X-box and 5.1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-08-2001, 02:42 PM - Thread Starter
Ted
Ted's Avatar
Can anyone tell me how to get Halo to play in DD5.1 I have the Advanced AV kit with the optical Cable hooked to my AMP, but it plays in Prolodgic.
I tried here with no luck....
http://www.avsforum.com/avs-vb/showt...threadid=98071
HELP?!??
Ted is offline
post #2 of 7 Old 12-09-2001, 05:29 AM
Maggie Guy's Avatar
Did you go into the main menu of the xbox and enable Dolby Digital and DTS?
Alpha LS Guy
Formerly known as Maggie Guy
Maggie Guy is offline
post #3 of 7 Old 12-09-2001, 10:58 AM - Thread Starter
Ted
Ted's Avatar
I think that may be part of my problem. I powered on my Xbox with no game in it, went into the settings, then audio and the only selections I had were mono, stereo, and dolby surround. I cannot find a selection for DTS or Dolby 5.1 anywhere in the menus. Can you please tell me where you found your setting?
Ted is offline
post #4 of 7 Old 12-10-2001, 04:14 PM
Macondawg's Avatar
I think that the "dashboard" in the X-Box is never in Dolby 5.1. Mine does not process the signal until after I insert the game. By the way, Halo is pretty cool in 5.1. Good luck.
Macondawg is offline
post #5 of 7 Old 12-16-2001, 07:53 AM
joekun's Avatar
I have the High Def AV kit, but when I went in to the dashboard I saw the options for DD and DTS.
If I were you I would check the connections (unplug and replug everything). Make sure the digital input is set to the corresponding button on your receiver (if that's necessary, it is on mine) and try it again. If that doesn't work and you have a spare optical cable try swapping them out. Finally, if that doesn't work either call Microsoft's support line or take the AV pack back to the store and swap it out as it's probably defective.
joekun is offline
post #6 of 7 Old 01-25-2002, 08:20 AM
IO Error's Avatar
Can you give me some more information about this Advanced AV kit!? I gotta have it.
Thx.
IO Error
A wise man once told me, "You can have ANYTHING you want in life. You just can't have EVERYTHING you want."
I say, "Pah! He who dies with the most toys wins!"
IO Error is offline
post #7 of 7 Old 01-25-2002, 04:12 PM
ragedogg69's Avatar
Here is a link to the Advance AV pack:
http://www.xbox.com/system/Advanced+...talog=cat%2Dus
I have the HD pack and love it. I have no problem with it and I even got the extended warrenty on it. Those damn Sears salesmen.;)
My DVD Collection
GO CHIEFS, WILDCATS, SUNS, DIAMONDBACKS, COYOTES, RATTLERS, AND LUMBERJACKS!
"Asking if an HDTV is too big, is like me asking you if the diamond on your wedding ring is too big." -- My dad's response to my mom's question about my 65" HDTV.
ragedogg69 is offline
Closed Thread Local HDTV Info and Reception
