The Defective Mitsubishi DLP TV Owners Thread - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #211 of 365 Old 04-27-2013, 08:30 AM
Starquester's Avatar
My 65734's lamp went out at 14930 hours, just replaced it with an $85 Phillips unit yesterday.
YMMV I suppose.
Starquester is offline
post #212 of 365 Old 04-27-2013, 02:37 PM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
YMMV I suppose.
That is excellent life out of it. I buy the Osram lamps and I usually get about 4800 hours out of them before they start flickering. I replace mine when they begin to flicker instead of going out completely. Maybe I'll try the Philips next, but I JUST installed my 3rd lamp and STILL have a 4th backup Osram lamp waiting. I'm sure the two used lamps I have are still good for 2000 more hours, but letting them flicker might damage the ballast.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #213 of 365 Old 04-28-2013, 11:10 AM
krayziekmf's Avatar
YMMV I suppose.
Does everyone just buy replacement bulbs on ebay? I am not sure I want to spend $120 to get one from mitsubishi if they have phillips / osram lamps on ebay for $85. I have a wd-73c9. Thanks.
krayziekmf is offline
post #214 of 365 Old 04-28-2013, 08:14 PM
ChuckF.'s Avatar
Both Osram and Philips make fine lamps, just don't buy the $38 Chinese knockoffs.
A couple recommended sellers: Dynamic Lamps on Amazon: http://www.amazon.com/shops/dynamiclamps and Nio on eBay: http://stores.ebay.com/neilampsandelectronics
ChuckF. is offline
post #215 of 365 Old 04-29-2013, 06:30 PM
krayziekmf's Avatar
Thanks! I picked up a Philips lamp.
post #216 of 365 Old 06-18-2013, 07:41 AM
UncleM's Avatar
Mitsubishi WD-57831 DLP -- I'm blessed with what looks like a NEW PROBLEM with this set. No references to it here in our forum.
The set has stopped responding to ANY remote commands - on/off, volume, nothing happens.
Remote has always worked fine until I powered system down last night. Cable, soundbar, video processor (DVDO Duo) all powered off as normal but TV went to blue screen. Had to power off with front panel power button. Powered TV on the same way this morning.
I tried Reset - no luck.
Recycled power (unplugged) - nothing
Has anyone had or heard of this problem with the Mits DLP? Any suggestions about what's wrong or how to determine the problem?
It's the Amps!
UncleM is offline
post #217 of 365 Old 07-28-2013, 06:57 PM
onedummy's Avatar
Mitsubishi WD-65734 - Not sure if I'm posting this in the correct place or not. I had to replace my color wheel a couple of years ago. Thank goodness I had an extended warranty on my unit. I'm having a new problem arise. Across the top left side of the screen I'm seeing what is like a rainbow effect across the screen surrounded by darker shades. I've had to replace the bulb a couple of times on this tv and had saved my last bulb that didn't completely blow. I put in my old bulb and I'm getting the same rainbow line across the screen. I thought the bulb I was using might need to be replaced.? Could the lens need cleaning? Anyone have any suggestions or direction as to where I could look for a possible solution?
Thanks for your time.
onedummy is offline
post #218 of 365 Old 08-20-2013, 06:35 PM
Corey Anderson's Avatar
Don't pay more than $60 for a lamp with housing. Just search for the part number on eBay and they come up in spades. I've used them for a bunch of different TVs and always had great luck.
I just bought one for my particular DLP model, literally 10 minutes ago for $34 shipped, including CA sales tax from a very reputable seller.
Corey Anderson is offline
post #219 of 365 Old 08-20-2013, 09:08 PM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
Unless those are OEM lamps you're finding, that's not good advice considering all the negative consequences people have reported by using non OEM lamps.
colour is offline
post #220 of 365 Old 08-21-2013, 04:27 AM
Augerhandle's Avatar
Quoted: 747 Post(s)
Liked: 649
Your first post? Hmmmm.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #221 of 365 Old 08-23-2013, 07:55 PM
osu1991's Avatar
Quoted: 123 Post(s)
Liked: 74
My first non oem lamp lasted approximately 3 months, and the replacement was dead on arrival. Went with an oem after that and it's been going strong now 8 months, unfortunately I got the white and black dot disease a couple of weeks ago. I ordered the chip online for 180.00 and it took about 25-30 mins to install in my WD60735 and now my picture once again looks awesome.
osu1991 is offline
post #222 of 365 Old 08-25-2013, 12:58 PM
mits4me's Avatar
Well guys, lightning zapped what I think is my power board on my WD-65734. After looking all over the place for repair shops and not finding any, I have decided to just part out my tv. So if anyone needs a complete light engine for this tv along with a bulb that is about a year old but not a ton of use, email me at the address below or send me a p.m. My unit was manufactured in May 2007 and it has already had the DLP chip replaced under warranty for the white spot issue. I would be happy to send you pics of the unit. I'm not going to ask for a fortune; just a little to take the sting out of a new t.v. phishman000@aol.com And those are zeros at the end of my email, not the letter "o".
mits4me is offline
post #223 of 365 Old 09-06-2013, 07:24 PM
Paul Racke's Avatar
I have the Mitsubishi WD-65737. I purchased it back in June of 2010 and it worked fine until July of this year. The Bulb finally went out (really a lot of use on the bulb) so I was happy with that. Bought new OEM and put in. Now this past week or two I have noticed at various places around the screen a bright white dot. It started with one and now is up to five in a week. I have read all the problems everyone has had with the DLP Chip and want to know if Mitsubishi has sent any replacement chips to an individual to fix this problem for free? That is what I am trying to do now, due to the large number of complaints about this same issue.
I will let you know what Mitsu says about it.
Paul Racke is offline
post #224 of 365 Old 09-24-2013, 09:51 PM
Paul Racke's Avatar
I worked with Mitsubishi, who out of the kindest of their hearts, arranged to have a vendor come in and replace the DLP chip for a modest cost of $200.
They made me feel all warm and fuzzy by pointing out that the manufacturers warranty had expired, but they would do this just for me, send the chip to the vendor for FREE. All I have to do is pay the vendor to install it.
Now replacing the light is easy enough, however, I wasn't going to attempt replacing the DLP chip myself.
I accepted their offer and a week later the vendor came out and fixed it. All is good for now.
post #225 of 365 Old 10-14-2013, 10:22 AM
DANIELHMAN's Avatar
So I called the number 1-800-332-2119 and they are kind of good willing me the part. Forcing me to use a tv installer to put the chip in at an out of pocket cost of 200. Not exactly what I was hoping for and I did try and try to get them to send me the chip directly. It did not happen, but they are going to comp me a new bulb for the TV and are even going to allow me to install the bulb myself. I did have to ask about them letting me install the bulb and the guy said it was very easy so I did not need a tv installer. I said I know it is easy but so is installing the chip, and you are not letting me do that. I have had much better luck from other companies that have sold defective equipment and good willed parts like GE. Not sure if I would ever buy a mitsubishi tv again.
DANIELHMAN is offline
post #226 of 365 Old 03-20-2014, 05:54 PM
dlproswell's Avatar
I own a Mitsubishi DLP 65736, purchased it in 2008. We started getting white and black dots on our screen. After doing some internet research on what is causing the dots I found this page. I thought it would be a long shot to call Mitsubishi since the TV is 6 yrs old, out of warranty and low and behold my 5yr extended warranty expired Dec of 2013. Other than having a difficult time understanding the Mitsubishi customer support person, they agreed to order the part and have it sent to a local service center to have the part replaced. My cost would be 200.00  Calling Mitsubishi if you are having the white/black dot issues is worth it!  Their number is, 1-800-332-2119
old corps likes this.
dlproswell is offline
post #227 of 365 Old 03-21-2014, 04:57 PM
Quoted: 747 Post(s)
Liked: 649
Anyone Have Picture Problems after Mitsubishi DMD Chip Replacement?
See this thread. http://www.avsforum.com/t/1523680/anyone-have-picture-problems-after-mitsubishi-dmd-chip-replacement
I apologize for cross-posting, but I need feedback from others with new chips.
post #228 of 365 Old 04-22-2014, 06:08 PM
abi99's Avatar
I believe labor should not take more than 20 minutes once the technician begins the dissassembly process, so the $200 they are asking are really to cover the cost of the part, labor, and some profit too. Not worth it. I would never buy Mitsubish again, NEVER.
abi99 is offline
post #229 of 365 Old 04-23-2014, 01:39 PM
Quoted: 747 Post(s)
Liked: 649
The $200 needs to cover the technicians time not just at your place but the drive to and from, cost of the van, maintenance & insurance; the secretary's time spent setting up and scheduling the appointment; workmen's compensation, unemployment insurance, shop overhead such as rent, utilities and insurance; oh and yeah there's a little left over for profit to feed the kids.
post #230 of 365 Old 04-26-2014, 09:25 PM
leonExMits's Avatar
FYI, DMD chips made prior to Oct 2010 are subject to pixelization,a  known issue. Many manf provide FOC parts not sure about labor
leonExMits is offline
post #231 of 365 Old 05-28-2014, 11:01 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
Got off the phone earlier with Mitsubishi. Just like was discussed here, they are sending a new chip to be installed by a technician for $200. This is for my WD-65835.
Will update after the install.
Samsung PN64H5000 (recommended settings)
Denon AVR-X4000
A little R&R: Reaction Audio CX-10 (2) | Rythmik Audio F12 (2)
And a pair of Emotiva Airmotiv 5s
Soulburner is offline
post #232 of 365 Old 05-29-2014, 01:06 AM
Quoted: 747 Post(s)
Liked: 649
Please check for this problem after the chip is replaced
post #233 of 365 Old 05-29-2014, 01:46 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
I will definitely look for that. It should be very obvious to me.
Denon AVR-X4000
post #234 of 365 Old 06-03-2014, 10:29 AM
Astradone's Avatar
I have the white dots too! After reading this thread I called Mitsubishi and they are sending out a technician with the free chip for $ 200. My set is 2009 WD65837. Thanks for the info.
Astradone is offline
post #235 of 365 Old 06-03-2014, 10:13 PM
Dr_jitsu's Avatar
Quoted: 74 Post(s)
Liked: 53
I have 2 Mitsu DLP's, A 70 something (for over 5 years) and an 82 inch for my main home theater. Once properly calibrated, I have a TV (fits perfectly in my CRT cutout, logs like a flat screen) that is every bit as good as another type TV, at one quarter of the price.
I have 30K in my home theater. I also have the white dots.
$200 is absolutely reasonable to fix it. Any type of repair person will want $100 just to pull in your driveway.
Dr_jitsu is offline
post #236 of 365 Old 06-03-2014, 10:41 PM
TinnEars's Avatar
Liked: 73
My old Mitsubishi DLP TV lasted over 12 years before the dots appeared. Given its age I chose to recycle rather than repair it especially since it needed a new lamp too.
TinnEars is offline
post #237 of 365 Old 06-05-2014, 02:59 PM
pudealee's Avatar
I have a WD-73738 - it is about 4 years old. Last night the TV went into this "checkerboard mode." At first I thought it may be the signal, but after trying various inputs, I realized it was the set. I turned the set off for a while, and eventually after an hour or so the picture started to come back. This morning it was crystal clear.
The other evening, it did it again, but this time it has not made it back to normal. I have attached a picture of the issue. Any ideas what may be going on?
My AVR is a Denon AVR-2312CI. I use HDMI connections only. I swapped out the WD-73738 with another TV, and the other TV worked fine. I also tried switching the cables (from all sources - BluRay, Sat box, etc) - all produced the same results as in the linked picture.
Thanks!!
http://www.handyville.com/rube/008.JPG
pudealee is offline
post #238 of 365 Old 06-13-2014, 01:11 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
http://www.avsforum.com/t/1523680/an...ip-replacement
Install went smoothly, took maybe 30 minutes, and perfect image afterward.
post #239 of 365 Old 09-12-2014, 02:46 PM
Liked: 0
I too called Mitsubishi. They 1st offered me the free chip with $200 for the install. I told them they had manufactured my TV with a defective chip and like the car companies with a recall they should fix it for free. I was put on hold and then the young man helping came back on and said free chip $200 for install and they will throw in a free lamp. Well I had just replaced the lamp before the black & white spots started so I didn't want a lamp. I said no this is unacceptable. You need to fix my TV @ no cost to me. Was put on hold again and then he came back on and said they would cover the $200 too. Am at the point of waiting for the service company to receive the part and make an appt with me. Will update after my repair is complete.
jwb524 is offline
post #240 of 365 Old 09-12-2014, 02:58 PM
collin's Avatar
Good for you. When I was in the same situation, they would not budge on the $200. I even went two levels of escalation and contacting their executive level, etc. without any luck. They didn't even offer me a free bulb.
collin is offline
Reply Rear Projection Units
