KEF T305 vs Paradigm MilleniaOne vs MartinLogan Motion 4 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-20-2012, 10:17 PM - Thread Starter
elenovi2012's Avatar
Hello,
I am novice to AV stuff. I am shopping for a home theater and need your guidance.
What would you recommend based on below options?
Speaker System:
1) Paradigm MilleniaOne 5.1
a) Paradigm MilleniaSub (gets too expensive and may not opt for it) ($2500)
b) Martin Logan Dynamo 700 Subwoofer ($1700)
c) Paradigm UltraCube 10 ($1950)
2) KEF T305 ($1500 - Based on the Sale)
3) Martin Logan Motion 4 (L, R, Rear); Martin Logan Motion 8 (Center), Martin Logan Dynamo 700 SubWoofer ($1750)
Is it even a good idea to combine Paradigm speakers and ML Sub? Does Paradigm Millenia speakers; ML Motion 4; KEF T301 speakers even comparable on the quality; performance etc?
Receivers to go with any of the above speaker :
1) Integra 30.4 (Anywhere between $800 to $900)
2) Denon AVR-3313CI ($800 to $900)
3) Onkyo TR-NX717
Projector:
EPSON Homecinema 3010e
Appreciate your inputs and suggestions.
elenovi2012 is offline
post #2 of 4 Old 07-11-2013, 05:18 PM
samitk's Avatar
What did u end up getting - I am in similar situation with similar options - hence wondering
samitk is offline
post #3 of 4 Old 07-11-2013, 06:34 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
This forum is just for Testing how to use the posting tools, etc. not for tech. discussions or help from a wide user base. Posts here aren't even added to your total post count.
The original poster (OP) posted 8 months ago and found his answer here from other users.
wajo is offline
post #4 of 4 Old 07-12-2013, 06:14 PM - Thread Starter
i went ahead and bought KEF KHT3005SE from accessory4less.com. You can search for the same subject in the Speakers section to get more details
Reply Post Testing Area
