Panasonic LCD Projection with Partial Yellow Tint on Screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-20-2008, 06:06 PM - Thread Starter
zacware's Avatar
I've had this PT50LC14 LCD Projection TV for 4 years. No problems except for having to change the bulb about 6 months ago. Now more and more, there is a yellow tint appearing across about 60-70% of the screen. I called a local TV repair shop and they said they never heard of of such a thing? Could it be caused by the bulb? It's 4 years old, and the idea of paying someone to start swapping out parts to try to find the problem is troubling. Any ideas are appreicated. Thanks!
zacware is offline
post #2 of 9 Old 05-09-2008, 03:07 PM
Duane123's Avatar
I also have several yellow blobs on my TV (PT-50LC14). It is due to a burnt polarizer filter just past the blue filter for the blue chip. This TV is a three chip design with red, blue and green chips.
I am currently trying to get a new polarizer filter from Panasonic.
Duane at duanetr@sbcglobal.net
Update: Panasonic was of no help, other than I could buy a new light engine from a Authorized dealer. I am now trying to buy a polarized blue unit from partstore.com.
Duane123 is offline
post #3 of 9 Old 06-12-2008, 04:11 PM
Duane123's Avatar
Update: I received a new blue polarizer unit from Panasonic. I installed it
and it fixed my problem!!!!
Duane123 is offline
post #4 of 9 Old 07-05-2008, 12:46 PM
Gps_man2's Avatar
I have the same yellow tint on part of the screen on my Panasonic PT50LC14 and would like to replace the blue polarizer filter . Can anyone tell me where this is located and how to access it for replacement . Thanks for any response.
Gps_man2 is offline
post #5 of 9 Old 07-09-2008, 06:16 PM
Duane123's Avatar
Gps_man2,
E-Mail me and will help you!
Duane duanetr@sbcglobal.net
Duane123 is offline
post #6 of 9 Old 07-12-2008, 01:28 AM
ratbones's Avatar
Hey guys my display Sony KDF- E50A10 also has a round yellow tint in the center. Could be that my light engine is bad?
I also posted this in the A10 master thread but no help.
XBL- Z3ROx24
ratbones is offline
post #7 of 9 Old 06-18-2012, 07:51 PM
shabenda's Avatar
Do you have the part number for the filter to get rid of the yellow tint on a Panasonic tv ?
shabenda is offline
post #8 of 9 Old 06-18-2012, 08:01 PM
ChuckF.'s Avatar
Every Panasonic model number tv will have a different part number for the blue input polarizing filter.
ChuckF. is offline
post #9 of 9 Old 01-28-2013, 10:23 AM
BreezyRacer's Avatar
BreezyRacer is offline
Reply Rear Projection Units
