insert xls or pdf file - AVS Forum | Home Theater Discussions And Reviews
Old 03-02-2013, 01:37 PM - Thread Starter
videobruce's Avatar
Quoted: 607 Post(s)
Liked: 247
Make BriteView Channel Master CM/Entone Digital Stream DVICO TViX ePVision Moxi TiVo test test test test test
Model BVT-980H CM7000/DTVPal CM7400/458 DPH1000R M6620N PHD-VRX HD MR1500T3 S3/HD/Premiere/P4
Cost new $165.00 $320.00 $380.00 $230.00 $300.00 $230.00 $500 / $600 -/-/ $100 & up
used/open box   $220.00 $260.00 OB $190     Mate $120 S3-$330/P-$480
authors rating * *** ** / ** ** *** *** **** ****
Hardware:
Tuner types; ATSC, QAM, NTSC 1 ATSC/QAM 2 ATSC 2 ATSC/QAM 2 All 2 ATSC/QAM 2 All 2 or 3 QAM All except Prem4
Combined analog & digital tuners --- --- --- Separate --- Yes --- Combined
RF inputs One One One One One Two One Two except Prem4
HD Video outputs: HDMI / Component HDMI Both Both Both HDMI HDMI Both Both
HD Audio outputs: Optical / Coaxial None Optical Optical Optical Both Optical Both Optical
Front panel display type text or LED's LED LED Clock & LED Led Full Text Text & LED LED LED
Front panel functions; transport and/or menu None None Menu Menu Menu & PB Menu & Ch. Menu S3 Text/LED/LED
Power consumption; operating & standby 9 \ 1 23/21 24/ ? ? 1/ ? 22 w/HD/15/2 26/Mate 10 S3-34/ S4-26
HDD: internal stock/maximum external size 320G / No 250G / No 320G / Yes 320G / Yes None / 2TB None / 2TB 500G / 6TB 250/160/320 - 1TB
HDD spins down in standby Yes No No? Yes Yes Yes No standby No standby
External record: HDD/Memory stick Stick None Both Both Both Both Yes / No Yes / No
Low power standby Yes No No Yes Yes Yes --- ---
Boot time from standby 30 sec --- --- 30 sec 30 sec 30 sec --- ---
HDD file system (format) NTFS DFS – Proprietary EXT3 NTFS ? NTFS EXT2 Linux ? MFS – Proprietary
Tuners setup:
Separate OTA & CATV channel scans No --- No No No Yes No scan No
Add channels not in the original scan Yes ? ? ? Yes ? No Yes --- Yes w/ 2nd scan
Add individual channels via physical numbers No No ? Yes ? Yes, no sub ch Yes No No
M Cable Card support No No No No No No Yes Yes
Edit channel names and/or call letters No No Yes Analog ? No Call letters No No
Ability to re-map QAM channels No --- No No No No Yes No
Signal strength indicator No Yes Yes Yes Yes Yes Yes Yes
Skips encrypted QAM channels ? --- ? ? ? Yes Yes via CC Yes
Skip channels. in Guide that are in ch. List ? No ? ? ? ? No ? S3-No / S4–Yes
Program Guide & Recording:
Program guide; PSIP and/or Pay (full) PSIP PSIP Both PSIP dig. only PSIP PSIP Full Pay only test test test test test
Fully usable without additional fees Yes Yes Yes Yes Yes Yes Register DVR No
Number of days of programming Varies Varies Varies / 14 Varies Up to 1 Varies 14 7
Grid type of guide No Yes Yes No No No Yes Yes
Combined or separate guide for all tuners --- Combined Combined Combined Combined Separate Combined Combined
12 or 24 hr clock 24 hr 12 hr 12 or 24 hr 24 hr 12 or 24 hr 12 hr 12 hr 12 hr
Time setting; auto and/or manual & source Manual Both / PSIP Both / PSIP Both / PSIP PSIP/NTP NTP/PSIP/Man Auto/NTP Auto/NTP
QAM channels listings w/o using a CC Varies w/MSO --- Yes w/sub. Varies w/MSO Varies w/MSO Varies w/MSO Yes No !!
Jump fwd & back in Guide No 1-8 days 6 & 24 hrs No ? ? Page up/down 24 hrs Not in Grid view
Guide search by program names No Yes Yes No No No Yes Yes
Save program searches No Yes Yes --- --- --- Yes Yes
Manual recording VCR style Yes Yes Yes Yes Yes Yes Yes Yes
Protect recordings from deletion No ? No Yes ? Yes Yes Yes Yes
Record only new episodes No No Yes No No No Yes Yes
Name and/or time based recordings Time Time Name (pd G) Time Time Time Name Name
Auto adjusts for changing days or start times No No No ? No No No Yes Yes
Recording conflicts action; auto or manual No Manual Manual Manual Manual Manual Manual ? Auto
Auto pad recordings start & end in Guide No No No Indirectly No No No Yes
Number of programs recorded at once One Two Two One Two Two Two or Three 2 / 2 / 2 / 4
Record indicators of future programs ? Yes Yes From the guide Yes Yes in Rec list Yes No
Available HDD space shown ? Yes Yes Yes Yes Yes Yes No/No/Yes/Yes
Adjustable buffer time amount No No No ? No buffer Yes Up to four hrs No No
Closed Caption available in playback No Yes Yes No No Yes Yes Yes ?
Playback & Misc:
Dedicated play & stop & standby buttons Yes Yes Yes Yes No play /stop Yes Yes No stop or StBy
Remembers where playback left off Yes Yes Yes Yes Yes Yes Yes Yes
Skip ahead or back time amounts None Both; 30 sec Fwd; 30 sec None Both: 15 sec Both to 2 min Fwd variable Fwd 30 sec hack
Edit recorded program name ? No? ? Yes Yes No No No
Recordings encrypted within HDD No Yes Yes No No No Yes Yes
Record history showing errors Shows failed No ? Yes No Yes (limited) No ? Yes
PC / USB file transfer ability No / Yes No / No No / Yes No / Yes Yes / Yes Yes / Yes Yes / No Yes / No
Media Player No No Yes Yes Yes Yes Yes Yes
Create playlists for external media --- --- Yes No Yes No No No
Ethernet: wired/wireless No No Both No Both Wired Wired Both
Internet services available --- --- Vulu --- None U Tube Numerous Numerous
Multiple room recording and/or viewing --- --- No --- Yes No Yes w/Mate Yes w/extender
Firmware upgrade; Internet and/or USB USB Both Both None available Internet USB Internet Internet
Available support; on-line and/or telephone None Limited Limited/None Very Limited Very limited Limited Both Both – Good
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
Old 03-03-2013, 01:27 AM
Aleron Ives's Avatar
Quoted: 1593 Post(s)
Liked: 1303
Update 1
HD DVR Comparison condensed.xls 19k .xls file
Aleron Ives is offline
Old 03-03-2013, 01:20 PM
acaoacao's Avatar
Moxi portions update HD DVR Comparison condensed.xls 34k .xls file
acaoacao is offline
Old 03-21-2013, 10:31 AM - Thread Starter
videobruce's Avatar
Quoted: 607 Post(s)
Liked: 247
reserved
