Official 2008 Samsung HL61A750/HL67A750 LED DLP Settings and Calibration Thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
post #541 of 567 Old 03-21-2010, 08:44 AM
Lee Bailey's Avatar
Yes, that is about right. To make it lower, you will be crushing blacks.
Lee Bailey is offline
post #542 of 567 Old 03-25-2010, 08:42 PM
BigSteve82's Avatar
Quoted: 90 Post(s)
Liked: 32
(Stupid?)Question: Will a POWER OUTAGE ever affect the SM settings after they've been saved?
I have Lee's settings and my power went out here due to a storm and was out for about 2hrs or so before coming back on. The TV still looks a little off compared to what it did (I believe), but I didn't enter the SM to verify it.
Just wondering if the SM will ever go back to default after being unplugged/without power for an extended period of time and, if so, how long before that happens.
4K/HDR Display: Vizio M70-D3 | Receiver: Yamaha Aventage RX-A3000
Speakers: Definitive Tech BP8B (Front) / CLR2002 (Center) / ProMonitor1000 (Rear+Height) / HSU VTF-2 MK4 (Sub)
Media Players: Xbox One S / PlayStation 4 / Chromecast / Amazon Fire TV Stick (Kodi)
Remotes: Vizio Tablet / Harmony One+ | HDMI Cables: Monoprice "Certified Premium" 18Gbs
BigSteve82 is offline
post #543 of 567 Old 03-26-2010, 06:33 AM
rahull's Avatar
The service menu shouldn't unless you do a reset. The user menu will
however .
rahull is offline
post #544 of 567 Old 03-26-2010, 11:56 AM
BigSteve82's Avatar
Quoted: 90 Post(s)
Liked: 32
however .
Alright, thanks! I don't guess it was off long enough to reset the user menus as all my settings were still in there. Anyone know the time it takes to be without power before the UM resets?
post #545 of 567 Old 03-26-2010, 01:23 PM
rahull's Avatar
As soon as it turns off either by you or power loss. It will go to dynamic and default settings.
rahull is offline
post #546 of 567 Old 03-26-2010, 02:42 PM
BigSteve82's Avatar
Quoted: 90 Post(s)
Liked: 32
So you're saying it defaults to the factory settings immediately upon power loss or being unplugged? That definitely wasn't the case here as it was without power for over 2hrs and retained all my UM settings once the power came back on. My previous TV would retain the settings for 24hrs with no power, was just curious about this one and the SM settings.
post #547 of 567 Old 03-27-2010, 07:47 AM
rahull's Avatar
Depends on your settings. If using CALIBRATE mode settings don't
change as all settings are locked in the SERVICE MENU when selecting
CALIBRATE in SERVICE MENU'S EXPERT SETTING menu. Otherwise
it changes to DYNAMIC'S default when power on. Forgot you said you
were using Lee's settings which is CALIBRATE. Settings won't change.
rahull is offline
post #548 of 567 Old 06-29-2011, 10:37 AM
jkeener71's Avatar
Quoted: 16 Post(s)
I got a High-end PC with Dual Geforce 295 in sli using updated nvidia drivers...
Anyways I noticed calibrations and recommended settings, but didn't really see anything for PC (except someone mentioning to used HDMI 3 and change source name to "PC").
Anyways, I'm sure some of you use this TV as your Media Center and/or PC. So any recommended settings, etc would be great.
NOTE: If there is a better thread I should post this, please let me know.
Vizio p702ui-b3 UHDTV | Onkyo TX-NR636 4K 7.2 A/V Receiver | BIC America Formula F-12 Sub | JBL Studio Speakers 190x2 (F), 180x2(S), 130x2 (RS), 120c (C) | ASROCK Z87 | I7-4770K @ 4.5Ghz | MSI Nvidia GTX 970 Gaming 4G | Windows 10 64bit | PS4 XBox1 WiiU
jkeener71 is offline
post #549 of 567 Old 06-29-2011, 03:58 PM
Dominic26's Avatar
Quoted: 55 Post(s)
There is another thread called "2008 Samsung HL61A750 LED DLP Owners Thread and FAQ". It is more active at this point.
Dominic26 is offline
post #550 of 567 Old 06-30-2011, 05:13 AM
Low Tech's Avatar
I posted a thread on undocumented 75hz settings with 750A1F DLP.
You must use the DB15 connector, As HDMI is limited and you do not need to change the name with the HDMI3 port.
You can use 75hz on most all the resolutions given on the VGA connector.
Though the DLP will not allow 75hz on 1920x1080 mode for some reason.
I tried to get 720 to work as an undocumented feature, it seems locked out.
So all other modes available for VGA do seem to work well with 75hz.
It seems that the tv is not... Repeat! Not down converting 75hz signal into 60hz.
So Euro Bluray will be played back in proper scan rate.
I ordered Dark Night in bluray from the UK and will test.
So far the highest resolution I can obtain at 75hz is, 1360x1024.
It will allow for proper scan line playback as Euro content has more scan lines.
I think this is an undocumented feature for US model DLPs, that may allow for Non region A Bluray content to play through computers properly.
Yes, my 2010 Panasonic 42C2 performs better than an S2 No floating blacks and keeps the lowest black levels.
Low Tech is offline
post #551 of 567 Old 06-30-2011, 03:18 PM
jkeener71's Avatar
Quoted: 16 Post(s)
I tried this resolution, had to do custom resolution. When I test it...
I just get, "MODE NOT SUPPORTED"
then it reverts back to 1920 x 1080. I'm using the Nvidia Control Panel software (newest geforce drivers).
post #552 of 567 Old 07-02-2011, 06:03 AM
Low Tech's Avatar
Ummm I thought you were doing 1280x1024.
The 1360x768 works fine, and is the equivelent of 720p in aspect ratio in PC mode.
Though all US resolutions for video standards are locked at 30 and 60hz.
All Euro resolutions can be set to 75hz.
Low Tech is offline
post #553 of 567 Old 11-07-2012, 12:04 PM
johnnywyoming's Avatar
I am reading the Greyscale and Color Calibration for Dummies info from curtpalme.com and plan to preform this calibration on my system after receiving my Oppo 103. Greyscale adjustment controls in the instructions are called RGBLowEnd, and RGBHighEnd. Does anyone know what the equivalent controls are named on the Sammy?
Samsung HL61A750
Harman Kardon AVR520
Oppo BDP-103
Dynaco A35 fronts
Wharfedale WH-2 Center with dipole rears
Wharfedale Diamond 10.SX sub
johnnywyoming is offline
post #554 of 567 Old 02-16-2013, 08:14 AM
jcampanella's Avatar
Hello,
I have a HL67A750. I have had it for about 5 years now. It has always had an awesome picture, I followed the calibration on this site when I got it 5 years ago. However, lately is seems to have taken on a purple hue. I really notice it in the whites on the screens (like lettering) and in peoples faces on close ups. I have messed around with some of the basic settings and nothing seems to effect it. Anyone else experienced this problem? Thanks.
jcampanella is offline
post #555 of 567 Old 10-18-2013, 01:03 PM
jeffbon's Avatar
I bought my Samsung 67" HL67A750 LED DLP in March 2009. In early 2013, it developed the left side shadow due to bad light tunnel.
Samsung replaced the entire light engine with a new one on 5/30/13. Problem solved.
Sometime in August 2013, I saw these on the screen:
I have left several phone messages with the authorized Samsung repair shop that installed the new engine and they don't return my calls.
Does anyone know what these circles are?
jeffbon is offline
post #556 of 567 Old 10-26-2013, 09:10 PM
Just4Kicks's Avatar
I had this same problem with my first Samsung DLP HDTV, HL-R5688. Instead of circles, mine had rounded edge rectangles. The Samsung tech deemed it a light engine leak issue and replaced the light engine--under warranty.
Just4Kicks is offline
post #557 of 567 Old 10-27-2013, 07:18 PM
Just4Kicks's Avatar
I just got done with my annual LED Light Assembly cleaning. I was surprised to see very little dust, especially on the red LED cooling fins which typically has had more dust than the green or blue.
post #558 of 567 Old 09-13-2014, 02:30 PM
DeathStalker77's Avatar
Question Aligning The Picture
Hello all!
I had to replace the motherboard and fans on my unit (I have a 61 & a 67) and have not been able to get the picture re-aligned - I can get to the service menus, but am unable to figure out how to get everything aligned. So my 61 has just been sitting unused Now the DLP chip in my 67 is going out and I figure I might as well try spending $200 to replace it, as opposed to spending ~$3k on a new tv.
Can anyone provide specific instructions (or videos) on how to properly align these sets? I have a copy of the service manual (thanks for the link in an earlier post!), but I just can't seem to figure things out - it's not the colors, but the alignment.
Thanks SO much for any assistance!
DeathStalker77 is offline
post #559 of 567 Old 11-22-2014, 05:52 AM
Laramie55's Avatar
Overscan Adjustment through Service Menu
Hi, Glad to see this thread is alive and well since my HL61A750 still is. I replaced my DMD chip recently and it seems I have greater overscan than before. I re-did the install but it remains the same. I have searched the forum and gone page-by-page through this thread and the one related to the Owner's Manual without finding any mention of the ability to use the service menu to adjust picture size or influence overscan. Is this not possible?
Thanks for being here.
Laramie55 is offline
post #560 of 567 Old 12-27-2014, 07:30 PM
keltraine's Avatar
Overscan here too...
Hmm, I too have noticed overscan on certain sources and never thought about fixing it through the service menu-would love to know how too please!
Or would it be better to ask in the owner's thread at?
2008 Samsung HL61A750 LED DLP owners thread and FAQ
keltraine is offline
post #561 of 567 Old 12-28-2014, 04:58 AM
Laramie55's Avatar
The reply I received in the service thread said it is not electronically adjustable. Mine seemed to change size after I swapped out the DMD board. These sets have some overscan right out of the box. If you have not replaced the DMD board and are straight from the factory you are probably as good as you're going to get.
post #562 of 567 Old 12-31-2014, 07:36 AM
agentrnge's Avatar
Quoted: 18 Post(s)
I've got a problem with my set. Its been this way since day one. The LED level controls do not work. There is no difference between low/med/max. I dismissed it and never worried about it, thinking it was a low impact setting that was not really noticeable to the eye. This was the case since I first turned on the TV. No difference after changing other failed/failing components.
Then I got an identical set used, and the LED level setting is very apparent.
Any ideas why this setting would not work?
I am running the TV in standard or movie mode. Never in auto/dynamic mode. I never use game/entertainment mode. ( although I did just try enableing/disabling it to see if it made any difference ).
Sorry its a cross post from a question I asked in the main user thread.
History on the set. Blue LED and the LED driver were replaced last year. DMD chip replaced a few months ago. Its been cleaned inside a few times. Arctic Silver on all heatsinks.
agentrnge is offline
post #563 of 567 Old 01-02-2015, 01:44 PM
audiocontr's Avatar
Question Sudden "solar" on 67A750
Folks, I LOVE my 67. Still love it almost 6 years later - and I now have my first issue. Does anyone know what would cause the attached image? At first i thought it was a general failure of red and blue, but the menu text is perfect, just the image appears all "wonky".
I'm pretty handy with electronics. I can gt my hands pretty dirty on this one if you have any suggestions.
audiocontr is offline
post #564 of 567 Old 01-04-2015, 08:01 AM
Lee Bailey's Avatar
The DMD board may have different dimensions for the height of the DMD panel on the board itself. You would have to compare the two boards. Sounds like the chip is now closer to the screen, thus the increase in overscan. You could try some spacers between the DMD board and the mounting plate, shimming it back. Though you will need to readjust the focus after that.
There's also the question of any grounding the board may have with the chassis if you shim it.
post #565 of 567 Old 01-04-2015, 08:04 AM
Lee Bailey's Avatar
Thumbs up
That looks like something going on with that particular HDMI input, cable, or the source.
I get that when my Darbee decides to freak out every once in a while.
BTW, the Darbee unit works great with this TV....
post #566 of 567 Old 01-04-2015, 12:14 PM
audiocontr's Avatar
i appreciate the response. sadly it happens on every source, including VGA
post #567 of 567 Old 01-07-2015, 11:50 AM
audiocontr's Avatar
Tech says its the "optical Block" which is no longer available. Any advice on finding one?
Reply Rear Projection Units
