HELP! color best color setting and game lag ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-10-2008, 06:56 AM - Thread Starter
bigdave4269's Avatar
I just recieved this mitsubishi wd57731 and having problems getting the best picture setting. Need to have it for the tune in before the big playoff game tonight for the Cavs game. Anyone else own this model? Next problem is my wife cant play guitar hero 3 on the Wii because of the lag. She cant seem to strum the notes in a timely fashion. Any advice would be greatly appriciated.
bigdave4269 is offline
post #2 of 5 Old 05-10-2008, 07:45 AM
slapshot11's Avatar
Not sure about the settings on that tv, but as far as guitar hero, there should be tv settings in the game that deal with the delay. There should be settings for projection tv, dlp, etc. Once you find the right setting, you should be all set.
slapshot11 is offline
post #3 of 5 Old 05-10-2008, 08:12 AM
walford's Avatar
The color settings for most HDTVs are set and saved separatly for each interface connection since the color levels coming from each source such as DVDs, STBs etc are not the same. So if you set the color settings while watching HDMI1 they do not apply when your are watching HDMI2 or component 1.
Hopefully as suggested your TV has a game mode which reduces the time required for scaling of inputs to the TVs native mode by reducing the quality of the scaling.
walford is offline
post #4 of 5 Old 05-10-2008, 02:40 PM
slapshot11's Avatar
Yes, i forgot about that. Some tv's have a game mode that will turn off all extra video processing functions on the tv. But my earlier post, I was talking about the actual game having settings to change the delay. YOu can try either of those suggestions or a combo of both to get it right.
post #5 of 5 Old 05-10-2008, 04:13 PM
ebackhus's Avatar
Use the lag test in GH3. Once it's calibrated it should be just fine.
ebackhus is offline
Reply Rear Projection Units
