Panasonic PT-50LC13 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-27-2010, 10:52 AM - Thread Starter
jailbird2's Avatar
I have an issue with my Panasonic PT-50LC13 RP LCD TV.
When you turn it on, it shuts off. Looking up the blink code in the service manual, the code means that FAN1, FAN2, or FAN3 is stopped. The TV eventually can be coaxed back on, however.
I opened the TV and took a quick look. Without pulling it apart (again, I've already had to fix the ballast), I can easily see that FAN3 & FAN4 are working. That just leaves FAN1 & FAN2. Both of those appear to be inside the Projection Unit.
The service manual says to replace the entire projection unit (LSXA0528-HBS). Those run $225+ just for a refurbished unit. To mean it seems stupid to replace the entire projection unit just for a <$20 fan!
Is there any sane reason I can't just replace the fan on the unit? I've never opened it up, so is there a concern for dust contamination or something? If it's possible to replace, does anybody happen to know the model #s of the fans inside the unit? I hate to tear it all apart to just get the #, put it all back while the parts get shipped, and then tear it all apart again.
jailbird2 is offline
post #2 of 6 Old 07-29-2010, 10:22 AM
tomwil's Avatar
Liked: 26
FAN 2 is part number L6FAKCDH0007, the same as FAN 4.
FAN 1 is enclosed in FAN CASE UNIT part number LSXA0519, and appears that this fan is not available separately.
This is derived from the service manual, section 16.2.
That which may be known of God is evident within man, for God has shown it to them, so that they are without excuse. (Romans 1:19-20)
tomwil is offline
post #3 of 6 Old 08-10-2010, 07:38 PM
marceloendler's Avatar
HI!
I just found a Panasonic HDTV PT-50LC13-K in the garbage!! When I turn it on, there is a blue screen saying I need to replace the tv lamp. What part of the Tv is the lamp located at and where to I have to start opening to get to it?
Thank you!
Marcelo
marceloendler is offline
post #4 of 6 Old 08-11-2010, 07:48 AM
tomwil's Avatar
Liked: 26
The TY-LA1000 lamp replacement instructions for the PT-50LC13 can be found here.
You can try to reset the lamp timer to remove that blue screen message, and get extra life out of the current lamp that is already installed.
tomwil is offline
post #5 of 6 Old 09-01-2012, 08:56 AM
PANA PT50LC13's Avatar
Was was the end repair your made on your set?
I have the same problem. Cooling fan not working correctly .
I really think this was an intentional design flaw so keep repair man working!
PANA PT50LC13 is offline
post #6 of 6 Old 10-12-2012, 03:38 AM
mr266's Avatar
Quoted: 122 Post(s)
Liked: 733
I'm also curious as to the outcome as I have the same problem. It's actually easier to just keep the darn thing on all the time. The picture is still outstanding on mine though.
WDTV Live SMP with WD EX4100 NAS
Polk RTI8 Front, Polk CSI5 Center, Polk RTI4 Surround
MTX SW2 12” SUB, Sharp AQUOS LC-70C6400U
URC-WR7 Universal Remote
Motorola QIP7232 (P2) FIOS DVR, Sony BDP-S590 Blu Ray Player
Marantz SR5010 AVR,Technics SL-B20 Turntable
mr266 is offline
Reply Rear Projection Units
Panasonic
