Audyssey thread link testing - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #31 of 59 Old 07-06-2014, 02:31 PM
andyc56's Avatar
Quoted: 17 Post(s)
Liked: 336
Another interesting result. My previous testing (see post 20 of this thread) was with the following setup:
System: Desktop, Firefox 30.0, Windows 7
At the end of this testing, I reset "posts per page" to default in AVS Control Panel. then I switched to Internet Explorer 11 and logged in. So the new configuration is:
System: Desktop, Internet Explorer 11, Windows 7, posts per page = default
I clicked the link in Keith's sig and went straight to the FAQ! So then I went into AVS Control Panel using IE11 and changed "posts per page" to 100. So the new configuration was as follows:
System: Desktop, Internet Explorer 11, Windows 7, posts per page = 100
I then went to the same wrong post as when I was using Firefox with "posts per page" set to 100 when clicking on Keith's link (see post 20 of this thread). So I switched the "posts per page" setting back to the default. Now I have this configuration:
That is, same configuration as when I first tried IE and went to the correct page. Result? Wrong page! In fact, it's the same wrong page as post 20 of this thread when using Firefox with the default "posts per page".
andyc56 is offline
post #32 of 59 Old 07-06-2014, 04:53 PM
andyc56's Avatar
Quoted: 17 Post(s)
Liked: 336
I just did the following additional test.
  1. Set posts per page to 100
  2. Click FAQ link - goes to post 71601 (wrong post)
  3. Set posts per page to default
  4. Click FAQ link - goes to post 21481 (wrong post)
  5. Close Firefox and open it back up
  6. Click FAQ link - goes to FAQ as it should!
The above is completely repeatable. So it appears that in order to see the fix that occurs when posts per page is reset to the default, I must close Firefox and reopen it. Once that is done, I can repeatably go directly to the FAQ.
kbarnes701 likes this.
andyc56 is offline
post #33 of 59 Old 07-06-2014, 05:50 PM - Thread Starter
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5071
Good sleuthing! Thanks for that.
kbarnes701 is offline
post #34 of 59 Old 07-06-2014, 07:10 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
This is consistent with my experience in editing posts... internal links don't work properly after Saving until I Refresh the page.
wajo is offline
post #35 of 59 Old 07-07-2014, 04:11 AM
Woobieizer's Avatar
Quoted: 477 Post(s)
Liked: 227
Lightbulb UPID and Links landing 100%
This is going to solve the problem of links landing 100% of the time. This method will not be difficult to implement. We have to train ourselves to learn what a TRUE peramlink is in this VB format. That key was found in the URL revealed while looking through "All Post by User" and cherry picking my troubled link. My sig "Macros via Cell" was going arbitrary landing zone dependent upon URL I selected per Post Per Page parameters. I prefer 20 post per page. Therefore only people who had a similar setting would land correctly on my post. Even Guest user would land in different spots, as the default guest PPP is 30
Spoiler!
We need a peramlink that will work for Guest AND User regardless of PPP (post per page) This is it: Unique Post ID Find this number by hovering over your post of posts Misleading permalink popup.jpg You may want to copy the link location and paste it in notepad to get the UPID
The Magic:
post24101652.html?highlight=#post24101652
This is an example of the segment of URL you will need to use. You will have your unique post id number. Copy and Paste your UPID into both places, then copy the entire segment into your Signature/ or Post.
Here are two examples of segments done with UPID for Thread host KB.
post21782993.html?highlight=#post21782993 WELCOME TO THE AUDYSSEY FAQ AND 'AUDYSSEY 101'!
post21783025.html?highlight=#post21783025 FIRST TIME AUDYSSEY USER? FOLLOW THIS AUDYSSEY 101!
Seen below on lines 5 and 7 are the segments pasted correctly with UPID's respective.
I've tested this in IE 11, Chrome, and FF 30 in desktop mode, using default forum skin on a Win 8.1 machine.
Woobieizer is offline
post #36 of 59 Old 07-07-2014, 05:13 AM - Thread Starter
kbarnes701's Avatar
Liked: 5071
Same here. Until I sussed that, I wasted quite a bit of time re-editing the Audyssey FAQ and tearing out my hair because the links didn’t work.
post #37 of 59 Old 07-07-2014, 05:16 AM - Thread Starter
kbarnes701's Avatar
Liked: 5071
Spoiler!
The Magic:
That is fabulous work. I can't see very many people doing this every time they want to link to a post but hopefully your work here will help VerticalScope provide a transparent fix for the problem. Great job!
Woobieizer likes this.
post #38 of 59 Old 07-07-2014, 11:09 AM - Thread Starter
kbarnes701's Avatar
Liked: 5071
I have implemented Woob's workaround in my sig and asked people in the Audyssey thread to test it for me. Works fine for me. Many thanks Woob... great job!
post #39 of 59 Old 07-07-2014, 12:40 PM - Thread Starter
kbarnes701's Avatar
Liked: 5071
post #40 of 59 Old 07-07-2014, 01:06 PM
davelr's Avatar
Quoted: 28 Post(s)
Resp. to Keith Barnes re: links not working
Keith,
Saw your post this morning and gave it a try, but I'm not sure that I'm winding up at the correct place.
If I set the posts/page to "default" or manually to 30 I wind up at post 19950 which doesn't appear to be the post with the FAQ unless I'm mistaken. If I try the "101" link I also wind up at 19950. The "REW" and "Distance" links work correctly.
I tried several different posts/page settings just to see what would happen. In all cases the "REW" and "Distance" links worked correctly but the "FAQ" and "101" links behaved as follows:
40 p/p winds up at post 2700
100 p/p winds up at post 100
5 p/p winds up at post 68120
This behavior was the same in Firefox and IE. Let me know if they need any other testing.
davelr is offline
post #41 of 59 Old 07-07-2014, 01:21 PM
Woobieizer's Avatar
Quoted: 477 Post(s)
Liked: 227
@kbarnes701 Do you have ownership of the 1st page? Cause your FAQ reside in pre-VB (parsable) UPID's. Thus the only way I see these new handmade shortcuts working would be to go to 51780, 51779, and 51778 and copy the posts sequentially into the last page to obtain the newer integers that would allow for shortcuts and spot on landings for the (jumpto/anames). Test basic functionality, change the first post title. Delete the aforementioned after a week or two of life in there new home or just leave two copies.. JIC
I like the latter idea.. have two copies. Grab a parcel of land on the tail end of the thread.
You could test this theory in your other Test Post because it has the newer that 6/11/2014 UPID's
Unless VS and the Vbees have a plan, I don't see any other way..
post #42 of 59 Old 07-07-2014, 01:29 PM - Thread Starter
kbarnes701's Avatar
Liked: 5071
Thanks Woob. I could grab the parcel, as you call it, on the tail end of the thread. Not sure if it would be good form to have two FAQ posts though, and it would double my maintenance work. But I could always delete the original - but then the problem would be that all the hundreds of links to the FAQ and individual answers in the rest of the thread would be invalid of course. IDK how many people browse a thread that long but some might and every old FAQ link they hit would be wrong. As it stands, most people would, I think, get taken to the right place.
I am still hopeful that VS and the vBees come up with a solution (great name that ).
post #43 of 59 Old 07-07-2014, 01:39 PM
Woobieizer's Avatar
Quoted: 477 Post(s)
Liked: 227
you're missing the
?highlight=
It needs some work Keith..
HTML Code:
http://www.avsforum.com/forum/90-receivers-amps-processors/795421-official-audyssey-thread-faq-post-51779-a-post21783025.html?highlight=#post21783025
 http://www.avsforum.com/forum/90-receivers-amps-processors/795421-official-audyssey-thread-faq-post-51779-a-post21782993.html?highlight=#post21782993
post #44 of 59 Old 07-07-2014, 01:51 PM
Woobieizer's Avatar
Quoted: 477 Post(s)
Liked: 227
Let's give it some thought..
pretty sure I cloned Vbee from @Bob Sorel , it's catchy
post #45 of 59 Old 07-07-2014, 01:53 PM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
I'm using IE 10 on Windows 7 and Keith's sig links are working fine with 100 posts per page. However, from the subscribed threads page, clicking the link to what used to be the last read post is now always taking me to the last post (the same as clicking to the far right where the last poster is shown):
Did this change intentionally? If so, is there a different way to get to the last read post??
Name:	REW thread.JPG
jkasanic is offline
post #46 of 59 Old 07-07-2014, 01:59 PM
Woobieizer's Avatar
Quoted: 477 Post(s)
Liked: 227
Yes..
Mike Lang update the thread HERE:
http://www.avsforum.com/forum/25444833-post.html
post #47 of 59 Old 07-07-2014, 02:07 PM
Woobieizer's Avatar
Quoted: 477 Post(s)
Liked: 227
Originally Posted by davelr View Post
Keith,
@kbarnes701 I notice a snafu in his sig links and it is listed above.. Yet you may want to try to exit both browsers and flush all cache/cookies and relog. If you still fail in any PPP then Keith needs to check the URL I supplied above.
post #48 of 59 Old 07-07-2014, 02:27 PM - Thread Starter
kbarnes701's Avatar
Liked: 5071
you're missing the
?highlight=
HTML Code:
Ah - OK. It does actually work though. Thanks. I'll amend it.
post #49 of 59 Old 07-07-2014, 05:25 PM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
Yes..
Thanks for the link.
jkasanic is offline
post #50 of 59 Old 07-08-2014, 02:52 AM - Thread Starter
kbarnes701's Avatar
Liked: 5071
post #51 of 59 Old 07-08-2014, 05:02 AM
Woobieizer's Avatar
Quoted: 477 Post(s)
Liked: 227
Thumbs up Posted WIP, and resolution
Links
A. General Audyssey Issues
a)0. What is Audyssey?
a)1. What happens when I run Audyssey?
a)2. Why is dialogue from the centre channel difficult to hear or understand?
a)3. I keep reading about Reference Level'. What is it?
a)4. Reference or Preference - which is best?
a)5. How does Audyssey handle dipole and bipole surround speakers?
a)6. Is it possible to save and recall an Audyssey MultEQ calibration?
a)7. What are the Audyssey 'Movie' ('Reference') and 'Music' ('Flat') curves?
a)8. What is THX Re-EQ? Should it be on or off when using MultEQ?
a)9. Why are my high frequencies 'bright' or 'harsh' since running Audyssey?
a)10. How can Audyssey measure anything with those silly blips?[
a)11. Where can I find help with the Audyssey Pro Kit?
a)12. What is the relationship between the Equaliser setting in my Onkyo/Integra AVR and Audyssey?
a)13. Will Audyssey work if I am using external amplification?
a)14. Which current AVRs have which version of Audyssey room correction?
a)15. Does Audyssey care what input signal type, processing or decoding method I use?
a)16. What does the term 'F3' mean?
B. Issues That May Arise During Calibration
b)1. Why is Audyssey reporting that my speakers are out of phase?
b)2. Why is Audyssey reporting 'Ambient Noise Too High'?
b)3. Should I move anything out of the room before running Audyssey?
b)4. Should I leave the room when the measurements are running?
b)5. I am getting a speaker detect error - what's wrong?
b)6. Does it matter how I set the controls on my AVR when running Audyssey?
b)7. Audyssey ran OK but is stuck on the 'Calculating' phase. Any suggestions?
b)8. Why doesn't Audyssey work properly with my AVR's 'biamping mode'?
b)9. Why is Audyssey 're-chirping' and raising the test tone level, even when my ambient noise is low?
b)10. Why can I barely hear the test tones when Audyssey is calibrating my subwoofer?
C. Crossover Settings
c)1. Why are my Crossovers set differently to my speaker manufacturer's specification?
c)2. Why do I often see advice to raise the Crossovers to 80Hz?
c)3. I have big tower speakers at the front. Shouldn't I set these to Large'?
c)4. Is it OK to change the Crossovers from Audyssey's recommendation?
c)5. What is the LPF of LFE and what should it be set to?
c)6. Why is Audyssey setting different crossovers for my identical speakers?
c)7. Audyssey is setting my crossovers way differently to what I expected. Why?[
D. Mic & Mic Placement Issues
d)1. Do I really need to put the Audyssey mic on a tripod or stand?
d)2. Do I really need to use all the available Audyssey mic positions?
d)3. Where should I position the mic for best results?
d)4. Do I have to use the mic that came with my AVR or PrePro?
d)5. Why do I need to measure where nobody sits?
d)6. I have two rows of seats at different heights. What's the best mic placement?
d)7. Can I extend the Audyssey mic cable?
d)8. Where do I put the mic for the 1st measurement if my listening position is not centred?
d)9. Mic cable integrity issue.
E. Levels, Distance & Trim Settings
e)1. Is it OK to change the trim levels Audyssey sets?
e)2. Is it OK to change the distance settings Audyssey sets?
e)3. Why is it a bad idea to use your AVR test tones and a SPL meter to check trim levels?
e)4. Why has Audyssey set my sub distance much greater than it actually measures?
e)5. Audyssey has set my satellite speaker distances incorrectly - should I just change them?
e)6. What do I do if my trim levels are at the limits of their adjustment ('maxed out')?
F. Subwoofers & Bass
f)1. Why has Audyssey set my sub distance much greater than it actually measures?
f)2. How do I connect and set up two subwoofers?
f)3. How do I set the controls on my subwoofer before running MultEQ?
f)4. If I want to run my subs a little 'hot' where should I make the changes?
f)5. Since I ran Audyssey everything sounds great - but where has my bass gone?
f)6. My sub speaker distance setting is closer than the actual physical distance.
f)7. What is ‘LFE + Main’ or ‘Double Bass’ and should I use it?
f)8. How does Audyssey handle complex multiple subwoofer setups?[
f)9. What's the best way to set up Audyssey when also using Velodyne's SMS-1 room EQ system?
f)10. Why can I barely hear the test tones when Audyssey is calibrating my subwoofer? (Links to b)10)
G. Dynamic EQ & Dynamic Volume
g)1. What is Dynamic Volume?
g)2. What is Dynamic EQ?
g)3. What is Reference Level Offset in Dynamic EQ?
g)4. What's the difference between Dynamic Volume, Dynamic EQ & Reference Level Offset?
H. MultEQ: What Is It, How Does It Work?
h)1. Why do I need MultEQ?
h)2. What is the difference between the various versions of MultEQ?
h)3. How does MultEQ differ from my old graphic equaliser'?
h)4. How does MultEQ differ from other room equalisation methods?
h)5. What does correcting in the 'time and frequency' domains mean?
h)6. Does MultEQ measure anything else?
h)7. If I have MultEQ in my AVR, can I forget about room treatments?
J. Audyssey DSX Questions
j)1. What is Audyssey DSX and how does it work?
j)2. How many channels of amplification do I need to run DSX?
j)3. Is there any specific content designed for DSX?
j)4. If I can choose only one – Wides or Heights – which should it be?
j)5. Isn't Audyssey all about reducing the impact of unwanted reflections, not creating more?
j)6. Where should I place my speakers for Wides and Heights to get the best effect?
j)7. What kind of speakers should I use with DSX?
j)8. Are there any negatives to using DSX?
j)9. Are there any other technologies that do a similar job?
j)10. What are the differences between DSX and these other technologies?
Bump...
Same thread as all your hand made link are and can be retrofitted.
See this post for details,
post #52 of 59 Old 07-08-2014, 10:05 AM - Thread Starter
kbarnes701's Avatar
Liked: 5071
Links
Outstanding! Thank you so much for that!
post #53 of 59 Old 07-08-2014, 10:42 AM
Woobieizer's Avatar
Quoted: 477 Post(s)
Liked: 227
np Keith
post #54 of 59 Old 07-08-2014, 10:54 AM - Thread Starter
kbarnes701's Avatar
Liked: 5071
np Keith
Thanks again. You have been a huge help to me following the changeover to vB. As you may have seen in the FAQ, I always credit those who have been of help to me, so I will add an official 'thank you' to you asap. I wouldn't have known where to start.
post #55 of 59 Old 07-10-2014, 11:14 AM
Woobieizer's Avatar
Quoted: 477 Post(s)
Liked: 227
post #56 of 59 Old 07-10-2014, 11:22 AM - Thread Starter
kbarnes701's Avatar
Liked: 5071
post #58 of 59 Old 02-17-2015, 06:24 AM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
None of the links worked for me using IE 11. The first two links took me to the last page (I use 100 posts per page view) of the Official Audyssey thread starting with post 74101. The last link ("this post") took me to the FAQ in post 51778. From what I've seen on other threads, it feels like the number of posts per page has some effect on the links?!
jkasanic is offline
post #59 of 59 Old 02-17-2015, 06:54 AM - Thread Starter
kbarnes701's Avatar
Liked: 5071
Yes - links on AVS only work properly if the user has the post per page set to the default (30).
Reply Post Testing Area
