Would It Be Easy To Remove The Screen From A DLP HDTV without breaking anything? - AVS Forum | Home Theater Discussions And Reviews
Old 07-27-2009, 02:41 AM - Thread Starter
MTyson's Avatar
I saw a thread where a guy with an LCD rear projection tv took off his screen and rear projected a 100" screen and it stayed in sharp focus by adding about a foot or so of distance (perhaps the super short throw lens allowed this to be possible), so I'm interested in trying this out, but was wondering if the screen would come off easy and if it could be put back on it if didn't work out.
I'm looking at a Mitsubishi WD65C9 65" C9 Series DLP
MTyson is offline
Old 07-27-2009, 07:55 PM
dssturbo1's Avatar
the front screen on the mits wd 52/62x25 series models come off pretty easily, about ~10 screws and unplug a front panel connector then a little tilt forward and pull up and out no problem.
....... thankfully because it gets so much dust on the lower internal mirror that the owner needs to clean it 1-2 times a year.
HD HD HD I Need more HD, Yes I am a HD Addict :)
dssturbo1 is offline
Old 07-28-2009, 01:56 AM - Thread Starter
MTyson's Avatar
Is there anyway you find out if the text/image stays in focus when projected onto a piece of paper from a foot, two feet and further? I really need to know if the image will stay relatively in focus from a distance of 1-3 feet and when it start to loose too much focus. If texts looses a little focus it's ok, as long as it's not blurry. I'd love to know at how many feet away it starts to lose too much focus.
I'd GREATLY appreciate it if you could do this for me sometime when you open it again or if you don't mind just opening it to test this out for me that would be awesome. I'm thinking of plunking down $1,400 for a set to use it as a giant rear projector and I'd hate for it to be a complete waste.
MTyson is offline
Old 07-28-2009, 11:39 PM
dssturbo1's Avatar
sorry it is in the local shop being repaired.......for the past 2+ months.
Old 07-29-2009, 07:57 AM
walford's Avatar
AS DLP RPTV image may not expand as the distance from the rear mirror increasesd the way the LCD RPTV model you read about did.
Another concern is can the bulb provide enough ouput for you to be able view the images on the screen size you are considering.
walford is offline
Old 07-31-2009, 08:16 PM - Thread Starter
MTyson's Avatar
It should expand fine if it uses an optical lens at all like the LCD rear projections sets do. The light output should be fine. The sets are generally very bright even with a lot of ambient light, so 110" on a 1.8 gain dark gray screen should be ok. I tried it with my CRT HDTV, which are the least bright (but highest contrast) and it was decent brightness on my screen with dimmed lights or off. DLP should be ok.
Grrr. I really wish I could find a way to test this out with DLP. I'd much rather not have to go LCD to do it, especially and older LCD. If anyone will test this out for me on a newer 1080p I will pay $5.00 via Paypal!
MTyson is offline
