Air-conditioning Fan Motor not running ? ? ? ? - AVS Forum | Home Theater Discussions And Reviews
Old 07-01-2013, 10:40 AM - Thread Starter
See The Light's Avatar
Quoted: 45 Post(s)
Liked: 59
My Air-Conditioning Fan Motor outside stopped running.
Capacitors eventually go bad. I think the last time I replaced it was in 2008. So I got about 5 years service out of it.
It's easy to replace. Just turn the power off, or cut the power at the breaker, before removing and testing the current capacitor.
They're not that expensive, usually under $40.... which is way less expensive than a Service Call !!
Cable Channel Choice is the only choice I want to make !!
See The Light is offline
