HELP PLS: Mitsubishi ws-65513 reset code - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-20-2009, 10:26 PM - Thread Starter
soleful247's Avatar
i am in need of the reset code for a mitsubishi ws-65513. If you have it or know where I can find this code, please let me know.
Any information is more than appreciated.
Thanks in advanced!
soleful247 is offline
post #2 of 4 Old 05-21-2009, 07:17 AM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
MENU 0370, select Initial press enter, wait for it to finish, press RESET on front panel.
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is offline
post #3 of 4 Old 05-21-2009, 07:35 AM - Thread Starter
soleful247's Avatar
^^^ Thank you very much.
The TV is at my fiance's house. I will try it later today, and I'll let you if it works. Thank you!
post #4 of 4 Old 05-21-2009, 07:37 AM - Thread Starter
soleful247's Avatar
BTW, You also gave me the code for my Mitsubishi 73" last month when I had the same problem!!
You my friend, are a life saver!
Reply Rear Projection Units
