Panasonic PT 56TW53 Please Help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-12-2008, 05:48 PM - Thread Starter
kurtsbug's Avatar
Just bought a Panasonic PT 56tw53 that worked great before moving it. The tv is now projecting exceedingly bright red, green and blue light out of the front of the screen. What steps should I take to get this repaired. is it repairable? I have a list of Panasonic repair shops ready to call if need be. Just need some advice here.
kurtsbug is offline
post #2 of 5 Old 10-12-2008, 06:29 PM
hammerdwn's Avatar
Quoted: 173 Post(s)
Liked: 57
Post a picture
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is offline
post #3 of 5 Old 10-12-2008, 10:15 PM - Thread Starter
kurtsbug's Avatar
Ok, I have uploaded the pictures (2 of them). First timer here. Also, when we transported the tv the outer screen was damaged. It was my understanding that this was the protective screen. It has been completely removed.
kurtsbug is offline
post #4 of 5 Old 10-13-2008, 07:46 AM
hammerdwn's Avatar
Quoted: 173 Post(s)
Liked: 57
Wow, that's crazy looking. I'd say if you've never touched the inside of a Tv before, you should get a tech to diagnose it. But, if you really want to, take the back off and look inside where the crts fire up into the mirror and see if anything is blocking that path.
post #5 of 5 Old 03-03-2013, 04:50 AM
davidoburrido's Avatar
i have curved red lines accross the screen, is that a bulb, cable, etc? looks like a laser pointer making lines accross the screen...
davidoburrido is offline
Reply Rear Projection Units
