SoCal/LAAVA.org Spring 2017 Subwoofer meet - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 769Likes
post #61 of 724 Old 06-12-2017, 05:02 PM
Timothy1180's Avatar
Quoted: 919 Post(s)
Liked: 275
Looking like jtr and seaton are going to be the benchmark everything will be tested against.
Where is the svs pb16?
Timothy1180 is offline
post #62 of 724 Old 06-12-2017, 08:57 PM
xcjago's Avatar
Quoted: 13 Post(s)
Here's the slow-mo videos I recorded on my phone:
xcjago is offline
post #63 of 724 Old 06-12-2017, 09:15 PM
kyzer soze's Avatar
Quoted: 234 Post(s)
Liked: 157
My goodness that Seaton F18 is gorgeous
Pulloutchamp likes this.
Ascend Sierra 2's (LCR & side surrounds) + Klipsch atmos modules. 5.1.4 setup
Marantz AV7703
NAD M25
Rythmik FV15HP
kyzer soze is offline
post #64 of 724 Old 06-12-2017, 09:54 PM - Thread Starter
Marc Alexander's Avatar
Quoted: 2707 Post(s)
Liked: 2547
Originally Posted by xcjago View Post
The Cap 118 video is of CEA-2010 burst tones. 😲
The Cap 1400 video is the entire EoT intro. 😵
Marc Alexander is online now
post #65 of 724 Old 06-13-2017, 07:28 AM
ereed's Avatar
Quoted: 1317 Post(s)
Liked: 766
wow! that looks exciting! Now I wanna see Seaton F18 in slow motion!
Theater: Sony 45es, 120 inch 16:9 screen, Panny BDT500, Rotel RMB-1075, Rotel RSP-1068, Klipsch RP-280F, RP-450C, RP-160M, SVS PB13 x 2, Monster Power Conditioner, GIK acoustic panels
TV Room: Panasonic 60" plasma, Integra DTR-30.3, Axiom Audio M60, VP150, QS8, EP500
ereed is offline
post #66 of 724 Old 06-13-2017, 08:29 AM
bscool's Avatar
Quoted: 754 Post(s)
Liked: 591
@Marc Alexander How would you compare the Submersive vs the S3000i? Or have you had a chance to?
HTPC, Sony 40es, 120" Silver Ticket, 7702mkii, Sunfire Amp 225w, JBL 590, JBL 520
PSA XS30, Seaton Submersive, 2 Um-18 8cf sealed, Outlaw Ultra x 12, Kappa Pro 18LF, BFM Tuba 60 horn, B&C 18TBW100 6cf 41hz, 34hz, 28hz tune
iNuke 3000 & 6000 DSP's, Crowson Motion Actuator
bscool is online now
post #67 of 724 Old 06-13-2017, 09:31 AM
Mark Seaton's Avatar
Quoted: 695 Post(s)
Liked: 1869
Originally Posted by Marc Alexander View Post
We were able to get the Submersive, JL F113, & FV18* tested. In the middle of the Captivator 118 testing it got too windy so we went inside and played clips.
Most impressive to me? Easily the Cap 1400 and F18+!
Good to hear you were able to give a quick first listen last weekend. How long of a slave cable should I send out to insure you get to hear both downstairs? It might be nice to have the cable long enough to set in the front corners or 1/4 width given you have a pair for listening.
When listening to the SubMersive HP, given the more open room, you can also try setting the PGM SEL button to the out position (then cycle the power to engage it). This will make the low frequency response shape more like the F18. Ultimately you can either turn it up some in the native response or use the 2nd program to start a little flatter down low. It might prove interesting for you to listen and compare both if time allows. Changing the LF Adjust knob on the F18+ or using the PGM SEL button to engage the 2nd DSP program does not change how loud the sub can get at any frequency, just how much input signal is required to get to the limits. It won't affect CEA measurements, but can affect where you might stop on a frequency response sweep. For example, you could sweep an F18+ at its highest overall levels with the knob set around the minimum (full counter clockwise).
It's good to hear there were differences and similarities heard. Do you have a plan to attempt to initially match the levels of the subs you are comparing?
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is offline
post #68 of 724 Old 06-13-2017, 01:58 PM - Thread Starter
Liked: 2547
I am going to have to redo all the CEA-2010 testing (Sorry @xcjago )! I did not properly follow the REW procedure for calibrating the sound card/interface (Yamaha MG10XU) with a loopback. Same with calibrating the SPL levels for the mic (Dayton EMM-6).
Everything is golden now.
chucky7 likes this.
post #69 of 724 Old 06-13-2017, 02:02 PM
ereed's Avatar
Liked: 766
Admit it Marc....you just wanted to crank these subs all over again.
ereed is offline
post #70 of 724 Old 06-13-2017, 02:03 PM - Thread Starter
Liked: 2547
Originally Posted by tvuong View Post
*I have to speak to Brian Ding about the FV18 as there were some problems outdoors and indoors*
What were the problems?
I am actively troubleshooting with Brian. We will share more once we have fully diagnosed what is going on. Sorry that I don't have any more to share at thos time.
post #71 of 724 Old 06-13-2017, 03:32 PM - Thread Starter
Liked: 2547
Yes I do! I need to complete the measurements to setup the following in-room comparisons.
Seaton MFW-15 vs PSA V1801 vs JTR Cap 118 vs Cap 118 (vs Rythmik FV18 if possible)
Seaton Submersive HP vs Seaton F18+ vs PSA S3000 (vs Funk DO 12 {18.0C equiv} if possible)
**Seaton F18s & Submersive vs dual JTR Captivators**
chucky7, ereed and bscool like this.
post #72 of 724 Old 06-13-2017, 06:32 PM
xcjago's Avatar
Quoted: 13 Post(s)
Shoot, I thought something was off. Do you think there will be a correlation between the before and after numbers. Like old measurements +X dB = correct measurement?
xcjago is offline
post #73 of 724 Old 06-13-2017, 09:09 PM - Thread Starter
Liked: 2547
I highly doubt it. 🤓
post #74 of 724 Old 06-13-2017, 09:29 PM
tvuong's Avatar
Quoted: 1795 Post(s)
Liked: 1090
Hopefully you guys get it figured out before this weekend GTG so that we can see reports comparing all of the 18" ported subs along with the sealed one of course.
tvuong is online now
post #75 of 724 Old 06-14-2017, 09:42 PM - Thread Starter
Liked: 2547
A new driver will be delivered Friday so we should be in business!
post #76 of 724 Old 06-14-2017, 09:53 PM
bulls's Avatar
Quoted: 155 Post(s)
Liked: 92
SoCal/LAAVA.org Spring 2017 Subwoofer GTG
June 17th, 11AM - until whenever.
Marc list me on the 17th, wife has officially allowed me to depart for a few hours
Marc Alexander and chucky7 like this.
bulls is offline
post #77 of 724 Old 06-14-2017, 10:03 PM
tvuong's Avatar
Liked: 1090
Cool 😎
post #78 of 724 Old 06-14-2017, 10:13 PM - Thread Starter
Liked: 2547
@asarose247 and son came over today to test the smallest of his horn subs, the L-Horn (a little larger than 6'x2.5'x2'). They arrived around 9:30AM and it was already 90 degrees! I'm not sure how much heat affects horns but we were able to keep the INuke 6000DSP in the shade.
Above 20Hz it is an absolute beast! I did forget to run compression sweeps but we can do it at a later date as they don't live far from me. Attached are the CEA-2010 passing numbers we recorded. I can't wait to hear it in-room Saturday!
Today was my son's 4th birthday. Tomorrow night I will be able get several subs completed including the Cap 118 to see how my numbers correlate to data-bass.com.
chucky7 and salehdidit like this.
post #79 of 724 Old 06-14-2017, 10:47 PM - Thread Starter
Liked: 2547
Special thanks to Mark Seaton. He will make sure the slave cables are delivered Friday. With everything going on I haven't had the time/energy to build myself.
After hearing the single F18+ I went ahead and ordered two additional slaves. The deep bass detail is unlike anything I've heard. I haven't even played around with LF Adjust yet!
Mark also gave me some great pointers on how to better level match the subs using REW. Using the AVR's pink test tones has limitations.
chucky7, bulls, ereed and 2 others like this.
post #80 of 724 Old 06-15-2017, 12:03 AM
bulls's Avatar
Quoted: 155 Post(s)
Liked: 92
forecast looks good so far
Saturday 06/17 0% / 0 in
A mainly sunny sky. High 94F. Winds WNW at 10 to 15 mph.
bulls is offline
post #81 of 724 Old 06-16-2017, 01:28 PM
Pulloutchamp's Avatar
Quoted: 347 Post(s)
Liked: 492
Anything needed to bring?? Beer friendly??
Sharp Aquos Q+ 70" UQ
Onkyo Tx-nr646
Klipsch RP-280F (F/R towers) RP-250C (Center)
Polk Towers (rear surround)
SVS Elevations (Front Height)
2 PSA V1801 1 PSA V1500 Xbox1
Pulloutchamp is offline
post #82 of 724 Old 06-16-2017, 02:29 PM
chucky7's Avatar
Quoted: 1844 Post(s)
Liked: 2023
Looks like the Rythmik FV18 replacement driver won't be there in time for the GTG...
Panasonic TC-P55UT50
Pioneer SC-1222-K
Polk Audio LSiM703 / LSiM706c / RTiA3
JTR Captivator 1400
chucky7 is offline
post #83 of 724 Old 06-16-2017, 06:18 PM
kyzer soze's Avatar
Quoted: 234 Post(s)
Liked: 157
Damn
Marantz AV7703
NAD M25
Rythmik FV15HP
post #84 of 724 Old 06-16-2017, 10:48 PM
chucky7's Avatar
Liked: 2023
I just returned from Marc's residence. It's an almost windless night.
We did CEA 2010 for JTR 118HT and PSA V1801. Marc has it all figured out so setting up and moving subs actually took longer than the test itself.
It's too bad that we are in a heat wave in SoCal right now so we couldn't start earlier.
Pioneer SC-1222-K
JTR Captivator 1400
chucky7 is offline
post #85 of 724 Old 06-16-2017, 10:53 PM - Thread Starter
Liked: 2547
Just bring $5 towards the food. BYOB - Bring Your Own Beer. I can't drink.
post #86 of 724 Old 06-16-2017, 11:01 PM - Thread Starter
Liked: 2547
I haven't spoken to Brian @Rythmik since Wednesday but it must have been an oversight that it was sent ground instead of 2-day.
Nathan Funk explained to me a technique to remove the driver and attempt to determine an orientation (gravitational pull) that may allow more volume without mechanical noise. I will try tomorrow.
post #87 of 724 Old 06-16-2017, 11:02 PM - Thread Starter
Liked: 2547
Originally Posted by kyzer soze View Post
Damn
Can you bring the FV15HP?
post #88 of 724 Old 06-16-2017, 11:27 PM - Thread Starter
Liked: 2547
Some things never change. It's too bad more local folks don't have Funks!
post #89 of 724 Old 06-16-2017, 11:35 PM - Thread Starter
Liked: 2547
Jeff P and Mark S have been helping me get a handle on the CEA testing. The numbers posted for the L-Horn are 2m/Peak. We simply need to subtract 3dB to get 2m/RMS.
We will post all of the numbers after the listening impressions. Don't want to bias the jury (although I may have inadvertently done so already).
chucky7 likes this.
post #90 of 724 Old 06-16-2017, 11:38 PM - Thread Starter
Liked: 2547
Shout out to my next-door neighbor who told us to "have at it" as we tested a bit past 9:30! I hope they never move! 😎
chucky7, bulls and Pulloutchamp like this.
Reply Area Home Theater Meets
