Official LaserVue Owners thread - Page 90 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
Old 06-10-2014, 02:49 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1113 Post(s)
Liked: 1088
Originally Posted by jpetrol251 View Post
so my a91 now has some issues with dots that come and go. I called mits and after putting up a fight they agreed to fix for free (parts and labor). But they want me to sign a release. CONFIDENTIAL SETTLEMENT AND R E L E A S E. The tv is over 2 years old. I brought up the buybacks and they said No. Any advise?
Any idea if the repair is expensive or not? If not, I'd tell them to stick that document where the sun doesn't shine. If it is expensive, I still might tell them to do that. If you sign the document, where does that leave you if the repair doesn't work? On the one hand, it's nice that they're agreeing to fix something that's out of warranty, but on the other hand it's the right thing to do (except for the signing your life away part).
Not that it's a factor at this time because they don't currently sell anything I want, but I can't see myself every buying a Mitsubishi product again seeing how they've been handling these issues.
OptimusNeo09 likes this.
gsr is online now
Old 06-10-2014, 03:10 PM
taichi4's Avatar
Quoted: 322 Post(s)
Liked: 153
Luck for you the problem appears (from your brief description) to be the DMD chip at the heart of the DLP engine. As such it is no different than what many Mits DLP owners have done...either have a tech do the repair, or do it themselves. Most importantly, the appropriate Texas Instrument DMD chip is available, as opposed to the very difficult to find Mits lasers.
You'll need to search some of those threads and posts, but even if you have a tech do it, it's much less than cashing out the TV, or signing away your rights. On the other hand, what are they asking you for other than confidentiality (which appears moot at this poin).
In your case the problem appears to be the tiny mirromirred DMD chip which modulates the light projected by the lasers.
By the way, Mits is returning to TV with a UHD flat panel LCD, which uses a red lase rather than the standard red (filtered) LED for illumination
taichi4 is offline
Old 06-10-2014, 03:17 PM
DoctorM's Avatar
Quoted: 665 Post(s)
Liked: 202
Oh, I did want to also mention that I seem to recall the 'dots' that come and go is a failing DLP chip, not lasers. That's a part that a lot of people have ordered cheap on their own and replaced.
Anyone able to comment on this? I'm too lazy to search the thread.
DoctorM is offline
Old 06-10-2014, 04:05 PM
taichi4's Avatar
Quoted: 322 Post(s)
Liked: 153
See above post.
The dots are caused by the degradation of the micromirror structure and movements that produce the DLP effect. Each pixel of picture is projected by an independently moving micromirror that moves on a hinge structure.
Due to the deforming effect of heat on the hinge structure, and possibly the build up of electrical charges from continually being made to move by electrical charges, the mirrors become biased, and even frozen in place. The light dot is a mirror always projecting light onto the screen, and the dark dot is a mirror that is swung so that it cannot reflect light.
taichi4 is offline
Old 06-10-2014, 04:21 PM
OptimusNeo09's Avatar
Here you go. I'm prepared for that day just in case. http://www.avsforum.com/t/1475141/how-to-replace-the-laservue-l75-a91-ti-1910-6143w-chip
OptimusNeo09 is offline
Old 06-27-2014, 12:12 AM
DoctorM's Avatar
Quoted: 665 Post(s)
Liked: 202
Arc?
Finally getting around to replacing my really old AV receiver.
Checking out possible wiring options, I discovered HDMI ARC (Audio Return Channel) and though 'cool'.
I can find no mention of it. Did Mitsubishi really skimp on this and give these TVs only 1 possible digital output line (coxial) or is ARC just undocumented?
DoctorM is offline
Old 06-27-2014, 02:38 AM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 1088
Other than eliminating a cable, there's absolutely no advantage to ARC as it doesn't support the high res audio formats such as Dolby True HD or DTS HD Master Audio. So I honestly wouldn't worry about it.
gsr is online now
Old 06-27-2014, 10:05 AM
DoctorM's Avatar
Quoted: 665 Post(s)
Liked: 202
It just sort of sucks that if you use the Laservue for tuning your TV, there is only one digital output and it's coaxial.
Btw, talking to someone at Best Buy yesterday, they said they have Geek Squad (not the regular GS guys, but specialists) who do come out and blow out dust from rear projection TVs.
I didn't ask if that is included in the extended warranty or an extra cost, but since I've yet to figure out how to actually life/move/relocate the TV to clean it out, it'll probably be worth it.
DoctorM is offline
Old 06-28-2014, 11:57 AM
taichi4's Avatar
Quoted: 322 Post(s)
Liked: 153
I'd be careful, in that a lot of people (including Geek Squad) don't know how to clean the lenses of a rear projector. People immediately think microfiber, but that is not a great solution. Mr. Bob, on the Don't Dump Your CRT RPTV has some good info, which would apply to all lenses in all RPTVs.
The coatings on these lenses have to be treated in the proper way, as your image, in the last analysis, is projected through these lenses.
And I'd be careful around the DLP light engine as well. I'd ask these techs precisely what they would do during cleaning.
taichi4 is offline
Old 06-28-2014, 12:47 PM
DoctorM's Avatar
Quoted: 665 Post(s)
Liked: 202
Good note. I was more of the mindset that if I did it myself and messed it up, or hired some other repair shop to do it (and they messed it up) I could be SOL. If Best Buy messes it up, they hold the extended warranty so I'd probably be able to twist their noses for a 4K or OLED replacement.
DoctorM is offline
Old 08-01-2014, 08:46 PM
phenderson's Avatar
Quoted: 14 Post(s)
Originally Posted by jasonmichaelh View Post
Find the service manual and do it yourself. It definitely looks like the top mirror might be out of whack. Vertical adjustment can be made in the service menu.
If you are the second owner of the tv I doubt Mits will buy it back from you, unless maybe you are in a state that exempts you from the non-transferable warranty clause. It sounds like you are on AZ like me, so that wouldn't apply.
Walts might be able to help you, but they did a horrible job of servicing my LV.
Jason, let me make the long story short.
I paid guy I bought the TV from, $300.00 + $50.00 to his cousin, to deliver it to Waltz...
I then paid Walts $50.00 to "look" at it. By the time the TV powered on, the curves were a profound hour glass.
Walts quoted me $1200.00 to fix the Laser Assembly. I told them "No, give me some time to find an alternative".
I have found a laser engine assembly for the 91 series, on ebay, for $350.00
Should I buy that unit and try to fix it myself.
No, I am not a soldering time person... but I am an IT specialist. I have been known to take apart laptops and fix those with my A+ certification intuition.
Would that be enough?
Lol... would YOU be interested in a project, since you live in these parts of Arizona, like myself...
I am going to call some other TV shops to see how much the would charge me...
Its been over a month, and Walts is now calling me to come pick the TV up...
phenderson is offline
Old 08-02-2014, 09:41 AM
RU Geekman's Avatar
If this is the part on ebay that you are referencing (the price is the same as what you mentioned), please be aware that this unit does not include the laser assembly. The part listed on ebay, # 870B010001, is the Optical Engine Assembly. It contains the Digital Micromirror Display (DMD) chip, lens and mirrors. The lasers for the L75-A91 are in the Light Source Assembly, # 870B009001, which listed for $2,497.30 from the Mitsubishi parts department. However, they haven't had this part since March of last year and I know of none available in the secondary market.
RU Geekman is offline
Old 08-02-2014, 11:59 AM
phenderson's Avatar
Quoted: 14 Post(s)
RU Geekman, they (Walts) said that that part, and not the laser assembly, were the only things that needed to be repaired..
Old 08-02-2014, 04:00 PM
RU Geekman's Avatar
You had used the term "laser assembly," so I wasn't sure if you knew that the lasers and the main optical components are in different assemblies.This thread will show you how to change out these parts. Just follow the instructions for removing the Optical Engine Assembly (the formal name for this unit is "ASSY-ENGINE"), part number 870B010001, and replace it with the unit that you purchase on ebay. Just note that in the instructions in that thread, only the DMD chip is being replaced, not the entire assembly (which contains the chip in a sub-assembly). I know of no way to obtain only the focusing mirrors, apart from getting them already installed in the ASSY ENGINE. Nor would you want to try, as it would be almost impossible to align them correctly outside of the factory. PM me with your e-mail address and I will be happy to send you the service manual.
Old 08-07-2014, 11:56 AM
rokosz's Avatar
Hello All,
This is a continuation of a number of posts I started back in early June 14
To sum up, the subject was "overheating" I disassembled the back cover and vacuumed the exhaust fan heat sink of a solid layer of dust/pollen/cat hair. And that seemed to be the answer. Called off the ext. Wty effort. But then it overheated again. wt?
Summer continues, but its been a cool one. my wife kept saying the breakeven point was 75Deg. any higher and the unit would shut down with the os display of ".. too hot...blocked air vent". So its not that heat sink/fan.
It must not be the DLP the tv works fine -- until it shuts down.
I'd always felt the denon receiver had _something_ to do with it, ignorant yes, but I thought the Mits had some sort of "wifi" ability and the Denon was confusing the Mits circuitry (a number of the mits shutdowns occurred when the denon was powered on). The denon is close by (a big hint, keep reading)
Haven't used the denon in weeks and as i said a cool summer _and_ my wife likes airconditioning in Greenland -- so the room has pretty much been under 75 all the time.
Well Lon'Bhold the danged Mits shutoff lastnight. Temp? 73 deg. (dog cocks head: eeruuuh?) We'd practically forgotten about the issue. Then i notice the denon is on. How long? Wasn't me - hadn't used it in weeks.
Finally a forehead slap: put my hand on the wood cabinet the mits sits on and directly underwhich is the denon -- its pretty warm -- much warmer than the other side of the cabinet top. Reach under the cabinet to above the Denon and hmmm that does seem toasty. I haven't yet moved the denon or adjusted the cooling in the denon area but finally I feel like a clear cause and effect. and yes the denon does seem to interact with the Mits but not vicariously, quite physically.
rokosz is offline
Old 08-15-2014, 06:30 PM
phenderson's Avatar
Quoted: 14 Post(s)
Originally Posted by rokosz View Post
Hello All,
Quick question to you or any of the other watchers...and readers.
How does the picture on some of these Laservue's compare to say the 6000, 7000, and 8000 series of the Samsung LED's or perhaps the Panasonic Plasma's?
Old 08-16-2014, 09:15 AM
Liked: 0
L75 A91 light engine fail.
I have a 2011 Laser TV purchased by One Call and I purchased the 3 year it expired on July, 11 2014 my TV broke on July 22, 2014. Well, that's another issue. However, that being said I have had a issue with picture brightness and a mild darkling and then getting bright and a mild color flicker as well. I am not getting any error code and no other issues. The picture still at times looks great but, is getting slightly worse. I called a technician (he was 3 hours away). Also, good luck finding a TV repair man who has any knowledge on how these TV's work. I live in central Md. So, if anyone needs to vent or just ask a question let me know. When the technician stated he could try a software update (if he could even find the software). I will say Mitsubishi said they would help me in my endeavor. I feel, as well as the technician feels that, the TV is totaled. I must say I am terribly disappointed because, this TV was beautiful. I have 10,073 hours on this unit. I babied this thing never moved it always kept it clean not a scratch. I must say I am truly devastated. No TV and the NFL season is here. I am already in debt and can't afford a $2,000 purchase. At this point I have no choice. Screw it, I need my Tv. I am not sure what I am asking for other than the fact that if your reading this you are not alone. Take comfort in the fact that others are suffering along with you. If anyone has the software update or light engine let me know. I hear you laughing loudly at me. If your laughing you realize I will never find it. Thanks to all.
just2muchfun is offline
Old 08-17-2014, 04:26 PM
EmerJency's Avatar
You Can download the latest, and afaik only, update from here. http://mitsubishi-tv.com/support/documents/L75-A91
As for the light engine, good luck. Let us know what fixes the slight dimming and colour flickering.
EJ
EmerJency is offline
Old 08-25-2014, 05:17 PM
Hagenstein's Avatar
Quoted: 94 Post(s)
Liked: 86
Another LaserVue fail...
Brother I am feeling your pain. I've had an L75-A91 for 4 yrs now and pretty sure the laser-light source has failed based on super-dim image, plus I now have the shut-off issue (set shuts back off within seconds of being powered on). I do have the benefit of a 5-yr warranty I purchased (through a local retailer) but not sure how they will handle it (their specialty is furniture and "selling you stuff", not AV/HT ) , or if I would have better luck dealing w/ Mits directly. I posted the below in the L75-A91 owners thread. Copying here for added visibility:
Originally Posted by Hagenstein View Post
Hi All. A fairly inactive thread these days but nevertheless wanted to add my own L75 A91 to the list of failing/failed LaserVues.
Some dimming noticed sometime in its 2cd year. More so in the 3rd year. A LOT more in 4th year to the point of not really being watchable. A few weeks ago began getting the auto-shutoff as well (time to shut off varies and I've ruled out all other source components and cables).
My 5 year warranty is good into late Spring of 2015 so not 100% how the retailer I ordered the set through (local retailer) is going to handle it. I loved the image when the set was in its prime (after calibration), especially 3D, and am now sorely disappointed it hasn't lasted longer. If the set could be repaired I *might* be ok with that for awhile, but how long before it would go out again? I really think I want to replace it with the 2014 model LG 84" 4K/Passive 3D set (don't want to go down in size and not much else out there that can match the non-ghosting high-quality 3D imho) but I *have* to recoup something per the 5 yr extended warranty I purchased.
And what's with the lack of availability of parts for this set anyway? I was under the impression manufacturers were required by law to stock parts for 7 years past the date they cease selling (manufacturing?) the product. Is this incorrect? If not, how does Mits skirt this requirement? And if I'm wrong well, not the first time lol.
Any owners out there that have had their set repaired (particularly new light engine) and has remained in good working order afterwards for a substantial amount of time (or the opposite)? Let's hear the rest of your story.
raccoondad likes this.
Hagenstein is offline
Old 08-25-2014, 05:30 PM
Hagenstein's Avatar
Quoted: 94 Post(s)
Liked: 86
... and a mild color flicker as well.
Let me guess... A sudden change in coloration of the image, such as a strong greenish tint?
Mine started with the green tint once every few minutes. It increased in frequency to every few seconds, and began cycling between: normal-but-very-dim image -> dim-green-tinted image -> normal/dim again -> dim reddish-tinted image.
It is not entirely unlike what I used to see years ago in CRT's when one of the colors would start to "go out". Which is I why I'm pretty sure it's an issue with the laser light sources.
Interested to hear what recompense you get from Mitsubishi if any, and what you had/have to go through to get it. Seems Mits' response to LaserVue issues has varied considerably, with some folks getting decent buy-backs and others not-so-much. May be calling them myself in the next couple of days....
Old 08-26-2014, 07:27 AM
EmerJency's Avatar
That is exactly what my set is doing now. I've purchased the main board and light engine both harvested parts, but am thinking it is the light source which I can't find anywhere. I will be replacing both parts once both are in hand, and will update if either one fixes issues.
EJ
Old 08-26-2014, 10:57 AM
Hagenstein's Avatar
Quoted: 94 Post(s)
Liked: 86
EJ
Please do and good luck.
Old 08-31-2014, 08:35 AM
EmerJency's Avatar
Still waiting on light engine, but thought I would post the next bit of symptoms that I've seen on the set. As well as the dim picture and pulsating tints, when I go into the service menu by pushing <menu> then 2, 4, 5, 7 on the remote, the service menu screen comes up but the screen takes on a magenta hue until I back out of the service menu. So any image that has any white in it comes out magenta including internal test. I was wondering if anyone else has seen this and if/how it was repaired. I am still thinking it's the light source and have engaged Mitsubishi to try and locate the light source to replace, but will see if they can pull through for me.
EJ
Old 09-11-2014, 01:30 PM
Hagenstein's Avatar
Quoted: 94 Post(s)
Liked: 86
EJ
I was going to test this on mine, to see whether I could replicate, however
a) My set won't stay on long enough for me to find out (a few seconds now at best), and
b) when I *am* fast enough to get it into svc mode, the svc mode never actually comes up; black screen only.
At this point in my own saga, the retailer I purchased through has honored my warranty by letting me my apply my full, original purchase price that I paid for the LaserVue (plus a little more) and apply it towards the purchase of a new set. They were actually willing to let me replace the set outright with what they felt was something comparable, but we had a difference of opinion on what qualified as "comparable". Which was fine with me in this case, as I'd made up my mind to replace it with the 2014 84" LG 4K passisve 3D set, based more on the quality of the passive 3D than on the rest of the set's attributes (not that those weren't taken into consideration as well).
I'm still interested to hear how this works out for you though, and hope they work out satisfactorily in some way. I wish we had some statistics on the percentage of failed Laservues... Sony had a class-action lawsuit on their hands some years back (and I think they lost) over a substantial fail rate/lots-o-problems with an early SXRD based set. Not sure how the suit was settled though. I'm not advocating or suggestion such action against Mits by any means (I was rather dissapointed to see them get out of the DLP projector market plus I still think the Laservue tech had promise), buuut... Just sayin'...
Disclaimer: i am not a lawyer nor do I play one on TV. No lawyers were injured or harmed in the writing of this post.
Old 09-11-2014, 05:48 PM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 1088
That strikes me as a very fair way to compensate you. Hopefully you get a much longer life out of your new TV.
gsr is online now
Old 09-11-2014, 06:31 PM
Hagenstein's Avatar
Quoted: 94 Post(s)
Liked: 86
Agreed, esp. given that I paid around 5K for the Laservue (the 2cd gen 75" model had just come out that year - early adopteritus I guess). I do wish there was a way I could have gotten a check from them to apply towards a purchase thru Chris at Cleveland Plasma, who have had great pricing on the 84" LG, but I could only get this deal via in-store credit (no surprises there really). They wouldn't come down to Cleveland Plasma's price, but the amount they did come down plus the money back for the Laservue put the LG price well below what I could reasonably have expected anyone else to match. So I feel this was quite fair.
And yes, I sure hope this set lasts longer than the 4 years of the Laservue (which I will still miss; oh that color when it was in its prime...)
Old 09-16-2014, 04:52 PM
EmerJency's Avatar
Any of you folks know if the later models a94/96 light source can be used in the a91? Want to see if Mits will sell me one from a newer set since they should still have these parts. Part numbers are slightly different but I need something to hope for haha.
EJ
Old 09-22-2014, 08:38 AM
john stephens's Avatar
Quoted: 39 Post(s)
Liked: 40
Just a reminder. Lasers don't go dim. They either lase or drop dead.
john stephens is offline
Old 09-22-2014, 02:44 PM
EmerJency's Avatar
Thanks for the heads up on that John. I was wondering if the light source is repairable? I have a dim picture and slight colour shifts as described by others in this thread. I purchased a salvaged main board and light engine, but the main board was bad, and I didn't try the light engine. Any help/advice you or anyone can give would be greatly appreciated.
EJ
Old 09-22-2014, 04:32 PM
Quoted: 39 Post(s)
Liked: 40
EJ
I can tell you this. I bought one of the first A1's sold in the US and it's still working beautifully after 7 years. Indeed my calibration has remained robust as I expected it would. Those lasers are externally tuned/frequency doubled solid state lasers. They only lase in case the underlying infrared laser wavelength is twice that of the Niobate cavity. No possibility for drift and lasing at the same time.
Things that can go wrong include DMD failure after long life and or perhaps problems with the power supplies. I would check those two things along with general cleanliness of the innards.
