DLP Green problem Mitsubishi - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 09-17-2008, 12:22 PM - Thread Starter
ebrom's Avatar
I have a mitsubishi DLP with model number WD-62530. The problem I am having is that it has an overall green color saturation. It is very saturated with green. This is happening on all inputs and even just in the menu. Anyone have a guess about what could be the cause of this? I cant find much information on avs or other forums about this particular issue for DLP. I found some people that had the problem on particular inputs or with particular aspect ratios but not as a whole. Any help would be greatly appreciated.
ebrom is offline
post #2 of 13 Old 10-05-2008, 07:09 PM
JacknJuls's Avatar
I have the same TV and just started having the same problem- did you ever find an answer?
JacknJuls is offline
post #3 of 13 Old 10-06-2008, 11:20 AM - Thread Starter
ebrom's Avatar
nope, I sure didnt. Sorry about that.
ebrom is offline
post #4 of 13 Old 10-06-2008, 01:38 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
Start looking how to replace the Light Engine $$$
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is online now
post #5 of 13 Old 10-06-2008, 06:39 PM
JacknJuls's Avatar
I unplugged my TV overnight and changed the lamp power up to slow- so far, so good. MNF is looking awesome so far.
post #6 of 13 Old 10-16-2008, 09:10 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
Not necessarly. How does it look on B&W material or with the color level turned down to zero? IOW's how is the grey scale?
ALL electronics age no matter what type. Things change. Depending on how bad this is, it might just need some tweaking.
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
post #7 of 13 Old 10-16-2008, 03:56 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
If the menu is affected by this "very saturated with green" problem, there is a hardware problem. "Some grayscale tweaking" will not even affect the color of the menu.
post #8 of 13 Old 01-04-2009, 01:56 PM
JacknJuls's Avatar
Are you pretty sure it would be the light engine that would cause this? I was quoted $732 for a replacement engine (plus installation) if that is the case. I'm mainly frustrated with how it comes and goes. You'd think if it was broken, it wouldn't work, and if it's sporadic, it should be fixable. Any suggestions appreciated.
post #9 of 13 Old 01-04-2009, 01:57 PM
JacknJuls's Avatar
Also, this isn't a DLP TV. The WD-62530 is RPLCD.
post #10 of 13 Old 01-05-2009, 07:32 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
Whatever you do, don't tell this site that;
http://www.bluestar-online.com/Mitsu...FQukHgod2HF_DA
Good catch.
post #11 of 13 Old 01-05-2009, 07:49 AM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
All inputs & Tv menu affected > Intermittent failure of the LCD Driver board, which is on the light engine. Suggest you have a tech out to SEE THE PROBLEM and give you a diagnosis.
post #12 of 13 Old 01-05-2009, 09:54 AM
JacknJuls's Avatar
I did have a tech out to see the problem; that's where the $732 + labor quote came from. To say the tech didn't inspire confidence in his abilities would be an understatement- "A new light engine should fix it, but I can't guarantee that" doesn't leave me with warm fuzzy feelings (and also makes me think there might be a cheaper fix available). Unfortunately, I live in a pretty rural area, so there isn't much available as far as local repair shops, hence my asking on this forum.
post #13 of 13 Old 01-09-2009, 06:54 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
If you haven't called Mits yet, do so. Tell them you live out in the boondocks and no service facility is near enough. Get a incident (reference) number, or whatever it is called. Then ask to speak to someone in California (possibly a 2nd phone call). Ask them to ask their 'advisor' what other board could be replaced instead of the whole Light Engine this so called 'tech' said was needed, since you are the one paying for this.
Reply Rear Projection Units
