Sony KDF-60XS955 turning on and off by itself? - AVS Forum | Home Theater Discussions And Reviews
Old 02-26-2009, 08:34 PM - Thread Starter
AsahiToro's Avatar
My Sony KDF-60XS955 is about three years old and I'm having problems with the set turning itself off by itself. After several seconds it will turn itself back on. It started doing this about six months ago for about two weeks and then worked fine for another month or so. Recently, it started it again and is doing it constantly. Could just a simple bulb replacement fix this? The bulb light on the front isn't coming on when it does this, just the standby light flashes. I tried unplugging the power strip which it is attached to for anout 10 minutes and that didn't help. Do I need to actually have to unplug the set from the power strip to hard reset it?
Any help and advice would be appreciated.
AsahiToro is offline
Old 02-26-2009, 09:24 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
Three years... replace the lamp.
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is offline
Old 02-26-2009, 09:28 PM - Thread Starter
AsahiToro's Avatar
I have one on order. I'm sure it needs it but I'm wondering if this alone will solve my problem?
Thanks again.
