Lens flapping adjustment possible? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-13-2002, 09:26 PM - Thread Starter
spexman's Avatar
Can lens flapping adjustment be done on a RPTV?
If so, please let me know how!
spexman is offline
post #2 of 5 Old 04-15-2002, 02:11 AM
Guy Kuo's Avatar
Placement of thin washers at the lens mounting bolts you can effect flapping. Just be careful not to drop those washers. However, you still can't correct peripheral vs center focus like on a FPTV
Guy Kuo
Guy Kuo is offline
post #3 of 5 Old 04-15-2002, 11:10 AM - Thread Starter
spexman's Avatar
Guy, thank you VERY much! What a simple yet CLEVER technique!
Why do RPTV's not allow adjustment for peripheral focus?
Thanks again!
spexman is offline
post #4 of 5 Old 04-15-2002, 06:12 PM
Guy Kuo's Avatar
Cost. The RPTV lenses only have to focus in a small range of distance values they can get away with using a simpler lens arrangement optimized for a single distance and still yield acceptable edge focus. FPTV need to contend with a large range of projection distances so the lense needs to cope with the varying curvature of the focus plane as the projection distance varies. That's why both edge and center optical focus elements are needed in FPTV.
Guy Kuo
Guy Kuo is offline
post #5 of 5 Old 04-16-2002, 06:51 PM - Thread Starter
spexman's Avatar
Cost was my suspicion as well.
Thanks once again for your knowledgable information!
spexman is offline
Closed Thread Rear Projection Units
