Mitsubishi 2007 (and possibility '06 & '08) lens cleaning procedure. No more halo's. - Page 15 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #421 of 422 Old 08-15-2017, 01:34 AM
Augerhandle's Avatar
Quoted: 877 Post(s)
Liked: 808
Originally Posted by GenTarkin View Post
Also, you are incorrect about the bulb - I purchased the original OSRAM bulb which Im pretty sure is(at least I think the original is a OSRAM PVIP... maybe its a neolux of phillips but I read those are inferior):
http://www.shopjimmy.com/osram-p-vip...rrp-e022-4.htm
I could see no discernible difference in light output after powering it on vs the old one that has about 5k hours on it
... so I put the original one back in and will use it till it dies.
That's the point. A lamp with 5000 hours on it will be dimmer than a new lamp. You should see a markedly brighter picture with the new lamp. But you didn't. And if your current lamp is working fine, there's no reason to buy a new one. It will sit in the closet until the warranty expires.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #422 of 422 Old 08-15-2017, 07:41 AM
GenTarkin's Avatar
OK.... I dont know how that was ur point in your original reply to my post, because ur post spoke pointed at my new bulb being a cheap knockoff =P
My original stock bulb just seems to have a good life so far, still putting out as much light as a new genuine OSRAM bulb =)
I decided to buy the new bulb because my original one is getting long in the tooth and expected it to be dimmer and die at any time sooner rather than later. But given the new bulb is same light output, its now a backup I have on hand for when the original does blow up =)
And dang, Im loving the blacks again with this new DMD....!
GenTarkin is offline
Reply Rear Projection Units
