Has anyone here got their Xbox Succesfully into 1080i Mode? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-17-2001, 03:36 AM - Thread Starter
thecurt's Avatar
In the Xbox menu's it says 1080i...yes or no.. when I select yes
And plug it into my lovely 1080i Jacks...
I get weird scanning
From what I gather.. Nearly everyone Else having this happen too (on othe video game only boards)
you guys being the smartest of the smart...when it comes to HD...
I was wondering.. have any of you?
And if you did... whats the trick (because Damnit...there is definately something freaky going on here)
thecurt is offline
post #2 of 9 Old 11-17-2001, 03:28 PM
fcnelson's Avatar
Are you using the Xbox High Definition AV Pack? I imagine it is necessary to get 1080i.
fcnelson is offline
post #3 of 9 Old 11-18-2001, 11:10 AM
hidenesha's Avatar
I hooked up the xbox using the same cable/input as I use for my hd receive (Dish 6000) and the xbox worked fine. I don't think the games downconvert to 480i because I couldn't really tell any difference than the component input - both looked great!
hidenesha is offline
post #4 of 9 Old 11-21-2001, 05:09 AM
Cableman's Avatar
I think games have to support 1080i for it to work. As far as I know, no games support 1080i right now.
Cableman is offline
post #5 of 9 Old 11-21-2001, 08:35 AM - Thread Starter
thecurt's Avatar
Yeah I've heard that
but you wold think that you would atleast be able to get into the Xbox menu in 1080i...if it supports it
when I plug it in
all I get is weird green scanning
thecurt is offline
post #6 of 9 Old 11-21-2001, 06:34 PM
Trevor L's Avatar
the dashboard is 480i only. i have no idea why but thats the way it is.
the games should work fine thought.
Trevor
Trevor L is offline
post #7 of 9 Old 11-22-2001, 10:22 AM
hk29's Avatar
So games don't upscale to 1080i?
hk29 is offline
post #8 of 9 Old 11-22-2001, 09:25 PM
nikon's Avatar
How can you get 1080i from a Xbox, and can you get the DVD pack to give you 1080i also.
nikon is offline
post #9 of 9 Old 11-23-2001, 11:12 AM
Cableman's Avatar
Think of it like a GIF or Jpeg picture. If it's a 50 by 50 image and you make it 100 by 100, it's going to look bad. The information has to be in the source to make it 1080i. If the source is 480i, then there's not enough information to make it bigger. Same thing goes for DVD. They're in NTSC (or PAL as the case may be) and they can't be turned into 1080i. I suppose they're could be some way to, but the result would look bad.
Cableman is offline
Closed Thread Local HDTV Info and Reception
