Mitsu WS-55411 Medallion 1080i Settings - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-23-2009, 08:57 AM - Thread Starter
weitj's Avatar
Hi Everyone,
I just got a rear projection tv Mitsubishi WS-55411 Medallion HD1080i. I turned on the set and it looks pretty good. I played around with the convergence settings and the color balance etc. The one thing I noticed right away is the overscan or picture cropping that happens. I'm estimating around 5% of the picture left and right gets cut off. About 3% up and down. I looked everywhere and couldn't find any controls that would seem to help the overscanning. I tried with AV cords as well as the Component cords and both inputs have the overscanning. Also, the picture seems a little low on the centering.
I contacted a local theater room shop and the guy there told me to mess around with the format button on the remote (cycles between zoomed, stretched, standard, etc views) and that of course did nothing.
So here are my questions:
1. Would getting into the "service menu" get me some controls that can fix the overscanning? How can I get into the service menu?
2. I can't seem to find a tv calibration service that can answer my question of fixing overscanning. I noticed that Best Buy's Geek Squad offers TV Calibration. Are they a good vendor for fixing overscanning? I don't care as much about the picture settings as the overscanning.
3. Is there a dtv tuner that has allows horizontal and vertical picture adjustment so that I can just plug everything through that? I was thinking if I can get a dtv tuner that has adjustments that allow to shrink the picture to size of the tv, that would work also.
Thank you so much in advanced,
Tim
weitj is offline
post #2 of 3 Old 09-23-2009, 09:05 AM
lcaillo's Avatar
You can reduce the overscan some in the service mode, but you will have to do extensive geometry and convergence correction if you do so. Some have shifted the lens bulkhead or individual CRTs closer to the mirror to reduce overscan, but this often leaves phosphor wear areas surrounded by clean phosphor if you are not careful about maintaining angular relationships or go too far. The calibration professional who will be able to do these things effectively is rare, and the service tech is even more rare. Look for Mr. Bob's discussions of CRT based RPTV. There are some extensive threads on the matter.
Where are you located?
Yes, calibration is important...every user should be calibrated.
Need electronics repair? A great place to start looking for a shop in your area: http://www.tvrepairpros.com/
lcaillo is offline
post #3 of 3 Old 09-23-2009, 09:13 AM - Thread Starter
weitj's Avatar
Hi Icaillo,
Thank you for the quick reply! I'm located in Saint Louis, MO. I'll have to look for the ubiquitous Mr. Bob. I've seen his postings but didn't understand all of it. I was hoping to not "physically" change the guts of the unit. My wife had me haul this beast upstairs and I'd imagine if I break it, it'd be a longer haul down the stairs. It sounds like the best course of action is to just live with the overscaning. Would that be your advice?
Thanks again, Tim
weitj is offline
Reply Rear Projection Units
