Test attachments - AVS Forum | Home Theater Discussions And Reviews
Old 06-12-2014, 08:06 AM - Thread Starter
Administrator
Administrator
VerticalScope's Avatar
Quoted: 473 Post(s)
Liked: 138
Test attachments
Testing an attachment...
VerticalScope is offline
Old 06-12-2014, 05:21 PM
granroth's Avatar
Quoted: 664 Post(s)
Liked: 446
Okay, lets's try uploading a picture or two.
Step one, click on the paperclip. A 'Manage Attachments' dialog pops up with a bunch of 'Choose File' buttons. I'm seeing a bunch of incredibly tiny max filesizes, though... let's see how that goes. Also, does drag n' drop work? Nope. Need to click on the button.
I choose a 2.6MB jpeg of 3264 x 2448, both of which are out of bounds of the max filesize. The upload succeeds and it says my current attachment is 'IMG_5422.jpg (226.3KB)'
I click on 'Close this window' in the upload window. I also see my file in the 'Attach Files' section under this editing window.
Is there a way to preview this edit? Maybe clicking 'GO ADVANCED'. Yep, using the Advanced dialog does give me the opportunity to preview it. I see my picture as an teeny-tiny attachment thumbnail.
Step two, let's try to convert that to a full IMG. I right click on my 'IMG_5422.jpg' and select 'Copy Link Address'. I click on the 'Insert Image' button and enter my copied URL into that pop-up dialog:
Oof.. that's huge in the preview window. Maybe worse than the attachment thumbnail size, even, since it spans the entire screen. Possible to resize it?
Nope, doesn't look like that's a feature of vBulletin. Not a fan of the attachment hanging about, either, since my posts are often image heavy. Perhaps if I need to do multiple steps anyway, I should just use imgur?
Let's try the same photo coming from imgur:
Original size:
EDIT (try Large Thumbnail instead of Huge) size:
Okay, that's a little better. We'll see how this looks after the post is saved.
No matter what, this is a very notable step back from before! I'm always more than happy to switch up my normal process flow, but this is a clear regression. This encourages people to use external hosting services and when that happens, it's almost guaranteed that older threads will be eventually bereft of images. Witness all of the skeleton threads from years gone past all linking to non-existent Photobucket accounts.
EDIT: looks like all three images appear the same size in the actual post. Curious. Still see the 'Attached Thumbnails', though -- maybe there's a way to hide that?
EDIT: Looks like I might be able to delete the attachment after the fact, but still keep the image. I need to Edit this post and then choose the Advanced editor. I click on the 'Manage Attachments' button. In the dialog, I click on 'Remove' by the image and then 'Close'. If we see the top-most image but don't see any attachment, then it worked.
granroth is offline
Old 06-12-2014, 09:19 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
Nice mastery of the new posting pictures method!
Mfusick is offline
Old 06-13-2014, 01:47 AM
Woobieizer's Avatar
Quoted: 477 Post(s)
Liked: 227
This is what I want
Woobieizer is offline
Old 08-23-2014, 03:20 PM
Woobieizer's Avatar
Quoted: 477 Post(s)
Liked: 227
Blacklisting scripts to quote post quickly
blacklisted scripts AVSforum.com wide to quote post and get to wysiwyg in a millisecond.
wysiwyg bereft of clickable in bbcode, because it is dependent upon scripting.
Type all text and comments to preview.
re-enable script and preview post to populate wysiwyg and have bbcode icons to manage attachments.
modified local style sheet to disable Drag n Drop Gui.
Originally Posted by Woobieizer View Post
removed the bbcode image
Old 09-02-2014, 05:25 PM
granroth's Avatar
Quoted: 664 Post(s)
Liked: 446
I was just notified that you need to login to AVS Forum in order to view images that are from attachments. I'm hoping there's a setting for that, since that would be a pretty terrible feature.
Testing now:
EDIT: Nope, I can't see it in an un-logged in browser This likely means I'm going to have to go through all of my posts and re-do all of the images. Argh!!!
granroth is offline
