HP MD5880N Bulb Question (image) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-07-2011, 09:45 AM - Thread Starter
Levelse7en's Avatar
I've had a MD5880N since 2005. The bulb blew out New Year's day this year and I just received a replacement. I had no issues with the picture prior to the bulb breaking (and it was probably past-due as I use the set a lot.).
Anyhow, I'm pretty confident I can replace the bulb on my own. However, there's a weird piece of glass mounted on the front of the replacement that doesn't look like it belongs there. Can anyone verify if this is just safety packaging, or is it an actual component? I've included a picture, there's a lateral piece of glass across the bulb that seems mounted to it with an adhesive. I'm very wary of having to remove this and make sure there is no adhesive left on the bulb. I don't want to have another blown bulb on my hands.
Picture:
http://imgur.com/Pvk70
Levelse7en is offline
post #2 of 2 Old 01-13-2011, 06:22 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
1. It's a lamp,
2. Obtain the Service Manual.
Here is HP's support page;
http://h20000.www2.hp.com/bizsupport...eriesId=472499
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
Reply Rear Projection Units
