Hitachi 57F510 Image Problems - Help! - AVS Forum | Home Theater Discussions And Reviews
Old 01-04-2010, 09:42 AM - Thread Starter
jds22's Avatar
This may have been covered in another thread, if so, I apologize for the repost.
I am getting crooked lines down the sides of my screen and some periodic discoloration going across the screen.
Notice how crooked the image is. This seems to be only happening on the side of the screen. The middle section seems to be fine.
Any ideas on what might be causing this? BTW, the set is either 6 or 7 years old, not exactly sure.
jds22 is offline
Old 01-05-2010, 08:58 AM - Thread Starter
jds22's Avatar
jds22 is offline
Old 01-05-2010, 05:37 PM
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
Originally Posted by jds22 View Post
I would go in to the DCAM mode and check that your three colors, green, blue and red are straight. It looks as if your main DCAM grid is not straight thus producing what you see.
Doing magic focus will not correct this unless you first correct it through DCAM adjustment and write it into memory, then magic focus may correct minor DCAM adjustments.
RPCRT-TV Overscan Reduction
Reference Blu-Ray Demo Disc
superleo is offline
Old 01-06-2010, 05:14 AM - Thread Starter
jds22's Avatar
I'll give that a try tonight.
jds22 is offline
