Mitsu wd-52525 - green wavy lines - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-20-2010, 10:19 AM - Thread Starter
frankmanic's Avatar
Hi all, my 52 inch Mitsubishi DLP went on the blink Friday evening - was fine Thursday night then turned it on Friday evening and no picture - just a lot of green wavy horizantal lines - I can hear the audio and the device manager and setting controls worked fine.
When I tried some of the other devices inputs I got a light blue screen with a round faded circle in the middle of the screen - I usually got a darker blue screen when there is no input. I tried input 3 where my DVD player is connected and got nothing. I also tried the front A/V inputs and those did not work either. I connected the satellite box to another TV and that worked fine so i know it's not my Direct TV box. My TV is a little over 5 years old and I replaced the lamp last March. I'll also mentione that the picture quality has been looking washed out and faded lately.
Any ideas what it could be? and/or what type of cost I'm looking at to fix?
also, how much in general would/should a service tech charge to come out and tell me my set is broken?
thanks in advance!!
one other note - this morning (saturday) - i turned it on and now my lamp button turns red after the initial power button blinks green for a few seconds - now can't hear any audio and none of the device/setting functions work - i pulled the lamp cartridge andit looks fine (not burned out like my last lamp) - could a lamp relacement fix all the issues I have???
frankmanic is offline
post #2 of 3 Old 03-27-2010, 09:47 AM
videobruce's Avatar
Quoted: 607 Post(s)
Liked: 247
If it isn't the lamp, then it's the ballast, but sounds as there are other issues.
Do you have the service manual, if not;
http://www.e-servicemanuals.com/prod...d_id=392552525
http://cgi.ebay.com/Mitsubishi-WD-52...-/130261225802
Or here for free;
http://search-manual-online.com/down...01hbnVhbC5wZGY
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is online now
post #3 of 3 Old 03-28-2010, 02:39 AM
dssturbo1's Avatar
almost a guarantee with this set that your capacitors/electrical chassis are failing. very very common issue with the mits WD 52/62x25 sets.
IF you want to get it repaired it will cost ~$200-300 in labor to a local mits service tech center and you get a 1 year warranty through Mits USA. go to the owners thread and get more help.
http://www.avsforum.com/avs-vb/showt...44566&page=234
HD HD HD I Need more HD, Yes I am a HD Addict :)
dssturbo1 is offline
Reply Rear Projection Units
