EZ FIX 4 kdsr50xbr1 4 BLINKING LIGHTS FAN READ!!! - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 95 Old 11-10-2014, 06:34 PM
Liked: 0
No Fan Either
Ok so im pretty experienced with fixing electronics. I recently bought this Playstion TV on craigs and when I went to go see if it worked before i bought it it did. Took it home and it was working great. Ran into the same issue with the blinking red lights. As i'm following the instructions I opened up the back of the TV. Looked at the lower left of the tv, the lower right like 7 times. Did not see a fan anywhere. I wish a pic can be takin to see where it is cause it just seems as if there is no fan in mine. Hope to hear from someone soon!!!! Thanks!
Gabriel Sanchez is offline
post #92 of 95 Old 11-10-2014, 08:52 PM
George Cifranci's Avatar
See this post I made in the "Official 2005 Sony KDSR-50/60XBR1 Owner's Thread"
Official 2005 Sony KDSR-50/60XBR1 SXRD Owner's Thread
In it you will find a link to the service manual as well as where to find the fan.
George C.
OB replaced on 9-27-2007
George Cifranci is offline
post #93 of 95 Old 11-17-2014, 03:19 PM
Liked: 0
Originally Posted by FIXRUPPR View Post
Is your Sony shutting itself off and blinking the red led 4 times? Guess what? It's the fan...<br><br>
Don't waste your money buying a new one, I have the absolute easy fix:<br><br>
This is a fan issue, most likely the large fan in the rear, lower left (from the back)...<br><br>
Here's the fix, I promise, it's EASY........<br><br><br>
Ok, I think I have the answer for the BIG FAN failure. I recently did a similar fix on the spindle of an xbox 360 and it is identical. Ok, this is an EXTREMELY EASY FIX...<br><br>
Open the back of the tv, locate the large fan (on the lower left on the back of the set.) unscrew the screen and remove the fan.<br><br>
Once the fan is removed, you will see the side with the model number and the other side is totally open.<br><br>
On the open side, pull...<br><br>
The fan will come off, into your hand, it is only held by magnets...<br><br>
You will notice a spindle on the fan and the other side has the magnets and the hole where the spindle came from (this is the fan motor).<br><br>
Clean both the spindle and the hole (motor) with a q-tip. The hole is smaller than the q-tip, but do the best you can to remove the old lubricant.<br><br>
Get a bit of WD40 and lubricate the spindle and spray a touch in the hole.<br><br>
Put them together, reconnect your fan, test it on start up and thank me...lol...<br><br>
HOPE THIS HELPS!!!!<br><br>
IT WORKS, TRUST ME...
This works great. I scheduled a tv repairman for $99 plus costs etc. - but I had to wait 2 days. Instead I fixed it myself. I followed the instructions above, and also watched a youtube video. I had the original fan model Airflex and had trouble getting it apart (I was trying to get it apart while it was still connected to the tv). After watching video I disconnected the fan from the tv, and had a much easier time getting it apart. Followed instructions and have my tv back. I also ordered a sony replacement fan from amazon.
I have a background in theoretical physics, and I am totally worthless mechanically so I was reluctant to open tv. I am also a professional poker player so I decided to gamble. Thanks for the info.
Mark Weitzman
markweitzman is offline
post #94 of 95 Old 05-20-2015, 06:57 AM
Liked: 0
THank you FIXRUPPR!
My KDS-R50XBR1 had the blinking LED symptom last week. And I found this thread. So I cleaned the fan and the shaft & bearing. It didn't work first. so I check the construction of the bearing, it was made of porous sintered material. The lubricant must dry out after 10 years. So I put two drops of lubrication oil in the hole and let it sit overnight. Next day, I used a Q-tip to soak up the excess oil, put back the fan, and it works. Now the TV is back. Thank you.
dexter000 is offline
post #95 of 95 Old 11-25-2015, 09:16 PM
briggleman's Avatar
So I to had the 4 blinking lights. Used my pancake air compressor to blow out the dust on that fan and the tv worked that night. However the next day it failed to come on. Attempted the re-lube of the fan as explained by the OP but my fan blades would not come off. I ended up destroying the fan. I tried a 3 wire computer fan but the tv did not like it. Ended up ordering one from Amazon for 20 bucks. Installed and now back up and running. I know it's time for a new tv, but I just love the sound and decent picture of this one. As long as I can fix it. It's a keeper.
briggleman is offline
Reply Rear Projection Units
