R60XBR1 Lamp Cooling Fan - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 08-16-2009, 07:57 PM - Thread Starter
dmen09's Avatar
New to this forum. My R60XBR1 just shut off and started displaying the 4 red blinking Standby lights. After some researching, it said it has to do with fans. I found that it was the fan to cool the lamp. One forum suggested I nudge the non-spinning fan to get it started. That did work for about 5 minutes and then shut off again. I'm fairly certain its this fan. I did some searching for parts and found a Sony 883586011 Lamp DC Fan Motor on Partstore.com. I removed the fan to verify and all I can find on my fan is that its an Airflex Model SFF21C 12 VDC 0.24A. Are these the same thing? If not, can someone verify if the fan I'm looking at is the problem based on my info? Any ideas on where I can purchase this fan? In most of my searches for the Airflex fan, it gives me results for forums. Thanks.
DMen09
dmen09 is offline
Reply Rear Projection Units
