How exactly would u describe the Rainbow Effect? - AVS Forum | Home Theater Discussions And Reviews
Old 06-22-2008, 06:13 PM - Thread Starter
techdummy's Avatar
I notice in mainly white backgrounds I see tiny small dots of color(red/green/etc) all over the screen. My other projection TV had it as well but it was only in the middle of the screen. I was unable to get an answer about this being the rainbow effect or not. Best Buy looked at me like I was crazy when I asked them about it. I was just wondering what some of u consider the rainbow effect to be?
techdummy is offline
Old 06-22-2008, 07:51 PM
gtunney's Avatar
The rainbow effect occurs when your eyes move quickly across a single chip DLP display. Note that this will occur with both front and rear projection systems. What you will see is bright objects separating into the colors of the light projection system, usually red, blue and green. Someone once captured this effect on their video camera which you can see at ftp://ftp.extremetech.com/pub/extrem...ainbowClip.wmv If you have The Incredibles, run the THX optimizer video option. When you see the white circle test, you can see RBE by moving your eyes quickly back and forth. This is how it was captured in the video. If you see it easily during normal videos, you might find it unsettling. I did. I get headaches watching color wheel dlps but LED DLPs reduce the effect enough that it no longer bother me.
gtunney is offline
Old 06-22-2008, 10:02 PM
WaldorfSalad's Avatar
What you describe doesn't sound like rainbow effect (try doing a search on "rainbows") but how can you expect anyone to really help you if you don't state what make/model of TV you have? Is it even a DLP?
WaldorfSalad is offline
Old 06-22-2008, 11:54 PM - Thread Starter
techdummy's Avatar
I have the samsung 61" 650series.
Old 06-22-2008, 11:56 PM - Thread Starter
techdummy's Avatar
My goodness. I didn't have a headache before but I have one now after that video. I pray my tv never does anything like that
Old 06-23-2008, 12:53 AM
Quentin2's Avatar
Quoted: 82 Post(s)
Liked: 33
Well that was informative, I think I've seen the rainbow effect now! Thanks for that link, gtunney. No way I move my eyes as rapidly as he waved the camera around so I don't think it's going to present a problem for me especially with a normal display. I have run the THX Optimizer though, it's on "Finding Nemo" which I have. Will have to try it again and see if I can get some of that effect.
TD, now we've got to figure out what you're seeing. Maybe it is a form of SSE?
2014 Samsung PN64H5000 Plasma Thread
2008 Samsung HLxxA650 DLP Thread/FAQ
Free Men Do Not Ask Permission to Bear Arms
Quentin2 is offline
Old 06-23-2008, 07:44 AM
nickels55's Avatar
Liked: 36
SSE - Silk Screen Effect. This is due to the texture of the screen and is supposed to help with the viewing angle. It can be lowered by decreasing the brightness and contrast, or by calibrating your screen. It is a characteristic of DLP TV's.
nickels55 is offline
Old 06-23-2008, 07:05 PM - Thread Starter
techdummy's Avatar
Today I just learned about calibrating a tv. I can't believe people do all these things to an already expensive set. The lady in Best Buy actually tried to get me to purchase a 700$ power surge.
Old 06-23-2008, 07:24 PM
gatorman's Avatar
With my first DLP, a Sammy, I saw the rainbows frequently at first. Then they pretty much disappeared. I think that my brain adjusted to what my eyes saw. No rainbows on a Mitsu.
gatorman is offline
Old 06-23-2008, 07:35 PM
nickels55's Avatar
Liked: 36
I am not sure what you are saying, but these sets have a million settings and the stores all have them punched up to crazy levels to try and sell them with a WOW factor. No two sets come out looking exactly the same. A pro will calibrate your set for about $400, or you can do it yourself with DVE or AVIA DVDs for much cheaper.
My set went from "pretty sweet" to "HOLY SH*T!" after I used both of those calibration tools. I see SSE only when watching hockey or occasionally in video games when there is a lot of white. Otherwise my picture looks almost 3d and very realistic. I have the Sammy 6187s - the older LED model. It's crazy sweet.
