big black spot on SAMSUNG sp 403jha - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-29-2009, 03:38 PM - Thread Starter
tuberoaster's Avatar
Hi,
the "spot" actually covers more of half of the surface of the screen, like a centered ellipsoid. I can think of 2 possibilities:
- the lamp: But why are the borders of the black spot so sharp?
- the LCD: But how come that it is so perfectly black?
Is this a common failure of LCD RPTVs? I have no experiences with these, just got it in this condition...
BTW, if it was ever necessary, do you know if/how it is possible to enter the service mode without the remote control? I don't have it...
thanks a lot!
tuberoaster is offline
post #2 of 3 Old 01-29-2009, 05:27 PM
hammerdwn's Avatar
Quoted: 170 Post(s)
Liked: 52
I'm not familiar with European models, but a quick google says that's not an LCD/DLP. Suggest you post pictures of this black spot
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is offline
post #3 of 3 Old 01-30-2009, 12:11 PM - Thread Starter
Hi hammerdwn, my problem was in the beginning that a quick google said on dozens of pages nothing more then "BUY LAMP NOW".
After a longer google I was able to download the service manual ( www chris-electronics.iuliman dot com is an excellent resource, maybe use translate.google)
under the chassis reference PLT51A. It says: p-Si active matrix LCD
BTW what other kind of TV sets could use a lamp?
anyways, now that I have the manual I am going to have a look at the optics and LCD. Thanks for your suggestion, I will do so if I get stuck!
Reply Rear Projection Units
