Help! Samsung dlp tv! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-08-2011, 01:55 PM - Thread Starter
jdunc04's Avatar
I have a Samsung 56" DLP that is giving me problems. The display is destroyed. Please tell me what part I need to replace in order to fix it!! I have many spots showing randomly throughout the screen. I have attached images.
So far I have replaced the Ballast, Power Supply, and Bulb. I bought the tv for 1100 2 1/2 years ago and spent 500+ last month replacing those parts and now this is happening. Is it work fixing? or should I cut my losses?
Jdunc04
jdunc04 is offline
post #2 of 4 Old 04-08-2011, 08:33 PM
pacofortacos's Avatar
Liked: 24
Wrong forum, you would be better served in the Rear Projection forum.
However it appears as if your light engine/DMD chip is failing.
Only other possibility would be dust, but I'd bet it is the DMD failing.
pacofortacos is offline
post #3 of 4 Old 04-09-2011, 04:08 PM
Ken H's Avatar
Moved.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #4 of 4 Old 04-10-2011, 07:56 AM
mes444's Avatar
The white dots do usually relate to a malfunctioning dmd chip, the mirrors are sticking. For a while Samsung was repairing this problem out of warranty, so calling them to see if they still are would be a good idea.
If they are not, my opinion would be it's time to get a new tv.
mes444 is offline
Reply Rear Projection Units
