WYSIWYG NOT! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-29-2013, 02:19 PM - Thread Starter
SFischer1's Avatar
Quoted: 484 Post(s)
Liked: 60
HI,
SCANNING: 473000000 (us-bcast:14)
LOCK: 8vsb (ss=75 snq=58 seq=100)
TSID: 0x00FF
PROGRAM 1: 42.1 KTNC-SF
PROGRAM 2: 42.2 KTNC-SA
PROGRAM 3: 42.3 This TV
PROGRAM 4: 42.4 RTV
The above is what I want to paste and have it look like the above which is what it appears like in other editors.
Instead this is what I get with Ctrl-V, or using "Paste as plane text" or "Paste from Word".
~SCANNING: 473000000 (us-bcast:14) LOCK: 8vsb (ss=75 snq=58 seq=100) TSID: 0x00FF PROGRAM 1: 42.1 KTNC-SF PROGRAM 2: 42.2 KTNC-SA PROGRAM 3: 42.3 This TV PROGRAM 4: 42.4 RTV
The carriage returns are being stripped out.
And Color, size and many other icons in the WYSIWYG editor do  not work!
Will this all be fixed soon, or an explanation of how to use it improved added?
SHF
SFischer1 is offline
post #2 of 4 Old 11-29-2013, 04:10 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
Your table copied and pasted from your post, using Rich Text Editor with Firefox 25.0.1.
TSID: 0x00FF
PROGRAM 4: 42.4 RTV
Your post copied and pasted in Microsoft Notepad, then copied from Notepad to this post.
TSID: 0x00FF
PROGRAM 4: 42.4 RTV
P.S. You posted in a forum used only for testing posting functions and procedures. Normally, no one would answer you in this forum. Use the Forum Operations forum for stuff like this.
wajo is offline
post #3 of 4 Old 11-29-2013, 04:26 PM - Thread Starter
SFischer1's Avatar
Quoted: 484 Post(s)
Liked: 60
TSID: 0x00FF
PROGRAM 4: 42.4 RTV
TSID: 0x00FF
PROGRAM 4: 42.4 RTV
Hi,
Yes I did not expect an answer, but thanks for confirming what I suspect.
AVS hates Internet Explorer 11, and perhaps Internet Explorer 10 as I saw a post about problems with it also.
~~SCANNING: 473000000 (us-bcast:14) LOCK: 8vsb (ss=75 snq=58 seq=100) TSID: 0x00FF PROGRAM 1: 42.1 KTNC-SF PROGRAM 2: 42.2 KTNC-SA PROGRAM 3: 42.3 This TV PROGRAM 4: 42.4 RTV
I just highlighted the text above in the quote and pressed Ctrl-C to copy and then Ctrl-V to past it again.
There has been more and more things not working that did in the past.
Maybe it is a setting somewhere that changed with IE11 that was installed a few weeks ago on my W7 Laptop.
I will keep looking, maybe someone will see this and have an answer.
Thanks for stopping by.
SHF
post #4 of 4 Old 11-29-2013, 06:00 PM - Thread Starter
SFischer1's Avatar
Quoted: 484 Post(s)
Liked: 60
Hi,
It's out of AVS's hands, the editor is no good for IE 11 that they are using.
Fix is in the works, 4.3 appears the version needed.
http://ckeditor.com/blog/CKEditor-Weekly-for-November-25-2013
SHF
Reply Post Testing Area
