HDMI input to an Pioneer Pro 520 hd - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-09-2008, 09:12 PM - Thread Starter
Truky46's Avatar
Hi to all.
I have a satellite receiver SV 8000HD the output from the satellite receiver to the TV is a HDMI connection but my Pioneer Pro 520HD do not have a HDMI input only component and RGB.
I like to know if anybody know about and switch or adapter to use with my TV set and made an HD resolution.
Thanks to all.
Truky46 is offline
post #2 of 2 Old 11-10-2008, 07:57 AM
walford's Avatar
Assuming your unit does have a DVI output get a dvi to HDMI cable or use component cables since the unit will output HD programs over either.
walford is offline
Reply Rear Projection Units
