Any Chicago area DLP repair shop recommendations? - AVS Forum
post #1 of 5 Old 03-04-2010, 08:52 AM - Thread Starter
flc224's Avatar
I now have a shadow in the lower left corner of my screen and believe it *might* be light tunnel related. I saw someone in Naperville had used a shop in West Chicago but, I live out of their service area (Oak Park). Does anyone have experience with shops in Chicago that will travel to Oak Park to repair my 61" Samsung DLP? Thanks.
flc224 is offline
post #2 of 5 Old 04-04-2010, 02:47 PM
Splicer010's Avatar
Liked: 32
It might be cheaper to replace the light engine yourself. Depends on the cost of the LE and the model of TV. For example. I had the same issue with my old LE for my DLP (shadow, lower left corner) and found new replacement LE for $180 shipped. You can try this place:
http://www.moduslinkptstvboards.com/Default.aspx
They can also repair your LE if they don't have one in stock. Good luck.
Splicer010 is offline
post #3 of 5 Old 04-04-2010, 09:22 PM
martinb60302's Avatar
There's a company I use give them a try Certified Electronics 708-863-5500 there in Lyons,IL
Good Luck
martinb60302 is offline
post #4 of 5 Old 04-04-2010, 09:56 PM
Splicer010's Avatar
Liked: 32
Lyons will go to Oak Park? Thats a cruise. Bet they charge for travel.
post #5 of 5 Old 04-05-2010, 07:44 AM
mes444's Avatar
If it's the light tunnel collapse, call Samsung CS first and give them your model number. I think they are still repairing it, even out of warranty, for free.
mes444 is offline
Reply Rear Projection Units
User Tag List
