Biloxi, MS - HDTV - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 81 Old 05-01-2012, 07:26 PM
mcrutland's Avatar
Originally Posted by Racer88 View Post
......and the end of the month has now come and gone....not even up in test mode yet...
Lets hope it has something to do with making sure that an HD signal via fiber is provided to D*.
mcrutland is offline
post #62 of 81 Old 05-12-2012, 07:31 AM
jerseyfla's Avatar
WLOX-CBS is now in HD on Cable One but for the ones without cable and getting it OTA it is still in 480i SD. I sent them a message via facebook and they told me to rescan my TVs. I did it 4 times still no dice. I want to email their engineering department but I'm quite sure no one is there on the weekends.
jerseyfla is offline
post #63 of 81 Old 06-02-2012, 10:50 PM
Racer88's Avatar
WLOX CBS is now up in test mode on DIRECTV. SIGH...
As for it ever being HD OTA I wouldn't be expecting that for a very long time, if ever. Not sure of the exact limits off the top of my head, but I'm pretty sure with the way things work now trying to send two HD channels in the current scheme of things would only result in two very crappy HD channels.
Racer88 is offline
post #64 of 81 Old 06-02-2012, 11:06 PM
Racer88's Avatar
Ok after some quick searching each DTV channel is alloted 19 Mbps
A 720p stream (ABC) uses roughly 10-12 Mbps.
A 1080i stream (CBS) uses around 15 Mbps minimum.
Based on that I think you can do the math on the likelyhood of 2 virtual HD channels in one actual channel.
Also some evidence to support this WKRG (CBS) has only ever had one 480i sub-channel. WLOX on the other hand has two 480i sub-channels. 480i uses roughly 4 Mbps.
Racer88 is offline
post #65 of 81 Old 06-02-2012, 11:59 PM
Tom Servo's Avatar
Quoted: 25 Post(s)
WKRG has two 480i subchannels - weather radar and MeTV. It's noticeable in their CBS HD feed, it is very blocky.
Also, some stations DO put on two HD feeds and from what I've been told, examples exist of having two 720p channels and one each of 720 and 1080 together… And yes everyone says it looks horrible as expected.
Tom Servo is offline
post #66 of 81 Old 06-03-2012, 09:47 PM
Racer88's Avatar
Yep, you're right. I hadn't really looked in a while. I do seem to remember them only having the 24/7 radar sub-channel in the past though. But I could be wrong. Not like it's something I've ever checked on anything approaching a regular basis.
Been studying some of the newer technologies that are now allowing DBS to fit 6 HD channels per transponder. So maybe some of that tech will also allow DTV to squeeze more out their alloted bandwidth some day. I guess it pretty much all boils down to what they're able to spend on upgrading their gear to the latest and greatest thing.
Racer88 is offline
post #67 of 81 Old 06-27-2012, 05:24 AM
WLOX's Avatar
To answer a few questions this morning.. Yes, WLOX is airing ABC in 720p on 13.1 and CBS & Bounce in 480i 4:3 on 13.2 & 13.3 Our CBS channel is available in HD on CableOne channel 457 and DirecTV channel 14. We supply an HD signal to Dish, but they still offer the locals here only in SD. We are on channel 14 on Dish. We are feeding U-Verse an HD signal and they should be up with it in a few weeks.
Evidently it is possible to air two HD program streams. WXXV is airing both FOX and NBC in 720p and it looks surprisingly good.
WLOX does not have the bandwidth to do this since we are also airing Bounce on our .3 channel. I do not see this changing in the foreseeable future.
WLOX is offline
post #68 of 81 Old 06-29-2012, 05:08 PM
Racer88's Avatar
The "DTV transtion" should have started with ATSC 2.0 instead of the already outdated 1.0 crap it did start with. I guess as always though they gotta keep people buying new TV's and/or tuners every few years. Gotta sell broadcasters new encoders and what not too. If broadcast TV wasn't nearly 20 years behind in technology, or wasn't holding onto 40-50 year old business practices then maybe they wouldn't be at the so called disadvantage they're at nowadays. Be it a real or not.
Racer88 is offline
post #69 of 81 Old 06-29-2012, 05:11 PM
Racer88's Avatar
On a more on topic note at least WXXV-NBC going live OTA hasn't created the braindead debacle at DirecTV that WLOX-CBS did. At least not so far.
Racer88 is offline
post #70 of 81 Old 06-30-2012, 05:30 PM
WLOX's Avatar
Our microwave link to WXXV, where the DirecTV collection point is located, took longer than anticipated. WXXV didn't have that problem since they are located in the same building..
WLOX is offline
post #71 of 81 Old 07-06-2012, 06:58 AM
Racer88's Avatar
WXXV-NBC is up in test mode on DirecTV now........sigh.....
Soon we get the great pleasure of having two WXXV provided networks with constant resolution and audio sync problems...yay
Racer88 is offline
post #72 of 81 Old 07-08-2012, 07:20 PM
WLOX's Avatar
I apologize for the loss of our WLOX-CBS HD signal on DirecTV. I have been in contact with DirecTV and we trying to determine the source of the problem.
[A Dish Network tech got a little carried away while uninstalling some old equipment and disconnected ours as well. We are back up now]
WLOX is offline
post #73 of 81 Old 07-12-2012, 02:25 PM
rtd2's Avatar
WXXV -nbc 25-2 is now uplinked to dish on ch 6 ....I'll continue to use antenna and watch NBC 25-2 in HD (Unlike Wlox-Cbs ) until dish launches our market in HD.
rtd2 is offline
post #74 of 81 Old 07-18-2012, 09:49 PM
Racer88's Avatar
WXXV-NBC's craptastic SD feed is live on DirecTV now. So wonderful having a quality HD feed removed to be replaced with this crap...mad.gif
Racer88 is offline
post #75 of 81 Old 07-19-2012, 10:12 AM
Racer88's Avatar
...and now I've found out that WXXV is sending DirecTV a HD feed for NBC, but it is DirecTV that has chosen to retransmit that feed in SD mad.gifmad.gifmad.gif
Racer88 is offline
post #76 of 81 Old 02-06-2013, 02:29 AM
Racer88's Avatar
So what's the excuse now for nearly 2 weeks(that I've noticed) of WLOX CBS in glorious SD??? mad.gif
Racer88 is offline
post #77 of 81 Old 04-03-2013, 12:35 AM
Racer88's Avatar
Ok, now why are the Biloxi/Gulfport locals having "technical difficulties" every night this week? (13, 14, 25 and 26)
(not that I expect an answer given your lack of response to the previous question)
Racer88 is offline
post #78 of 81 Old 04-03-2013, 12:38 AM
Tom Servo's Avatar
Quoted: 25 Post(s)
Who are you expecting an answer from?
What technical difficulties are the stations suffering from, and is it on DirecTV only or off the air?
post #79 of 81 Old 05-30-2013, 12:57 AM
Richard Lewis's Avatar
I understand that WXXV-TV is going to start some newscasts this fall. The story is at:
http://www.sunherald.com/2013/05/25/4690872/wxxv-tv-in-south-mississippi-will.html
Richard Lewis is offline
post #80 of 81 Old 12-12-2016, 01:14 PM
donebu's Avatar
Quoted: 12 Post(s)
Liked: 25
From Mississippi Public Broadcasting:
This is an important message for all MPB “Over the Air” viewers. You know, those of us who use an antenna to receive #MPBTV.
As you probably know, there are different channel numbers for each of our eight towers around the state. After each of these channel numbers there are sub-channels: dot one, dot two, dot three, and dot four.
On Monday, December 12, our dot one and dot two channels will change. MPB HD will move to dot one. A brand new 24/7 children’s channel, “PBS KIDS,” will premiere soon on dot two. Sub-channels dot three and dot four will continue to carry Create TV channel and MPB Music or Think Radio, just as before. The change should not require any action on your part. However, if there is a problem, you may need to use a digital tuner to rescan for these channels to appear.
Cable and satellite viewers should not be affected. For more information, visit: mpbonline.org/channelchange.
Not sure why MPB didn't do this with the digital transition. Really didn't make sense to continue broadcasting a standard-definition signal on their .1 sub-channel.
donebu is offline
post #81 of 81 Old 12-12-2016, 03:56 PM
Tom Servo's Avatar
Quoted: 25 Post(s)
I figured they did it to maintain some sort of compatibility with cable companies that did not carry the HD feed. It never did make sense to me, though, since it seems most SD channels these days are just center-punched or letterboxed versions of the HD channel.
