Samsung HL-T5X87/89 vs HL5XA650 Refurbs? - AVS | Home Theater Discussions And Reviews
post #1 of 1 Old 11-24-2008, 09:55 AM - Thread Starter
webdev511's Avatar
We are considering replacing our Sony 37" LCD RP with either a refurbished HL-T5087/89 (56) or HL50A650, but haven't been able to make very much of a direct comparison between the two DLP based sets. Our maximum viewing distance is a whopping 9', so anything larger than a 56 is just too big.
What's the quality like on Samsung Refurbs?
Is the 2007 LED Light Engine still considered better than the 2008 lamp & color wheel?
Nevermind finally found a helpful thread. http://www.avsforum.com/avs-vb/showthread.php?t=1029349
Webdev511
San Jose, CA
TrueHD = DTS-MA = LPCM
Low Bit Rate AVC > Low Bit Rate VC-1
High Bit Rate VC-1 > High Bit Rate AVC
MPEG-2 = Great for DVD and that's about it.
webdev511 is offline
Reply Rear Projection Units
