Toshiba 50hm67 bulb burst - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-28-2009, 10:12 PM - Thread Starter
simplyxtrippin's Avatar
I bought this tv about a year or two ago. Today, my sister said that she heard a little pop from the tv and the picture stopped but the audio still ok. This is already out of the manufacture warranty. The blue and red light was flashing in the front which means according to the manual: "abnormal operation of busline. (light engine)." So the popped the cover for the lap and pulled it out. The glass part inside the buld itself has shattered. There is no burn marks. The outlet block that the TV was connected to didn't have surge protection.
Could this burst lamp be caused by a surge or just the TV being used alot (about 12 hrs/day) or could there be something wrong else do with the TV? Should I just buy a bulb and hope that nothing's wrong with TV that'll cause the new lamp to burst aswell?
I checked the website that the manual referred to (ceaccessories.toshiba. com). The price is about $220. Is there a place that you guys prefer? Hopefully something cheaper. How many hours are the lifetime of these lamps? Where do you guys buy your replacement lamps?
simplyxtrippin is offline
post #2 of 2 Old 03-01-2009, 08:46 PM - Thread Starter
I just thought about this. The red and blue light blinks because of "abnormal operation of busline. (light engine)." Would that mean that I have to replace that somethings wrong with the light engine before i change the bulb? would a broken bulb cause the red and blue light to blink.
Another info: after the picture went, i plugged and replugged the power cord to reset the tv. WHen i did this it still didn't have a picture and i can still hear the sound. The thing is that the blue light was on and it took several minutes for the red and blue light to start blinking again. Could that have meant anything?
Reply Rear Projection Units
