Toshiba RPTV picture prob - video sample included - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-10-2009, 06:11 PM - Thread Starter
fggtheater_john's Avatar
I have a Toshiba 40H80 RPTV with a problem that has cropped up all of a sudden. The unit is about 8 years old and was trouble free until now.
I've attached a link to a video sample of what the TV is doing at the end of this message. This looks like the TV will not sync or something... this happens on any input I try be it the TV tuner, DVD input, s-video input, etc.
I would like to determine if it's worth it or not to try and repair it myself (if possible) or if I should have a service tech try to fix it, or if I'm just out of luck. Thanks in advance!
http://www.flickr.com/photos/webcompanion/3185690099/
fggtheater_john is offline
post #2 of 3 Old 01-10-2009, 07:39 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
http://www.google.com/search?num=20&...a+hyper+module
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is offline
post #3 of 3 Old 01-11-2009, 11:34 AM - Thread Starter
Thank you hammerdwn! I'll look into this more.
Reply Rear Projection Units
