The reason links in AVS Do/Don't Work - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 07-22-2014, 07:50 AM - Thread Starter
Woobieizer's Avatar
Quoted: 477 Post(s)
Liked: 227
AVS has been from vB, to Huddler back to vBulletin and in the transition user's post that included Linked Text break for various reasons. One reason is Post Per Page.
This is a post that describes it best to me so I captured a picture and the Link to AlexT:
SEO=Search Engine Optimization
The bottom line is that since we have options to change our PPP......
......We will inevitably run across Linked Text that will throw us for a tail chaser since our option is open and the link integrity is destroyed.
Woobieizer is offline
post #2 of 10 Old 07-22-2014, 08:17 AM - Thread Starter
Woobieizer's Avatar
Quoted: 477 Post(s)
Liked: 227
How to Overcome bad Linked Text
Lets take a few random links form the old days:
Step 1
PHP Code:
http://www.avsforum.com/forum/166-lcd-flat-panel-displays/851860-official-westinghouse-tx-series-tx-42f430s-tx-47f430s-owner-s-thread-187.html#post12321483
http://www.avsforum.com/forum/25-hdtv-technical/798265-how-build-uhf-antenna-90.html#post15866958
What you can learn from this is that each link has a unique forum number, thread number, post number and a not so unique Page number.
The page number copied into this code box was dynamically made based on my Post Per Page view selection of 20.
How can I manipulate this above url into a link that will work all the time and be static?
Remember this segment of html:
Step 2
PHP Code:
showthread.php?p
This is url splicing at it's best and you want to take the funky Post Per Page dependent URL from Step 1 and cut out all the info from the forumID to the #post and inject the segment from Step 2 as the replacement.
Shown All Steps
HTML Code:
HTML Code:
http://www.avsforum.com/forum/2321483
PHP Code:
http://www.avsforum.com/forum/showthread.php?p=12321483
Did you land on 3730?
HTML Code:
HTML Code:
http://www.avsforum.com/forum/15866958
PHP Code:
http://www.avsforum.com/forum/showthread.php?p=15866958
Did you land on 1782?
Do you have old bookmarks in IE, or Chrome, or Firefox etc,, that no longer work.. Try this to fix them.
post #3 of 10 Old 07-22-2014, 08:31 AM - Thread Starter
Woobieizer's Avatar
Quoted: 477 Post(s)
Liked: 227
Reserved
post #4 of 10 Old 07-22-2014, 09:39 AM
J_P_A's Avatar
Quoted: 591 Post(s)
Liked: 443
Interesting. I'll have to take a closer look at this. I noticed a few days ago that the links I put in the "Index" of my build thread no longer worked. I've found similar in other threads as well, but haven't had time to stop and figure out what was going on.
The Plains Theater Has Begun
J_P_A is offline
post #5 of 10 Old 07-23-2014, 02:50 AM - Thread Starter
Woobieizer's Avatar
Quoted: 477 Post(s)
Liked: 227
Wow, that's a lot of work.. I thought I never get my custom bath and kitchen done.. I saw all those bags of sand and said WTH.. Granted I don't follow theater builds but at least now your lists are fixed and I know where to go to get info.
Speaking of noisy Fan's.. OMG i've got one over the range. .5 Sones my butt!!
post #6 of 10 Old 07-23-2014, 08:56 AM
J_P_A's Avatar
Quoted: 591 Post(s)
Liked: 443
That's awesome! Thanks for fixing those. I copied and pasted that into my thread. I'm still having trouble fixing my other links though. When I try to plug the post number into the php code you provide, the resulting link takes me to the top of the page where the post is rather than to the actual post. Any thoughts?
Thanks again! And yeah, I'm pretty sure the guy responsible for measuring household exhaust fans is deaf and blind. I've heard trains quieter than some of the bathroom fans in my house.
J_P_A is offline
post #7 of 10 Old 08-03-2014, 05:29 PM
CleCakYngMfd's Avatar
Quoted: 805 Post(s)
Liked: 248
I think this thread needs an update on the apparent fix about past errant message linking.
Set me straight if the following is amiss:
It is believed that the problem with a post's 'PermaLink', at times, would take you to the wrong message, has been fixed.
The PermaLink is the 'Post x of x' of each message in the upper-right corner. You can reference this PermaLink in your post (copy-n-paste) or bookmark it.
The PermaLink is the link to reference to - not the Message Post Number, as that can change.
Another method, is to use the [Post] BB Code Tag in the Message Editor...
I am using the Curly instead of the Square Brackets to stop the 'Post' Tag from executing to show what the format looks like in the Editor:
Usage:
{Post}Put the Post ID Number Here{/Post}
or this...
{Post=Post ID Number}Text Value{/Post}
Example:
{Post}12345678{/Post}
or this...
{Post=12345678}Click Here{/Post}
The Message as Posted will look like this:
http://www.avsforum.com/forum/showthread.php?p=12345678
or this...
Click Here
Here is a link to the list of BB Code Tags
Again, the Post ID Number is not the Message Post Number you see in the upper-right corner of each message.
Hover over the Message Post Number to reveal the PermaLink which contains the Post ID Number which follows the '#post' at the end of the PermaLink.
(Note: The above Thread ID/Post ID example may or may not link to a valid thread or post.) (It does, as I post this message.)
CleCakYngMfd is online now
post #8 of 10 Old 08-04-2014, 10:21 AM - Thread Starter
Woobieizer's Avatar
Quoted: 477 Post(s)
Liked: 227
You've gone to great length to make a point (bbcode tagging) but at the expense of missing the point.
Whether using the 'permalink' to copy/paste into a new or old edited message is not the topic of this thread. The fact is that there exists 'Linked Text' that will not land determinate upon user's setting of Post Per Page. Both these examples take me to the top of the last page. First example is relatively new, second is older.
When editing a users listing for old 'Table of Content', or Bookmarks; I would not want to type [post]12345678[/post] for every URL property line containing a UPID (unique post identifier). Simple methods requires simple steps. Your steps are great for a given purpose, but typing takes too long. IMHO, Copy/Cut/Paste is preferred.
Case in point the use of {} brackets in your Usage/Example. They were easier to use than typing out [nopares][/noparse] four times, or at the minimum one time and copying and pasting one in each line example.
We would agree that having these tags implemented into the editor as icon executable would be Awesome!
post #9 of 10 Old 08-04-2014, 06:09 PM
Quoted: 805 Post(s)
Liked: 248
Woobieizer: "The fact is that there exists 'Linked Text' that will not land determinate upon user's setting of Post Per Page."
Ok, it appeared it might have been fixed based on some posts in another thread. Someone tested different PPP settings and it worked. So, the {Post} Tag works but not always the PermaLinks?
Woobieizer: "Simple methods requires simple steps."
Yes they do... but this forum software is not quite there yet.
Woobieizer: "Your steps are great for a given purpose, but typing takes too long."
The BB Code Tags are there for a purpose. I noticed I could not Edit a message and do Colored Text - unless I used the {Color=ColorName} Tag.
Woobieizer: "IMHO, Copy/Cut/Paste is preferred."
Yep.
Woobieizer: "We would agree that having these tags implemented into the editor as icon executable would be Awesome!"
Yes it would. It is 2014... so why is this forum software not doing this already?
Last edited by CleCakYngMfd; 08-29-2014 at 07:51 AM. Reason: Changed Quoted Text Color
post #10 of 10 Old 08-04-2014, 10:47 PM - Thread Starter
Woobieizer's Avatar
Quoted: 477 Post(s)
Liked: 227
woobieizer: "The fact is that there exists 'Linked Text' that will not land determinate upon user's setting of Post Per Page"
My examples above are disproof to your unnamed source.
"Post" Tag, referring to any link that has
Code:
showthread.php?p=
or [post]12345678[/post] parsed; have been true to land correctly regardless of login status, or PPP.
As for permalink: Not much to say that wasn't addressed in Welcome Back thread, other than perhaps all post, and specifically threads created after vB go live UPID #24888193 , will copy/paste/and PARSE to land 100%, or be tweaked to do so by the vB Team..
Hover discloses nothing of value in the tool tip yet.
woobieizer: "Simple methods requires simple steps"
Forum software or functionality have no bearing on the context you plucked my sentence from. For the record, I used Notepad++ to markup changed, because
and let AVS do the parsing.
woobieizer: "Your steps are great for a given purpose, but typing takes too long"
Clever, and not unlike the method of doing named quotes. 👍
woobieizer: IMHO, Copy/Cut/Paste is preferred
Yep.
Glad you're in agreement with me having an opinion.
woobieizer: "We would agree that having these tags implemented into the editor as icon executable would be Awesome!"
This is not the correct thread for that discussion. More importantly, I'm not even kindling under the totem pole hierarchy.
Reply Post Testing Area
fixed , resolutions
