Hi all new here , begging for help on a dim DLP display Mitsubishi 60735 - AVS Forum | Home Theater Discussions And Reviews
Old 10-28-2010, 02:27 PM - Thread Starter
battyt2000's Avatar
I hope I am posting this in the right place, If not i apologize. I have a mitsubishi wd 60735 DLP TV. I have noticed ever so slightly a decrease in brightness. Its neve been extremely noticeable until today. I turned it on and the picture is incredibly dark. So much so that viewing it in the day time is near impossible. Colors and all still look good but display is just very very dark.
I was thinking this might be a bulb but I'm such a noob I'm not sure. Is there anything else I should be looking at that might cause this. The lamp light has not turned on to indicate any sort of problem. I have just tried turning the brightness all teh way up and it really makes no difference at all. Any help you guys could give me would be so greatly appreciated.
Thanks a ton in advance
battyt2000 is offline
Old 10-31-2010, 12:12 PM
videobruce's Avatar
Quoted: 597 Post(s)
Liked: 246
The only thing it should be is the lamp. How many hours on the set? Press Menu, then 2470, do not press enter. Press Exit to exit. It's on the lower left corner in hours.
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
Old 05-16-2011, 12:13 AM
brentcd's Avatar
I have a Mitsu WD 60735 and the picture has been progressively dimming over the last few months. I used the menu command and found out I have 5400 hrs on it. Is it certainly the bulb? Are there other cleaning steps to do if/when I replace the bulb?
brentcd is offline
Old 05-16-2011, 12:15 AM
brentcd's Avatar
Second question, If it is a bulb, where is the best place for a good price on a good bulb?
brentcd is offline
Old 05-16-2011, 08:07 AM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
Mits is the best place to get the lamp it will include the housing. As for cleaning vacuum as much dust out as you can, that is supposed to be done periodically.
colour is offline
Old 05-16-2011, 11:56 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Nothing in life is certain, but here is some information about bulb life:
Most rear projection televisions come with three presets. For example, the some LCD rear projection TVs have three presets Vivid, Standard and Pro. Vivid is the preset the when first taking it out of the box. The "Vivid" setting will lessen the life of the lamp to approximately 3600 hours because it is the brightest setting. The "Standard" setting will extend to about 5300 hours of lamp life and "Pro" will further extend the lamp life to around 8000 hours. No matter what rear projection TV you own, changing the picture setting to normal or standard will lengthen the life of the lamp. Decreasing the contrast setting to around 50% will accomplish the same.
Operating the set at a high elevation can lessen bulb life.
arnyk is offline
