Hlr 6768 shadow - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-10-2011, 05:44 AM - Thread Starter
oceans711's Avatar
A Samsung technician replaced the shattered color wheel and bullb. Now there is a 6 inch shadow across the top of the screen. The picture on the screen and behind the shadow is perfect. Can I fix this? The technician said he needs to remove the entire unit to find the problem.
oceans711 is offline
post #2 of 10 Old 02-11-2011, 04:55 AM
videobruce's Avatar
Quoted: 608 Post(s)
Liked: 247
Something is blocking the light path. Have you been here yet?;
http://www.avsforum.com/avs-vb/showthread.php?t=1310024
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
post #3 of 10 Old 02-11-2011, 06:40 AM - Thread Starter
oceans711's Avatar
Thanks for your reply. Yes I have been searching through posts at the link. Any suggestions as to what could be blocking light? The service person thought it might be a piece of the shattered color wheel. If so would it be a non technical access?
post #4 of 10 Old 02-11-2011, 07:28 AM
videobruce's Avatar
Quoted: 608 Post(s)
Liked: 247
Can you post a screen shot?
post #5 of 10 Old 02-11-2011, 08:49 AM - Thread Starter
oceans711's Avatar
Thanks for your reply.Picture attached-very bright in room during the day.
post #6 of 10 Old 02-11-2011, 08:57 AM - Thread Starter
oceans711's Avatar
This is a bit better.
post #7 of 10 Old 02-11-2011, 09:16 AM
videobruce's Avatar
Quoted: 608 Post(s)
Liked: 247
Find the "R" series thread and post the question there.
post #8 of 10 Old 02-11-2011, 01:02 PM - Thread Starter
oceans711's Avatar
Thank you again for your replies-not sure how to find "R" thread-could use help.
post #9 of 10 Old 02-12-2011, 05:10 AM
videobruce's Avatar
Quoted: 608 Post(s)
Liked: 247
1. Clink on link,
2. Scroll down to specific threads,
3. Find one that covers your series (R) or whatever is close,
4. Clink on link.
post #10 of 10 Old 02-12-2011, 12:39 PM - Thread Starter
oceans711's Avatar
Thanks, Samsung said they would send someone else out and if it is a light tunnel problem they will repair it free of charge and if it's another issue it's my charge. Comments appreciated.
Reply Rear Projection Units
