Columbia, SC - HDTV - Page 31 - AVS Forum | Home Theater Discussions And Reviews
post #901 of 10089 Old 07-25-2003, 06:37 AM - Thread Starter
bdenman's Avatar
- CBS/WLTX-DT fixed their HD pass through problems though PSIP may now be problematic (17 was not remapping to 19 last night).
- FOX/WACH-DT is back on the air. Initially they had exciter problems, but all was well last night.
- ABC/WOLO-DT has been fine; cranking right along.
- NBC/WIS-DT seems to be working okay too.
- ETV/WRLK-DT No video problems but I continue to experience numerous digital audio dropouts on both OTA 35.3 and TWC Ch 800; analog audio seems okay > . Also, PBS's Soundstage last night came in Digital 2.0; ptvdigital.org lists it as DD5.1, while others reported receiving DD5.1. I have been told SCETV can pass along DD5.1 but I cannot recall having seen it.
Bruce
Bruce
Latest Summary on COLUMBIA SC HDTV can be found here.
bdenman is offline
post #902 of 10089 Old 07-25-2003, 03:42 PM
kevinivey's Avatar
Bruce,
Read in another thread that Soundstage has had problems with 5.1, and next week will be 5.1 and the next ten.
kevinivey is offline
post #903 of 10089 Old 07-25-2003, 04:07 PM - Thread Starter
bdenman's Avatar
Kevin,
Thanks for the info; I missed that tidbit about the latest Soundstage. I knew some of the early ones were just 2.0 but thought they were behind us.
By the way, can you (or anyone) tell me if you/they have you been having audio problems with WRLK (OTA or TWC)? I am curious if by some chance it might somehow be my equipment? Though I don't recall having had problems with DD5.1 on WOLO, perhaps it something in the WRLK stream that is different and causing drop out problems. Perhaps signal strength? Anyway, TIA...
Bruce
made a late evening update that was in error; sorry.
Bruce
bdenman is offline
post #904 of 10089 Old 07-25-2003, 10:17 PM
TechMan's Avatar
I know WOLO-DT has DD5.1 almost all the time. I would love to read a report back from all the engineers about what their equipment can do. Can you or can't you pass the signal, and what shows they know they are sending the DD5.1 sound on now or in the coming fall season?
TechMan is offline
post #905 of 10089 Old 07-26-2003, 08:27 AM
sbennett's Avatar
Our encoder is set to pass 5.1 audio when present. The output of the encoder is monitored with a Wohler multi-channel audio decoder.
-Shaun
Shaun Bennett
Engineering, SCETV
sbennett is offline
post #906 of 10089 Old 07-26-2003, 08:42 AM - Thread Starter
bdenman's Avatar
Shaun,
I take it then that you all have been monitoring your digital signal and all has been well at your end?
Bruce
Bruce
bdenman is offline
post #907 of 10089 Old 07-26-2003, 08:56 AM
sbennett's Avatar
Bruce,
Looking at the signal out of the encoder and OTA at our tech center in Columbia I have not heard the audio problems that you are having. If you are taking the audio drop-outs now, I can have our master control operator monitor the signal to see if we can reproduce the problem. If you want, email me your phone number and we can talk off-line about the problem.
-Shaun (sbennett@scetv.org)
Shaun Bennett
Engineering, SCETV
sbennett is offline
post #908 of 10089 Old 07-26-2003, 09:09 AM - Thread Starter
bdenman's Avatar
Shaun,
Thanks for the offer but.... of course .... it is working perfectly right now (both OTA and on TWC). Hopefully it will stay that way.
Bruce
Bruce
bdenman is offline
post #909 of 10089 Old 07-26-2003, 09:17 AM - Thread Starter
bdenman's Avatar
Shaun,
At 12:12 (portion of the NJ loop) it sputtered several times on TWC; switched over to OTA and so far nothing.
Now I am using a mechanical switch in the system which could be part of the problem but note it does not seem to affect my audio from other channels. Got me....
Bruce
ps: I just removed the switch to see if that helps. And if that does not make a difference I will ty a different cable.
Bruce
bdenman is offline
post #910 of 10089 Old 07-26-2003, 09:31 AM
sbennett's Avatar
Bruce,
MC operators will monitor the signal OTA in Columbia throughout the day. Unfortunately, I have no way to monitor TWC at this time. TWC is fed off a RF tap (RF to fiber) at the transmitter so we should see the hits OTA and on cable at the same time if we have a problem in the system.
On a side note: We might need to lower power on the transmitter next week while we are doing some antenna work. This could effect you in Sumter.
-Shaun
Shaun Bennett
Engineering, SCETV
sbennett is offline
post #911 of 10089 Old 07-26-2003, 09:40 AM - Thread Starter
bdenman's Avatar
Shaun,
Thanks for your attention to my problem. I will check both TWC and the OTA signal from time to time today to see how the audio is. (I have gone ahead and replaced my cable with another (hopefully better) and my connection is now direct (when necessary, I will manually move the cable between the two STBs). Since no one else is complaining about dropouts, I am wondering if perhaps somehow your audio signal's strength is just a tad lower than others (say ABC) which in turn is problematic with my particular receiver. Again, thanks for your help.
Bruce
Bruce
bdenman is offline
post #912 of 10089 Old 07-26-2003, 12:50 PM
jerry birdwell's Avatar
Shaun:
As advised elsewhere yesterday, I have problems with 29-3. Continuous pixelization, somewhat in sync with audio! No problems with 29-1&2. The problem continues today.
Anyone else receiving 29-3 having the same problem?
jb
JB - Asheville
jerry birdwell is offline
post #913 of 10089 Old 07-27-2003, 08:00 AM
ALL: (Unusual RF activity):
A retired Chief Engineer for TV (now living in Arden NC) who listens to the SC (Greenville area) PBS FM station advised this morning he has had problems with the Atlanta Station overriding the local signal for the past couple of days. (Both on same frequency).
Since Friday, I have had many unusual problems with my DT reception. Channel 9DT (29-x) has suddenly been very unstable. I have all but lost 33-x channels from Pisgah; 13-1,2 are very unstable.)
Are we experiencing unusual Sun Spot activity? Anyone check out SD for unusual hops and co-channel interference?
jb
JB - Asheville
post #914 of 10089 Old 07-28-2003, 05:18 AM
Re: WUNF Test (& UNCTV)
Wayne Estabrooks advises:
"Today at approximately 1 PM we will be running some HD to test the encoder
switching capability between HD and SD configuration and to test the
entire system. We will be doing this on all 11 transmitters. I'm not sure
what the program content will be during this brief test. It will be the
first time for HD content over WUNF-DT 33 although we have broadcast HD
previously on the other stations. I hope there are no surprises."
jb
JB - Asheville
post #915 of 10089 Old 07-28-2003, 12:57 PM
kevinivey's Avatar
jb
post #916 of 10089 Old 07-28-2003, 01:16 PM - Thread Starter
bdenman's Avatar
Kevin,
I believe Mr Birdwell is providing comments here directed to those folks who are in the northern and western parts of SC who can get the NC broadcasts. These are folks who can also receive the Cola broadcasts and don't necessarily follow the western SC thread. He may be referencing part of NC's ETV network and its various DT transmitters (or possibly one station who have a bunch of low-power repeaters).
Our own network from SCETV has a number of stations with transmitters as well; only a couple of which are now on the air. Cola is of course as is Rock Hill but Sumter is not nor is Charleston, Florence/MB, etc. Sounds like the NC folks are going to test everything at once.
Bruce
Bruce
bdenman is offline
post #917 of 10089 Old 07-28-2003, 02:38 PM
All:
I don't mean to cause confusion, but Bruce is correct...I have found some of you go for Mt. Pisgah stations and there is nothing more confusing than to look for a signal and find it has changed because of something going on at the station. I will limit my duplication of information on this thread...and try to make sure I don't misslead you. My primary PBS station is WNTV-DD9in Greenville (because of signal strength), and it is nice for me to get information regarding SCETV from this forum! Thanks
jb
JB - Asheville
post #918 of 10089 Old 07-29-2003, 08:40 AM - Thread Starter
bdenman's Avatar
Broadcasting Engineering today has an article that discusses our UPN/WB/PAX affiliate WQHB Ch 63 (DT38) DTV's transition.
"WBHQ, an UPN/PAX/WB affiliate in Sumter, S.C., has bought a SignaCast Lite DTV system for its DTV transition.... WBHQ's SignaCast system is slated for pre-build at SignaSys' San Jose, Calif., headquarters for a mid-August delivery date."
Note that WQHB's tower is now physically sited in the Cola area vice Sumter and that the article has the station's call letters badly transposed. Bottom line is the station we have heard virtually nothing from appears to be making progress towards DT capability. This article delineated the fact that they are buying a system (turnkey basically) that will provide such capabilities as PSIP and Closed Captioning and is also capable of passing HD as well. What remains to be seen is what their future affiliation will be ... WB only or WB/UPN/PAX.
Bruce
Bruce
bdenman is offline
post #919 of 10089 Old 07-29-2003, 07:18 PM
kevinivey's Avatar
15 seconds of widescreen NYPD Blues , and now 4x3.
post #920 of 10089 Old 07-30-2003, 11:01 AM
kevinivey's Avatar
Hello Mr. Ivey:
Time Warner Cable has not set a timetable for the addition of any additional HD channels. It is our intention to carry the HD signal for all broadcasters that are available in our area. Thank you for your patience in this matter.
Thank you for using The Online Customer Service
4th time,same message! (I still e-mail them everyday)
post #921 of 10089 Old 07-31-2003, 07:37 PM
kevinivey's Avatar
Today's email response from TWC, I forwarded them a Comcast announcement of ESPN-HD being added.
Hello Mr. Ivey:
We appreciate the information you provided to us in your email. We have not
been given authorization to carry ESPN HD at this point. All of us at Time
Warner Cable are excited about the development of HDTV and will launch new
channels as soon as we can.
post #922 of 10089 Old 08-06-2003, 07:08 AM
IrmoGamecoq's Avatar
Anybody catch the HD broadcast of Monday Night Football?
I tuned expecting my first glimpse of HD NFL and was utterly bummed to see Al Michaels and John Madden in non-glorious 4x3 SD.
About 15 minutes into the show, there was a short blurb where Al Michaels made the comment that "this broadcast, as are all MNF broadcasts, is being showing in HDTV...blah, blah, blah." There was also a little "HDTV" graphic displayed in the bottom left corner of the screen.
A few seconds later, the screen pixelized a little and lo and behold, we had 16x9 HDTV!
I told my wife that the folks down at WOLO must've just remembered to "flip the switch."
Is that what happened, in fact?
IrmoGamecoq is offline
post #923 of 10089 Old 08-06-2003, 07:27 AM
tritchie's Avatar
Can someone help me with this please. I have to move in with a friend while I'm having my house rebuilt. I'm currently on Directv which I will miss terribly if I give it up. My friend is on TW cable. What HD channel do they offer right now including locals? And do they broadcast Fox widescreen when available?
Thanks for help in advance!
tritchie is offline
post #924 of 10089 Old 08-06-2003, 07:32 AM
bdfox18doe's Avatar
Quoted: 242 Post(s)
Liked: 141
No, As has been mentioned in other areas of this forum ABC had technical problems with the feed. The problem was corrected at approximately 8:16pm by ABC NY.
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
post #925 of 10089 Old 08-06-2003, 10:45 AM
bdfox18doe's Avatar
Quoted: 242 Post(s)
Liked: 141
We have made some software and transport changes to WOLO's signal
today. If you see any problems with WOLO-DT, please let us know.
Bob
post #926 of 10089 Old 08-06-2003, 02:46 PM
kevinivey's Avatar
ch800-PBS-HD
ch810-CBS-HD
ch815-ABC-HD
ch845-Discovery HD
ch901-HBO-HD east
ch902-HBO-HD west
ch921-SHO-HD east
ch922-SHO-HD west
No NBC or Fox. My guess is the 2004 Olympics will force Wis to allow TWC to pass their signal. Notice that I do not blame TWC for their lack of carriage. I believe that Wis is the lone hold up in this lack of carriage. Fox has never responded to my e-mail request and I have never asked TWC about Fox.
post #927 of 10089 Old 08-07-2003, 05:46 AM
tritchie's Avatar
Thanks Kevin! Do you have any idea when ESPN might be available with TWC. Needless to say, I wouldn't have a big deal watching TWC for a few months, but being a huge football fan, I need all the HD I can get.
Trip
tritchie is offline
post #928 of 10089 Old 08-07-2003, 10:09 AM
Thanks for the followup. It seemed entirely too coincidental with the timing of Michaels' comment to be an accident, but I guess it was just that afterall.
post #929 of 10089 Old 08-07-2003, 10:01 PM
bellvg's Avatar
what's the problem with the audio on wis dt?
bellvg is offline
post #930 of 10089 Old 08-07-2003, 10:55 PM
TechMan's Avatar
WIS HDTV 41.1 - No Sound (ER,Leno)
WLTX HDTV 19.1 - Popping Audio (Y&R,Without A Trace)
Everybody Else is Runing A Clean Machine
TechMan is offline
