA
Another station bails on VHF. WINK in Fort Myers wants to move from 9 to 50. 1000 kW ND.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is offline
post #4877 of 7370 Old 09-13-2009, 09:28 PM
Trip in VA's Avatar
Quoted: 16 Post(s)
Liked: 55
The only interesting FCC filing this evening was a VHF Nightmare. WJHL in Johnson City wants an increase from 25.5 kW to 34.5 kW on channel 11.
- Trip
N4MJC
RabbitEars
post #4878 of 7370 Old 09-14-2009, 01:46 AM
Stanislav's Avatar
Where'd you hear that, Trip? I don't see an FCC entry for this yet. Or is it just scuttlebutt and they haven't actually filed yet?
post #4879 of 7370 Old 09-14-2009, 05:58 AM
Trip in VA's Avatar
Quoted: 16 Post(s)
Liked: 55
I post these things on my Channel Change page as soon as I know about them. But here's the link directly to the FCC PRM: http://fjallfoss.fcc.gov/prod/ecfs/r...ent=7020038318
- Trip
N4MJC
RabbitEars
post #4880 of 7370 Old 09-14-2009, 07:46 AM
mgpt6's Avatar
Ironic, WINK was the last Fort Myers station to go on the air in digital because the FCC gave them UHF and the fought to get VHF9.
mgpt6 is offline
post #4881 of 7370 Old 09-14-2009, 08:14 AM
Falcon_77's Avatar
It sounds like the "must carry" concept needs to be re-thought if stations go to Low-VHF just for cable carriage. No/few actually OTA viewers probably doesn't much if a station can get carriage in markets like NYC, LA and Philly, etc., just because of this rule. Low operating costs and no expectation of a signal from the OTA viewers makes this even more attractive. They will be effectively "virtual" broadcasters. This is already happening in NYC and Philly, due to an old loophole.
This is one of the many reasons 2-6 should have been done away with.
Why some low power stations with no must carry status think they can be successful on 2-6 is beyond me.
post #4882 of 7370 Old 09-14-2009, 09:26 AM
Falcon_77's Avatar
WKYT's request for 36 has advanced to the next step:
AMENDMENT OF SECTION 73.622(I), POST-TRANSITION TABLE OF DTV ALLOTMENTS, TELEVISION BROADCAST STATIONS, LEXINGTON, KENTUCKY. Proposed channel substitution for stations WKYT-TV from channel 13 to 36. (Dkt No. RM-11562 09-163 ). Action by: Chief, Video Division, Media Bureau. Adopted: 09/10/2009 by NPRM. (DA No. 09-2041).
post #4883 of 7370 Old 09-14-2009, 09:37 AM
Trip in VA's Avatar
Quoted: 16 Post(s)
Liked: 55
WINK's original digital assignment was on channel 53, which was deleted by the FCC as of June 12, 2009. They fought to get off of channel 53 so they would not have to build out a facility that would then have to be shut down and thrown away after the transition.
Channel 9 just happened to be an open channel in the area. I imagine they'd have fought to get another UHF if channel 9 had not been available.
- Trip
N4MJC
RabbitEars
post #4884 of 7370 Old 09-14-2009, 09:59 AM
Stanislav's Avatar
Odd that it doesn't show up when I do a search on today's apps. Oh, well...
post #4885 of 7370 Old 09-14-2009, 11:12 AM
TiVoFishMan's Avatar
I find terribly mixed results when I search for PRMs.
The FCC seems to categorize them in some weird way that confuses their search engine.
The same sort of search keywords that will yield success with one PRM, might not with another.
TiVoFishMan is offline
post #4886 of 7370 Old 09-14-2009, 11:34 AM
dline's Avatar
Interesting footnote to this NPRM:
"According to Gray [Television Inc., owner of WKYT], this channel substitution proposal is predicted to result in a loss of service to 36,342 persons located primarily in the mountainous regions of eastern Kentucky ... Gray asserts, however, that due to terrain blockage, the actual loss is reduced to 11,858 persons, and all but 941 of these persons would maintain CBS network service from other CBS network stations ... Gray also states that 'no person located in this loss area was within WKYT's analog Grade B contour,' and given the significant reception problems it has experienced on digital channel 13, it is 'unsure if anyone located in the loss area was ever able to receive WKYT's channel 13 digital signal.' "
dline is offline
post #4887 of 7370 Old 09-14-2009, 11:41 AM
BCF68's Avatar
hey Trip I noticed on the FCC daily digest today it says
DIGITAL TV APPLICATIONS FOR LICENSE TO COVER GRANTED
construction permit no: BMPEDT-20020426AAH,
callsign WLJT.
WEST TENNESSEE PUBLIC TV
COUNCIL, INC
WLJT-DT
71645
TN BLEDT-20080219BJY
construction permit no: BPCDT-20080226ABH,
callsign WBBJ-TV.
TENNESSEE BROADCASTING
PARTNERS
WBBJ-DT
65204
TN BLCDT-20080414ABS
So exactly what exactly did they get permission for and how is that different than what they had going on up until today.
BCF68 is offline
post #4888 of 7370 Old 09-14-2009, 01:41 PM
Dave Loudin's Avatar
The empowering answer is to look up the construction permits cited using the CDBS search utility at http://svartifoss2.fcc.gov/prod/cdbs...d/app_sear.htm
Dave Loudin is offline
post #4889 of 7370 Old 09-14-2009, 01:53 PM
SnellKrell's Avatar
Amen!
The loophole has been found and used. "Marginal" stations have forced cable and satellite companies to provide them carriage when precious bandwidth is at a premium.
Additionally, here in the NY DMA, many of them try to place their facilities on the Empire State Building! Where they're getting the dollars for such a high rent district is beyond me.
The Commission should take notice and do something, fast!
post #4890 of 7370 Old 09-14-2009, 02:09 PM
Trip in VA's Avatar
Quoted: 16 Post(s)
Liked: 55
Go to the ECFS and search for PRM09MB, in all caps, and it's the first result.
Nothing changed. They filed for final licenses way back in 2008 (!) and the FCC is just now getting around to issuing them.
The FCC is not known for its speediness.
- Trip
N4MJC
RabbitEars
User Tag List
