Changing Ballasts between LCD-RPTV's ??? - AVS Forum | Home Theater Discussions And Reviews
Old 07-18-2010, 03:19 PM - Thread Starter
benrules92's Avatar
So I have a bunch of old LCD projection TV parts,,, I have a few balasts from sony and hitachi TV's that seem to be of the same make,
My problem today is I have an LG RU-52SZ30, and I have broken it down to having a bad ballast, I have a couple other ballasts that have the same ratings, anyone have any experience switching ballast's between TV's ???
benrules92 is offline
Old 07-18-2010, 04:41 PM - Thread Starter
benrules92's Avatar
What parts in the ballast usually cause failure, could I possibly just switch parts between balasts?
Old 07-18-2010, 10:43 PM - Thread Starter
benrules92's Avatar
Ok so I have decided to try and fix the original ballast from the TV first, I tested all the resistors and 1 doesn't read anything with my tester. there is also an unmarked thing that looks like a resistor or diode that doesn't read anything when tested.
<---- white unmarked thing that doesn't register
<---- blue resistor that doesn't register
The color code on the resistor says its 46ohm
and for the white thing that looks like a resistor or diode could that be a thermal fuse ??
Any help on this would be awsome
Old 07-26-2010, 02:52 PM
darstr's Avatar
You are correct in noticing different MFG's use the same ballast, but I would not swap any ballast, unless I knew for a fact that it is the same. There can be many little differences that could cause you major head aches. Plus you can by ballasts now dirt cheap. Just shop around
darstr is offline
