mitsubishi 82 dlp tv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-18-2010, 03:24 PM - Thread Starter
destiny 21's Avatar
Quoted: 12 Post(s)
i am looking to get the mits 82 inch dlp. i am getting it to watch 3d content. i already have a panasonic 3d bluray playr two pair of xpand 102 glasses. question should i buy the newest 82 inch or should i get last years model and save some money. also do these tv s make any fan noise when cooling the bulb had a jvc thet was kind of loud when on.
destiny 21 is offline
post #2 of 2 Old 07-18-2010, 05:33 PM
gtgray's Avatar
Quoted: 220 Post(s)
Liked: 144
On my 2009 set you can really only hear the fan when you are behind the set. It is the quietest of several DLPs set I have owned. As for whether you should buy a 2010, or a 2009.. I don't know. The 2010 is supposed to get update firmware that will support most if not all the 3D formats without an adapter.
Samsung 78" JS8600, Mits WD-92840 43" Samsung 43ku7000 - Lumagen Radiance XS, Martin Logan Motion 40s, Ascend Sierra 2s
58" Panny Plasma -DVDO DUO, Usher S520, JBL HLS-610, Definitive SM45, MusicHall Marimba
gtgray is online now
Reply Rear Projection Units
